knock sensor low voltage
Old Oct 16, 2011 | 10:53 PM
gc258's Avatar
gc258
7th Gear
Default knock sensor low voltage
Just wondering if anyone has seen that code pop up and what should I be looking for?I just replaced my fuel pump with racetronics harness and walbro 255,now engine light comes on,when I plug in obd reader i get knock sensor low voltage.I've been searching the forum for hours and have found nothing.
Old Oct 17, 2011 | 12:42 AM
87SAM's Avatar
87SAM
So what codes does the DIC show, a P0325?
Old Oct 22, 2011 | 04:38 PM
gc258's Avatar
gc258
7th Gear
Default codes
well lets see looks like I have 4 codes;
10 pcm p0332 h c
99 hvac b0333 h c
bo-rfa c2100 h c
bo-rfa c2105 h c
anyone?help?
Old Oct 22, 2011 | 04:50 PM
gc258's Avatar
gc258
7th Gear
Default codes
ok,did a little investigating looks like the code thats given me a problem is
the po 332 knock sensor.Anyone else have this problem?
Old Oct 22, 2011 | 04:55 PM
lucky131969's Avatar
lucky131969
Exactly what was disturbed while installing the racetronix harness?
Old Oct 22, 2011 | 07:30 PM
gc258's Avatar
gc258
7th Gear
Default disturbed
conection to alternator and pump,also my gas gauge doesn't work now,it goes from 3/4 to empty
Old Oct 22, 2011 | 08:26 PM
lucky131969
Ok. No correlation to the knock sensors there. You will have to investigate the harness/sensors. As far as the fuel level, go over your work.........if everything was normal before you touched it.
Old Oct 23, 2011 | 09:53 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The knock sensor circuit is pretty simple but,, its in a crappy spot. Do you or have you ever hosed off your engine to wash it???
Heres what the covers for the sensors and the wires look like:
If water gets into the well the sensor will self destruct. The only way to examine the sensors is to remove the intake manifold.
BC
Old Oct 23, 2011 | 02:47 PM
gc258's Avatar
gc258
7th Gear
Default thanksd
thanks guys,i was really trying to avoid pullin the supercharger yet again,
if it keeps up i guess i will over the winter.
To knock sensor low voltage
