98 c5
Old Jan 16, 2012 | 02:35 PM
tonyost's Avatar
tonyost
Default 98 c5
I have a issue on wipper they will not go all the way down when i turn them off
Old Jan 16, 2012 | 09:27 PM
geezel's Avatar
geezel
With mine the problem was the wiper motor cover (has a circuit board underneath). It doesn't take much moisture in there to make them go bad.
Old Jan 16, 2012 | 11:28 PM
BigGun's Avatar
BigGun
Do an advanced search. In the keywords section select search in titles only and type in the word wiper. You will get 203 hits. There could be many reasons for your problem.
Old Jan 17, 2012 | 10:46 AM
tonyost's Avatar
tonyost
Started after replacing the window
Old Jan 17, 2012 | 01:09 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The wiper motor control board is on the bottom of the motor. It sits in a well in the windshield cowl. The cowl has several drain udders. IF,,,,,,,,,,,,they get clogged, it floods the motor and board and the wiper malfunctions.
Clean the udders and the wells and make sure that there draining correctly.
ON THE COWL BEHIND THE BATTERY
Old Jan 17, 2012 | 01:45 PM
tonyost's Avatar
tonyost
Will i need to remove the fender for this ?
Old Jan 17, 2012 | 01:48 PM
tonyost's Avatar
tonyost
I install driver wiper all works great install passenger not ?
Old Jan 17, 2012 | 08:20 PM
geezel's Avatar
geezel
Are you saying one wiper is is the parked position and one is not?
Old Jan 17, 2012 | 09:59 PM
RedC5's Avatar
RedC5
Cause me great grief this summer....udders clogged failed my motor from rain ....had to replace motor.
Old Jan 17, 2012 | 10:48 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Look at second pic! Reach in there to to access them
Old Jan 18, 2012 | 04:53 AM
tonyost's Avatar
tonyost
Motor bad have to replace it to much play
To 98 c5
