3.90 or 4.10
Old Nov 15, 2011 | 02:06 PM
Daddyrama31's Avatar
Daddyrama31
Default 3.90 or 4.10
Guys:
I think I know where I am going to go but wanted to hear your opinions on the matter. Here are the specs on my car. Weekend warrior and semi daily driver 2000 Z51 Convertable:
  • A.I fully worked 2.5 heads
  • Kooks catted long tubes
  • Isky 226/232 604/605 113 LSA
  • PAC springs....
  • SLP Under drive pully
  • Modified Blackwing CAI with CC air bridge
  • LS6 ported intake
  • 90mm ported TB
  • NGK plugs
  • MN6
  • Dyno Tuned
Car Pulls like crazy from 3k to 7k.
Thoughts and opinions welcome.
Old Nov 15, 2011 | 04:21 PM
Tech's Avatar
Tech
Originally Posted by Daddyrama31
Guys:
I think I know where I am going to go but wanted to hear your opinions on the matter. Here are the specs on my car. Weekend warrior and semi daily driver:
Isky 228/230 604/604 114 Cam
PAC springs....
LS6 ported intake
90mm ported TB
NGK plugs
Dyno Tuned
4.10s without hesitation (assuming you have a manual transmission). If you have an auto, then we'll need to know the current gear ratio and torque converter stall speed.
Old Nov 15, 2011 | 06:26 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Guys:
  • Isky 228/230 604/604 114 Cam
  • PAC springs....
  • LS6 ported intake
  • 90mm ported TB
  • NGK plugs
  • MN6
  • Dyno Tuned
You should go with 3.90's. With 4.10's at your power level, first 2 gears will just spin the tires.
__________________
Old Nov 16, 2011 | 02:05 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Listen to this Rick@RKT56!!!!! He's the BOMB! That was my initial thought also!! You have enough power to handle any gear ratio. Consider your DAILY DRIVING needs also.....3:90s will work excellent and help keep fuel milage in a reasonable range..
BC
Old Nov 16, 2011 | 02:58 AM
Supporting Vendor
BC
Old Nov 16, 2011 | 07:55 AM
CTD's Avatar
CTD
Either ratio is going to be better, I think you will have a traction problem either way, if you are not running better tires.
Many do not work to improve the traction after the gear change.
There is some excellent discussion over in the dark side "C6" Some very factual arguments presented. If you are inclined to check some of it out search "tractionmonster"
Here is one link...long read......
http://forums.corvetteforum.com/c6-t...-solution.html
I have 4:10's in my 01 Vert, Stroker LS3. Besides the performance improvement with gears, 5th & 6th gears are now very usable.
I'm removing my driveline again, more clutch grief, if I had any issue with the 4:10's they would be getting changed out as well.
Old Nov 16, 2011 | 01:56 PM
Daddyrama31
Thanks for the feedback. Keep the OP's coming please!
Old Nov 16, 2011 | 03:32 PM
Dope's Avatar
Dope
Resident moron
4.10s for sure. I went with 3.90s originally about 8 years ago, just upgraded to 4.10s. It's worth it. You're not gonna have traction either way. Go big or don't waste your money, in my opinion. For a big cammed M6 car 4.10s all the way.
Dope
Old Nov 17, 2011 | 04:52 PM
PRE-Z06's Avatar
PRE-Z06
Dope
I agree, the small difference between the two is hardly noticeable besides the 100rpm difference cruising. As long as you're not running out of gear for a particular race, I doubt you'd be able to discern a difference between the two imho.
Old Mar 21, 2012 | 11:16 PM
silrac's Avatar
silrac
1st Gear
Can you cruise the highway with 4:10 manual tranny ?
Old Mar 22, 2012 | 06:31 PM
rootpooty's Avatar
rootpooty
yes on a mn6 i think others have posted around 80 its around 2200 but i could be wrong being i dont have 4.10's.
Old Mar 22, 2012 | 09:51 PM
Armycop's Avatar
Armycop
Did a check today running home from work:
3.90 rears, 6th gear, 80mph; 1800rpm's, 27.6 mpg's. Still lights up the tires in first and second.
To 3.90 or 4.10
