Ignition key cylinder
Old Mar 16, 2012 | 11:50 AM
Aerovette's Avatar
Aerovette
Default Ignition key cylinder
Somehow I destroyed the left side contact and the key tore part of it loose and jammed it into the cylinder. Now there is no way for my key pellet to be read.
Dealer wants $479.00 for acylinder and to make my key fit it. So here are my assumptions and questions...
1. The contacts in the cylinder don’t care what the key resistor value is and all they are is a contact point. True?
2. When contact is made, it is the car’s computer that will determine if the resistor pellet is correct. True?
3. Therefore, making a new cylinder work with the original key, is simply a matter of tumbler configuration and does not require any programming etc. True?
Questions
1. Can I transfer new contacts to the old cylinder and eliminate the need for a locksmith?
2. Can I take the cylinder apart and transfer tumblers myself? ( I am mechanically competent ) J
I can get a cylinder on line (AC Delco) for less than half the dealer price. $149.00 at the dealer, $69.00 on line.
I can’t find a locksmith that understands what I am asking them to do. ( I have spoken to 6 so far).
Have any of you taken a cylinder apart?
I am thinking I will do it and make a nice write up with pictures if my assumptions above are correct. How hard can it be?
THANK YOU !!!!
Old Mar 16, 2012 | 01:37 PM
dlind4's Avatar
dlind4
I just had mine a month ago do this. I took apart the dash (not too hard) Just buy a lock cylinder and find a competent locksmith to rekey it. I can't believe that you talked to six of them and they don't know how to do it. I was told not to use the tumblers from the old ignition cylinder by the locksmith. He had new ones on him. Plus it looks like it might be a pain. I paid 120 dollars for the lock cylinder( I know its a high price but I didn't want to wait) and 45 dollars to the locksmith. 165 dollars is better than 479. Put it back in and back in business.
Old Mar 16, 2012 | 02:07 PM
Aerovette's Avatar
Aerovette
8VETTE7,
Thank you.
I wanted to keep it simple but without fail, they would ask me what car it was for and everything would go south from there.
I finally found this guy that said it was $289.00 and I asked why and he went on about travel time and removal and I said whoa whoa big fella. I will bring you two cylinders...one NEW, one OLD, I just need you to match the tumblers.
He said, "Oh yeah, I can do that. Takes about an hour and it'll cost you $45.00".
WAHOO !!
Old Mar 25, 2012 | 08:55 PM
Aerovette's Avatar
Aerovette
**************** UPDATE *****************
I purchased the lock cylinder on amazon.com for &$68.00 and it showed up 5 days early so I dug into it.
I took the old cylinder out and apart and instead of going to a locksmith, I transferred the tumblers one by one myself and put it all back together.
Crossed my fingers, turned the key...
VROOM....a $479.00 job done for $68.00 and about three hours of my time (took pictures for a write up if anyone is interested.)
Old Mar 26, 2012 | 02:50 AM
DeeGee's Avatar
DeeGee
Originally Posted by 8VETTE7
I would love to see the pictures and read your writeup. The issue of the key cylinder replacement shows up on the Forum from time to time and it would be nice to have the info to be able to pass along to another poster with that problem.
Old Mar 26, 2012 | 06:23 AM
SMaster's Avatar
SMaster
Good Job! Would love to see your pictures and write up!
Old Mar 26, 2012 | 01:50 PM
Aerovette's Avatar
Aerovette
I'm about halfway through the write up. In hindsight, I wish I had taken more pictures. It is so much easier to explain when you have something to look at.
Old Apr 30, 2012 | 09:57 PM
Please do post up your pics and writeup when you finish.
Old May 21, 2012 | 09:32 AM
CactusCat's Avatar
CactusCat
Have you finished your write up and posted the pictures? I'd be interested in seeing this as well.
Old Oct 14, 2012 | 05:44 PM
jason g's Avatar
jason g
I'll fix it if I can
I'd appreciate the write up/photos as well. Anything that you have is better than nothing at all! Thanks.
Old Oct 14, 2012 | 06:20 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Post the pictures to the forum post.
Just use Photobucket and copy the (IMG CODE) of the pictures that you upload and paste it into your post.
Old Sep 20, 2016 | 11:01 AM
WeevilZ06's Avatar
WeevilZ06
1st Gear
I could use this info now as I pulled by knee bolster out and fished the vats connector out and stuck a resistor in mine to get it home .
I had had a security light come on a couple of times so covered my bases. No joke I put them in my car a hour before I was stranded but without a flashlight at night . Good cell phones to the rescue
To Ignition key cylinder
