Timing Chain guide
Old Apr 29, 2012 | 03:37 PM
Leukic's Avatar
Leukic
Default Timing Chain guide
When I started removing parts from my blown motor, i noticed it did not have the timing chain guide that bolts right above the crank. Is this plastic guide necessary? for the saftey of the chain?
Old Apr 29, 2012 | 03:38 PM
baxsom's Avatar
baxsom
some have them some dont.
Old Apr 29, 2012 | 03:55 PM
Leukic's Avatar
Leukic
But is it detrimental to have one? I don't think so, but im not an expert.
Old Apr 29, 2012 | 08:03 PM
lucky131969's Avatar
lucky131969
Why would having a chain damper be detrimental to the engine?
Old Apr 29, 2012 | 08:14 PM
Leukic's Avatar
Leukic
You answered no question, so I am not sure why you are posting.
Old Apr 29, 2012 | 08:38 PM
_r2h's Avatar
_r2h
Pretty standard for Lucky.
Old Apr 29, 2012 | 08:43 PM
Leukic's Avatar
Leukic
The shop that installed my cam package before hand must not have reinstalled it then, cause it was not there when i removed my cam from the old motor . Hence why i was asking if it is necessary to have it. I wold prefer to have it but if it is not needed then so be it.
Old Apr 29, 2012 | 08:46 PM
_r2h's Avatar
_r2h
Some motors have them, some don't. It's not necessary, but is more an "insurance".
Old Apr 29, 2012 | 09:07 PM
Leukic's Avatar
Leukic
thanks
Old Apr 29, 2012 | 09:17 PM
lucky131969
First of all, I posted because it is an open forum. Second, I was asking the question, because I could not understand why you thought having a chain damper would be detrimental (harmful in some way), or if you meant NOT having a chain damper would be harmful.
Old Apr 29, 2012 | 09:29 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you have the holed in the block for a damper,, your gifted! Most don't. If you have the holes, find a damper and install it!! It provides the chain stability and longevity.
The damper is a good thing!
BC
Old Apr 29, 2012 | 09:33 PM
Leukic's Avatar
Leukic
The way it is read, it implies that it is sarcastic in nature.
The motors come from the factory with the Timing chain guide, I was asking if it was needed, ( it guides the chain to the crank sprocket) Mine didn't have one. And detrimental was as in would there be chain slap from the chain not having a guide.
Bill would you happen to have a part number for that guide.
Old Apr 29, 2012 | 09:54 PM
lucky131969
Like Bill said, some were actually fortunate enough to have the block tapped for the damper(not all C5s had it). Some went the distance, and measured, drilled/tapped their blocks. If I recall correctly, the damper supply dried up a couple of years ago.
Old Apr 29, 2012 | 10:39 PM
Tourmgr1's Avatar
Tourmgr1
I picked up a couple of these dampers (NOS) from Katech when I rebuilt my engine last year. Give Jason a call he may have some left.
Good Luck
Old Apr 30, 2012 | 03:25 PM
Leukic's Avatar
Leukic
Good Luck
Just looked on katech site and found the guide holy cow $95 for a piece of plastic. That's kinda odd. I know it's discontinued but wow
To Timing Chain guide
