clutch issues/harder to shift....
-shifting though never smooth is getting more "sticky", harder to find the correct gear
-noted a "hot asbestos" smell when driven around town, lots of stop and go, hot weather. It's not the brake pads.
-clutch fluid looks ok
Clutch/pressure plate? ran the high rpm, slutch engaged test, car doesn't move. Anything else to try or help diagnose?
How long does the clutch last in a C5; not first owner, though, I think it's been driven moderately.
thanks
Jim
Remove the console and lube up the shift box. you will be amazed at how stiff they can get.
Align your shifter and make sure that the rubber bushings that mount the shift box to the torque tube are not deteriorated and loose.
BC
thanks
Jim
Sometimes 1st gear feels like i have to press it in 2-3 times to get it in, and i aint skinny haha. i try not to push in to hard, but it takes quite an effort. the worst thing is, sometimes you dont know if it really is in first gear, or reverse, but i feel the first gear more, so i almost never grind it(sometimes it stucks between..) reverse stucks every so. and grinds, hurts me deeply in hearth..
would an short shifter be more confident that gear is in 'gear' ?
thanks
Denis
