"Serv Tire Mon Sys" with new CCW's
Old Feb 27, 2012 | 09:32 AM
tsbbzm's Avatar
tsbbzm
Default "Serv Tire Mon Sys" with new CCW's
I've had my new CCW's on for about 4 months now, and no problems till yesterday.
I was on the interstate for about 1 hour, looked down and displayed on the DIC was "Serv Tire Mon Sys"
When I purchased the new CCW's I also had them install new TPMS, like I said everything was fine till yesterday's trip.
Anyone out there know what's up with this, "Serv Tire Mon Sys"?
I have done a search didn't really find anything about CCW's and new TPMS.
Any help will be appreciated!
Old Feb 27, 2012 | 09:42 AM
BigGun's Avatar
BigGun
Have you tried to reprogram them? Easy to do. What does the dic read when you access the tire pressure?
Old Feb 27, 2012 | 10:29 AM
DeeGee's Avatar
DeeGee
After the fit were they operating normally? Any unusual pressure indications or XXX? Do you have any codes?
A retrain is the obvious thing to try first.
Old Feb 27, 2012 | 10:55 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The FIRST thing that you need to do is read and post you’re DTCs. There are several things that can cause that issue. Having the DTCs is the most expeditious method to tell you which direction that you need to take to resolve the problem.
READING YOUR Engine Diagnostic Codes
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine. NOTE! You can read the DTCs with the engine running and or driving down the road but it can distract you. BE careful! Some DTCs clear themselves when you turn the ignition OFF!
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current C code indicates a malfunction is present and active in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except English/Metric (E/M). Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press and hold the RESET button To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5. You can GOOGLE the DTC and also find information on it.
Here is very good site that explains the DTCs:
http://www.corvette-web-central.com/C5DTCcode.html
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Old Feb 27, 2012 | 11:52 AM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
with Bill. Also, has your remote keyless entry stopped working? If so, it may point to a bad receiver since they use the same receiver as the TPMS.
Old Feb 27, 2012 | 12:04 PM
AU N EGL's Avatar
AU N EGL
Just hit the reset button
Old Feb 27, 2012 | 08:10 PM
tsbbzm's Avatar
tsbbzm
Originally Posted by 8VETTE7
Did you program the TPMS to the car when you got the new wheels???
Here's a link to the procedure or take the car to a good tire shop and they can do it for you:
http://forums.corvetteforum.com/1575862367-post6.html
I programmed mine a year ago when I got my CCW's and have NOT had a problem since.
This worked! Thanks, You Guys are the GREATEST!!!
To "Serv Tire Mon Sys" with new CCW's
