cam or gears?
Old Oct 25, 2011 | 04:49 PM
LTCHAPPA's Avatar
LTCHAPPA
Default cam or gears?
I have c5 vert 6sp headers, cia,tuned ,357 rwhp.Looking for a nice power boost but undecided,either way i will need a new clutch. Opinions needed on a cam or gears.
Old Oct 25, 2011 | 06:12 PM
Pumba's Avatar
Pumba
From my 8 years of experience in modifying a C5, the very best performance improvement for the $ is a 4.10 ring and pinion gear set!
It instantly adds 20% more rear wheel torque, improves driveability across the entire driving range, and doesn't adversely affect the engine's idle quality.
Old Oct 25, 2011 | 08:05 PM
dankhts's Avatar
dankhts
do both! Throw a pair of heads on there too while you're at it!
Old Oct 26, 2011 | 10:00 PM
mitchell c's Avatar
mitchell c
If I could only afford to do one modification. I would do 4.10 gears.
Old Oct 27, 2011 | 05:02 PM
67ermine's Avatar
67ermine
Old Oct 29, 2011 | 02:16 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Another vote for 4.10 gears!
__________________
Old Oct 29, 2011 | 02:21 PM
99 vett babycar's Avatar
99 vett babycar
Old Oct 29, 2011 | 03:20 PM
RaW Z06's Avatar
RaW Z06
Rick, what would you recommend for a stock 2002 Z06?
Old Oct 29, 2011 | 03:33 PM
Supporting Vendor
For a stock Z06 with M12 (2.97 first gear) I wouldn't go over 3.73's. This set up will be similar to MM6 with 4.10's.
Old Oct 29, 2011 | 03:41 PM
RaW Z06's Avatar
RaW Z06
With stock Z06 gears being 3.42 is it really worth the time and money to go with the 3.73's..... I guess Im trying to figure out if the gains are worth the pain.....
Old Oct 29, 2011 | 04:09 PM
silver408z's Avatar
silver408z
Not gears. The more power you start making the more you are going to spin. Unless you are going to run some kind of more than normal sticky tire you are going to spin. I am making 500 rwhp, on drag radials and 342's and I spin. It would only be more spinning with a steeper ratio
Old Oct 29, 2011 | 07:21 PM
PRE-Z06's Avatar
PRE-Z06
Gears and a cam really compliment each other, so I recommend both!
Old Oct 29, 2011 | 07:56 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Gears
Old Oct 29, 2011 | 08:03 PM
Tampa Tuning's Avatar
0Tampa Tuning
Former Vendor
St. Jude Donor '12
I went cam, then needed gears
Old Oct 29, 2011 | 10:29 PM
mitchell c's Avatar
mitchell c
3.90 gears are a good compromise on a Z with the M12 tranny.
Old Oct 30, 2011 | 12:23 AM
sami85L98's Avatar
sami85L98
or SC it and no gears...lol.
Old Oct 30, 2011 | 07:26 AM
AU N EGL's Avatar
AU N EGL
Heads and Cam with the right cam. Most guys go too big of a cam. 224/230 cam
Driven too many 4.10 cars, FELT FAST, but really were not as fast as the stock 3.42
To cam or gears?
Old Oct 30, 2011 | 11:13 AM
Drumbum675's Avatar
Drumbum675
I'm also considering gears or a cam. This thread is helping.....
Old Oct 30, 2011 | 12:57 PM
JanCorvette's Avatar
JanCorvette
Cams the car will make more power and be faster, on the down side, it is fairly big labor, cause steering rack comes out, and idle and drivability issues may come up. On the other hands, gears 4.10, the car will make the same power just delivered differently. It will feel faster and maybe pick up .3-.5 at the track with tires. But everything else is like stock. I went with the gears and they feel great.
Old Oct 30, 2011 | 01:03 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
Driveabilty is all in the tune, I have the MayhemII cam, its pretty big. I am making 435 RWHP with stock heads on my 04 Coupe. It's my DD and drives great, I like the shake and told Englandgreen to tune it that way.I Have about 20000 miles on the cam, and I absolutely love it. Though England has tried to talk me into gears as my next mod, which sounds good to me.
