Performance questions
Last part of my questions concern throttle bodies. How much performance gain does one get by going to a 90mm vs a 92mm vs a 96mm vs a 102mm? Will all of these fit on a LS6 or should I bite the bullet and spend the $$$ for a FAST LS intake? Is the price difference worth it for the HP gain? Do the intakes support different sizes of throttle bodies? Can a used intake off a Camaro or Firebird be used on the Corvette? Just a bunch of newbie questions.... Sorry. Back in the day when I had my 67 Chevelle SS396, I didn't have to worry about all this stuff the way you do now. Seems a bit more complicated now with all of the computer stuff and tuning.
And the final question is regarding tuning. When to get it tuned? After the headers are installed, or wait for everything to be installed then do it? Should it be tuned multiple times? Thanks and I appreciate your patience. That was a stupid long post.
After each major mod, a new tune should be done.
So if you do LTs, exhaust and CAI, get it tuned.
then when you do the TB and Intake, get it tuned.
Tuning is a key to get the most out of any bolt on mods.
Good Luck
1. From your starting point, LT headers (with your CAI) and an aftermarket exhaust should give you about 345-350 rwhp and 340 ft/lbs of torque. Plan on spending $2,000 or more (depending primarily on the cost of the LT headers - which can run from $1,100 to $1,800 -or even more if you are buying an exhaust system) if you have someone else do this install. If you have your installer port your existing intake manifold and throttle body (rather than upgread them), you will accomplish roughly the same result, but save several hundred bucks. (I bought a Forum member's Z06 Ti exhaust for $350.)
2. Next step: upgrading your heads and swapping in a mild cam should net you about 410 rwhp and 400 lb/ft of torque. (Cam selection is key: if you later intend to add a blower, then be sure the cam you select is compatible with the blower; otherwise you might need to change out the cam (again) when you put in the blower). Plan on another $3000+ for the heads/cam install. Unless you live and drive in really cold weather, change out your thermostat (to, say, a 160 degree unit) at this same time. Also, adding in a 2800-to-3600 stall converter might be advisable at this time, or at the worst when doing the next step (#3 below). If so, that's an additional $1,000 or more. In any event, you'll want your tuner to also tune your A4 transmission -firmer shift points will complement the power gains you get from the engine mods.
3. If you ultimately determine to add a supercharger, then be sure the cam you select (in #2 above) is compatible with the blower. Otherwise, you would need to trade out the cam for one that maximizes your blower capabilities. If/when you add in the blower, be sure to also add a transmission cooler. A blower will cost you $6,500 to $7,500 installed.
In all events, follow AU N EGL's advice and get a dynotune (a) after the LT header install, and (b) preferably after each other major upgrade. If you use the same installer for all upgrades, he might give you a major $$$ break on the cost of the tunes.
Best regards,
The Lizzard
As just mentioned, a converter would likely give way more SOTP improvement compared to headers or an intake.
400rwhp to 450rwhp is a big target range. You might get close to 400rwhp without heads. Not 450rwhp though. But then I'd want to see at least 425rwhp with heads and a cam.
LS2
LS1 vs LS6 manifold:
LS1 with winged bottom:
LS6 FLAT BOTTOM:
I installed a home ported FAST90 and Home ported 90mm Throttle Body on my 02 ZO6. It has Patriot stage II heads, Comp 245-245, 610 lift at 114 lsa. With a professional tune, im in the 450HP range
NOTE! Once you pass the 400hp mark,, you will need to start beefing up the drive train!
Headers... You can find XS Power headers for LESS tham $900. I installed them in the drive way on jack stands on a C5 and C6. The C6 is a SNAP!
Any modification that you do that worth any good HP increase will or should be followed up with tuning! When you change that can,, your going to need new BIGGER injectors and they must be tuned in.
Save your cash, get as many mods together that you can easy afford. Example and my recommendation:
-Low cost headers OFF SHORE or used LT/SS Headers
-High flow Cats and and an X pipe
-LS6 /2001+ manifold (if you dont already have one)
-Ported TB
-VARARAM
-TUNE!!!!
With the above mods on my LS6, I was at 390 HP/375 Tq. The LS6 has better heads and a little bigger cam. You will easily be in the 350-360 HP range.
Just tuning the PCM will give you a very good SOTP performance gain with improved transmission shifting and shift timing!
BC
if you're looking to get off the line. A stall convertor will make the most difference on an automatic.
Here is a good DIY http://www.ls1howto.com/index.php?article=29
Headers http://forums.corvetteforum.com/c5-p...-shipping.html
I would suggest the Vararam for your intake. They perform
