head install help
Old Jan 3, 2012 | 02:10 PM
WHoisu05's Avatar
WHoisu05
Default head install help
i recently broke springs on my 2002 z06 i want to upgrade the heads while im at it since the motor has 85k miles and a bolt is broke in the head from a header install. once i take the old heads off will the new heads just bolt back on with new gaskets? they are the same 243 casting. also do i need new lifters and pushrods? i know these are fairly easy answers i just want to make sure i'm on the right path before i start buying everything.
Old Jan 3, 2012 | 02:19 PM
lucky131969's Avatar
lucky131969
With 85K on the clock, I would definitely replace the lifters and pushrods during a head swap. New gaskets and new head bolts.
Old Jan 3, 2012 | 02:22 PM
WHoisu05's Avatar
WHoisu05
thanks thats what i was thinking. i dont want a crazy build just a little something extra that will freshen up the motor. ive read a few threads that people are using ls7 lifters have you seen this?
Old Jan 3, 2012 | 02:45 PM
lucky131969
If you are sticking with stock lifters, that's all that is available.
Old Jan 3, 2012 | 03:11 PM
WHoisu05's Avatar
WHoisu05
Have you ever used Texas speed cams? Looking at torquer v2 v3 or 233/239 with 112 lsa.
Old Jan 3, 2012 | 03:15 PM
lucky131969
Nope, but plenty on this forum have.....I'm sure they will chime in.
Old Jan 3, 2012 | 03:27 PM
vettenuts's Avatar
vettenuts
Not all 243 heads are the same. Your heads have the lightweight valves. Do the heads you are using for replacement have the same valves?
Old Jan 3, 2012 | 03:30 PM
WHoisu05's Avatar
WHoisu05
Yes I believe they do
Old Jan 3, 2012 | 06:13 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
MAKE SURE,,,,,,, that the head bolt holes in the block are ABSOLUTEY "DRY" and clean!!!!!!!!!!!!!!!!!!!!!!!!!! Damage will result if not!!!!!!!!!!!!!!!!!!!
BC
Old Jan 3, 2012 | 06:16 PM
WHoisu05's Avatar
WHoisu05
Does anybody know the pushrod length?? Texas speed said unless I measure them there's no way to tell
Old Jan 3, 2012 | 06:17 PM
Paul 75 L82's Avatar
Paul 75 L82
Bill is right on, you can break a block easy. I have the Texas Speed 228R cam and it is very street able with great power gains.
Old Jan 3, 2012 | 06:21 PM
WHoisu05's Avatar
WHoisu05
I'm looking at the torquer v3 and the 233/239 tsp said they are all real close together
To head install help
