How much louder are headers?
Old Mar 11, 2012 | 07:44 PM
skeeters65's Avatar
skeeters65
Default How much louder are headers?
I have a 01 Z06 that is stock except a GHL cat back system.
My questions is how much louder will it be if I add headers and an off road mid-pipe?
Old Mar 11, 2012 | 07:53 PM
hardcore4sure's Avatar
hardcore4sure
Alot
Old Mar 11, 2012 | 07:55 PM
tstrobl1's Avatar
tstrobl1
I went from the stock exhaust with Magnaflow axle back to XS Power longtubes and off road x pipe with the same Magnaflow axle back. A little deeper tone but not much extra volume.
Old Mar 11, 2012 | 10:22 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The main reason for an engines exhaust note to be a LOT louder is the addition of a more aggressive cam and higher compression.
One thing that you will here more of is the sound of the exhaust valve and the initial pop of the exhaust gasses leaving the head. Its not loud but it will be a new sound that you will wonder what it is.
Your new headers will add a few more DB to mix but not a drastic amount. I have an 02 ZO6 and i have a complete stainless works system. Going from the stock Ti mufflers and manifolds, made a very nice improvement with NO DRONE. It wasn't too loud at idle and would grab your attention at WOT.
After I installed a big cam, ported heads with 11.5:1 compression, WOW,, the system got a LOT louder..
BC
Old Mar 11, 2012 | 11:03 PM
chevylad's Avatar
chevylad
I put a catback exhaust on first and there was a pretty big difference. I added and x-pipe, headers and high flow cats. There was some difference, but it wasn't that obvious. Next was heads and cam and that was also a pretty big difference.
Old Mar 11, 2012 | 11:45 PM
StingrayRebel's Avatar
StingrayRebel
i agree with bill, headers won't add a whole lot of volume by themselves... you will notice a "ticking" sound which is valve noise and is normal... the main thing that will add volume is removing the cats and the type of catback system you use... i replaced my titanium with corsa xtreme's to start and it was definitely louder than stock at wot and pretty tame at idle and while cruising with no drone... then i installed lg super pros and removed the cats... it is noticeably louder at idle, still pretty tame while cruising with no drone which is great, and anything 3k rpms and up is
Old Mar 12, 2012 | 01:55 AM
zeevette's Avatar
zeevette
Since you have the pup cats, headers,and an offroad X will be a notch louder.
Old Mar 12, 2012 | 02:19 AM
robg2001ls1's Avatar
robg2001ls1
Mine didnt get too much louder at idle. Just at WOT and thats with cats and Borla Stingers
Old Mar 12, 2012 | 05:24 PM
alj357's Avatar
alj357
What type of headers did you go with? Any sound clips (I have Borla stingers as well)?
Al
Old Mar 12, 2012 | 06:14 PM
AU N EGL's Avatar
AU N EGL
Classic Rock to Heavy Metal
To How much louder are headers?
