Vibration after clutch install
Later
Darion
I just had my clutch swap done end or last week and waiting for other work to get done. Fingers crossed it all goes smoothly and hope ya get this straight sooner than later.
Darion
https://www.corvetteforum.com/c5-tec...balancing.html
Darion
http://forums.corvetteforum.com/c5-t...h-install.html
Darion
Darion
I have researched this topic extensively. The most concise way to summarize it is:
All LS engines are internally balanced. They do not require external balancing for proper engine operation. This is true for all LS engines from 1997 up to now. They are factory assembled with as-machined parts. There is no component matching or balancing the crankshaft with the actual parts your are using as would be done in a one on one aftermarket rebuild, or building an engine yourself. This is not a criticism of GM. It is how they build the engines in an economical and efficient way in order to keep the cars affordable. The parts are all made and held to pretty tight tolerances, such that when they are assembled, the overall internal balance of the engine is within an acceptable range of imbalance. This is a fact. Let's call the net build balance acceptable if it is 1.5 oz∙in or less. This is fine for the operation of the LS engine.
Now put the engine in a MANUAL TRANSMISSION CORVETTE. The unique drivetrain of all C5 and C6 corvettes are more sensitive to small imbalances than a traditional design where the transmission is attached directly to the engine. In MANUAL TRANSMISSION CORVETTES the sensitivity is even greater due to the vibration transfer path of the gear shift from the torque tube. Small imbalances can create vibrations that feel terrible and can make you think something is wrong. To minimize these potential vibrations, GM engineers do a final assembly HOT BALANCE procedure. It is only done on the manual transmission corvettes. They bolt up the FW and clutch/PP, and run the engine on natrual gas. The balance machine then tells them where to put external weights if necessary in the harmonic balancer, and or flywheel as needed to get the total assembly balance down to within .5 oz∙in at both planes. This is also a fact and anyone can verify it by taking a tour of Wixom, getting in touch with someone there, or speaking with someone who actually does the procedure. This procedure is done to FINE TUNE imbalances so they are at a lower level as to minimize unwanted vibrations. They are NOT making up for a crappy engine balance. The engine is fine beforehand, it just may be at a level of imbalance that is too high for the sensitivity of the manual transmission corvette.
SO, when your manual transmission corvette comes out of the factory, it has on it a harmonic balancer and FW/PP combo that MAY OR MAY NOT have some external balance weights in them. I would bet that most people are pretty happy with the smooth operation of their factory engine. The only way that you are going to MATCH that operation when you replace your factory clutch and FW is if you take your stock FW/PP together, have a good machine shop measure the state of balance (it could be perfectly zero balanced, slightly imbalanced, or quite a bit imbalanced, but when mated with your stock engine, the whole assembly is .5 oz∙in or better), and have your replacement FW/PP combo MATCH what you took off. It is as simple as that. If you do anything else, you are guessing. Most people will tell you, "aww that's BS, just make sure you have your stuff zero balanced". That is very good advice if you want to make sure you ONLY have a final assembly imbalance that is only what your engine alone would have, which is 1.5 oz∙in or less. When it left the factory, the whole assembly was down below .5 oz∙in!! So this just opens up the chance that you may feel new vibrations you didn't before. Your engine is fine, but it will feel like something is wrong, and who wants new vibrations?? If you just slap in a new FW/PP out of the box, without checking anything, you have an opportunity to get imbalances above the 1.5 oz∙in, and now you could have vibrations that feel very bad, and bad for your engine as well.
Anything other than match balancing your stock stuff is a crapshoot to one degree or another.
This applies to all year manual transmission corvettes. Not just early Z's, not just a few, but all, including the current manual corvettes being built today.
Since you do not have your original flywheel or PP, your chance of matching the original balance is gone. Completely.
The best thing they can do at this point, which unfortunately would require taking the clutch out again, is to take the new stuff and have them zero balanced together as close to zero as possible. This will give you a total assembly that will only have the imbalances of the engine internals, with no contributions from the FW/PP. This may bring your vibrations down to an acceptable level. This means that your engine will be fine, even though you might feel some small vibrations. If you still have vibrations bad enough to make you uncomfortable, there are ways to fine tune balance the FW/PP/engine assembly while still in the vehicle. The method will be determined by a few more things.
1. Does your new FW have the 12 circumferential balance provisioin holes? They are through holes located at the outer perimeter of the FW, equally spaced.
2. Do you have long tube headers on your car? You had a cam installed, so I'll guess you have headers as well.
Once your shop goes through and tries replacing things one at a time, hopefuly they may stumble on something else that is the cause of the vibrations. Chasing vibrations can be a nightmare, as you are fingding out. but if they exhaust their efforts, and you still have vibrations, I know a shop close enough to you that has experience with fine tune balancing the assembly while in the vehicle. Of course, if you have enough access, you can do the process yourself. PM me for more specific information if you like.
If you do, you have a balance issue that involves the clutch assembly. If you don't, it's probably an issue with the torque tube. Another possibility is that they screwed up the pilot bearing. Worst case scenario they bent/sprung something during the R&R.
I may have this same issue on a 6 speed with 17,500 on it. Please explain more regarding the couplers. Where are they located, does the clutch have to be pulled to install them, how much are they.
My problem is a rattle in first and second gear; most noticeable there. Had all exhaust bolts and nuts tigthened (sp) so that doesn't seem to be the problem. No one can seem to help. My next resort is to have B-Quiet installed under the seats and in the transmission tunnel
Thank you.
The best of Luck
Rich
Took it into a shop to have the clutch replaced again and they found the pilot bearing to be completely ground up, and damaged the input shaft, slightly bent the driveshaft and damaged the torque tube. I had everything replaced with brand new oem parts along with an ls7 clutch and ls2 flywheel.
The car drove fine with no vibration and the shift problems were gone. 300 miles later i'm getting grinding and rejected shifts again and the vibration is back.
I talk to a few people and they say it has to be something internally wrong with my trans, so i make arrangements to have a new trans installed. Two or three days before i have to drop the car off the shift problems and vibration disappear.
I ended up getting the car back last week with a new trans, and after driving it for about 30 mins the shift problems and vibration are back yet again!!
It's back at the same shop which is a reputable performance shop, and they say they will get the problem fixed and not charge me for it.
I'm clueless as to what this can be. I have well over $7k in this car right now chasing this problem and it's driving me nuts! It's been back at the shop for 5 days already and i haven't heard from them yet,which means they haven't figured it out yet. I can't seem to find anything after lots of extensive searching that is close to what i'm experiencing.
Anyone have any ideas before i jump off a bridge? lol
Let us know when you hear from the shop.
I did not suspect the viibration to be a balance issue at fiirst but now that I have replaced everything, I don't see what else it can be.
We'll see what they say, I'll keep eveyone posted.
