Remote Keyless Entry Problem
Old May 20, 2002 | 10:50 PM
MidlandZR1's Avatar
MidlandZR1
Default Remote Keyless Entry Problem
Hi!
Hopefully someone out there can help me with a weird problem I'm having.
Both of my key fobs have stopped working. I've checked their batteries and they are good.
The only thing I can figure is I disconnected the car battery ( actaully it went dead but that's another problem ) over the winter and now the keyless does not work.
Is there a re-porgramming necessary when the car battery is removed like with programmable radio stations? That's the only explanation I can think of.
As always, thanks in advance for any help!
JIM.
:mad
Old May 20, 2002 | 10:57 PM
Dale RED 98's Avatar
Dale RED 98
Default Re: Remote Keyless Entry Problem (MidlandZR1)
Turn the key to on and press the lock and unlock buttons at the same time. The horn will sound when it is reproggramed. :cheers:
[Modified by Dale RED 98, 9:58 PM 5/20/2002]
Old May 21, 2002 | 12:37 AM
MidlandZR1's Avatar
MidlandZR1
Default Re: Remote Keyless Entry Problem (Dale RED 98)
THANKS DALE !!!!!
I'LL TRY IT TOMORROW.
Old May 21, 2002 | 07:38 AM
Gunny's Avatar
Gunny
If that doesn't work, there's a more lengthy procedure to reprogram your fob using the options buttons on the C5. You can do a search here on the forum for "key fob" -- a few months ago I remember someone posted the how-to. (Basically, you press the options buttons until nothing appears on the DIC (kind of like a secret stealth operation) :jester and that puts you into reprogram mode. Need more help, just IM me.
Old May 21, 2002 | 10:15 AM
C5XTASY's Avatar
C5XTASY
Default Re: Remote Keyless Entry Problem (Gunny)
The advantage of this method id that you can tell the car which fob is #1 and which one is #2 for purposes of memory settings. If you don't have the memory function, or don't care which one is #1 or #2, as mentioned earlier, just hold the lock - unlock buttons down until the car recognizes it, and you're done.
Ed
To Remote Keyless Entry Problem
