c5 oil pressure zero! HELP!
Old Feb 20, 2012 | 01:39 PM
  #41
CatCam's Avatar
CatCam
vettegirl -
1st - hats off to you, not a lot of guys out there will tear into a car like you have - I salute you and toast you with a 1/2" ratchet drive!!
Yes, frustrating that some folks can put 250,000 miles and only change a battery, alternator & lightbulb or two.
Others aren't as lucky.......
All that being said, I have buddies of mine who own 911's, Mustangs, BMW's & Chargers and they all have had "issues".......the 2002 Porsche 911's issues are many, the BMW's are ELECTRICAL and are $$$$$$ to fix.
Keep us posted & hang in there,
CatCam
Old Feb 20, 2012 | 02:16 PM
  #42
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
glad to hear you found the problem.
Now make sure you put it back together the proper way, I'm talking about the new balancer!
Old Feb 20, 2012 | 04:16 PM
  #43
dougbfresh's Avatar
dougbfresh
May as well pin it while your at it!
Old Feb 20, 2012 | 04:35 PM
  #44
VetteNoob's Avatar
VetteNoob
Learned something about the filter.
Pick up a katech c5-r timing chain. While youre there if your block is already drilled for the timing chain damper you may also consider getting that from them as well.
Old Feb 20, 2012 | 05:52 PM
  #45
printmanjackson
that's way overkill
Old Feb 20, 2012 | 08:57 PM
  #46
PilotofCorvette's Avatar
PilotofCorvette
Another happy ending.......
Old Feb 20, 2012 | 10:08 PM
  #47
VetteNoob's Avatar
VetteNoob
that's way overkill
What do you mean? I left the cam off the list
Old Feb 21, 2012 | 10:01 AM
  #48
rebelheart's Avatar
rebelheart
If she is doing this herself, unaided,she is my kinda gal!
Old Feb 21, 2012 | 11:35 AM
  #49
DBLTRGR's Avatar
DBLTRGR
Vette Girl, are you married? Oh... never mind, I am.
Old Feb 21, 2012 | 03:36 PM
  #50
hornet7's Avatar
hornet7
Default Cheap Entertainment
Man this was fun to read.
Old Feb 22, 2012 | 12:27 AM
  #51
Redhawg's Avatar
Redhawg
Old Feb 22, 2012 | 09:23 AM
  #52
chaase's Avatar
chaase
St. Jude Donor '12
New balancer, pin it and if the timing chain is loose you can get an LS2 chain for very little money. They are beefier than stock.
Old Feb 22, 2012 | 10:07 AM
  #53
RonSSNova's Avatar
RonSSNova
LS2 chain will be loose as well. Read about that on LS1Tech. It is a stronger chain though.
Old Feb 22, 2012 | 10:41 AM
  #54
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Unless this is an engine that going to be hammered regularly on a road course or at the track,, the LS2 chain will be more than adequate. It’s a LOT better than the old LS1/6 chain. Sure there are much better chains but price may be a big factor in the selection choice!
Here the comparison between an LS2 chain (on the engine) and a used LS1/6 chain. Note the thicker links and if you look very closely, you can see the parting line in some of the rollers between each link. :
Old Mar 2, 2012 | 01:26 PM
  #55
Dnealy's Avatar
Dnealy
Just went through the same situation with my car after i put the top end back on (oil pump was off for a few days). Anyways turned out that the valve was stuck in the LS6 pump so i had to tear it all back down and replace the pump, problem solved in my case anyways.......hope that helps to clear it up a bit.
