Active Handling Warming Up?
Old May 2, 2012 | 06:28 PM
DBLTRGR's Avatar
DBLTRGR
Default Active Handling Warming Up?
I've gotten this message twice today, followed a couple minutes later by "Warm-up Complete". I've never seen this before. Anyone know what's up? Is this normal?
Old May 2, 2012 | 06:47 PM
chaase's Avatar
chaase
St. Jude Donor '12
It's normal if you get the complete message.
Old May 2, 2012 | 06:50 PM
65GGvert's Avatar
65GGvert
According to stories on the forum, if you turn the wheel immediately after starting the car, you'll get the message. Never saw it, but I've heard it several times here.
Old May 2, 2012 | 07:07 PM
Jet-Jock's Avatar
Jet-Jock
Usually I'll get the message say mid day leaving for lunch. It's nasty hot out too. A few times I've seen it in the winter months, but its rare.
It reminds me of the call bells from the cockpit.
I think it takes about 10-20 seconds and the complete message appears.
Old May 2, 2012 | 07:09 PM
DBLTRGR's Avatar
DBLTRGR
That's intetesting. This is my second C5 and I've never seen it before today. Both times I was pulling out from parking while turning the wheel, so that might be it. Thanks!
Old May 2, 2012 | 07:11 PM
Jet-Jock's Avatar
Jet-Jock
Yeah same here, pulling out of the parking lot at work at very low speed and some 90° turns.
Old May 2, 2012 | 07:19 PM
Chicago1's Avatar
Chicago1
Yup same exect thing I've had a few times with the same scenario.
Old May 2, 2012 | 10:53 PM
DBLTRGR's Avatar
DBLTRGR
Yep, I was in tight parking both times.
Old May 2, 2012 | 11:13 PM
fhturner's Avatar
fhturner
Upon startup, Active Handling needs to "calibrate" itself while you drive straight w/ no significant steering angle input. When you start off w/ these slow, tight maneuvers, the process cannot yet complete. You'll notice that once you straighten out and drive w/o turning for a little bit, the "Warm Up Complete" message will come up.
Fred
Old May 3, 2012 | 09:09 AM
DBLTRGR's Avatar
DBLTRGR
Well this is all a relief for me. I'm on an extended road trip (Montana, Idaho, eastern Oregon, Nevada, Utaha) and it was bothering me. The car sure gets a lots of looks and nice comments, especially in the small towns.
Old May 3, 2012 | 04:46 PM
tdlong98's Avatar
tdlong98
Mine comes on every time I back out of the garage and drive slow down my 1/4 mile drive way
Old May 3, 2012 | 05:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If your ALIGNMENT is significantly off (steering wheel not straight when your driving straight down the road) it can cause it to come on a lot more frequently
Like it was stated previously, unless the EBTCM has a chance to calibrate the signals from the Steering Wheel Position Sensor (SWPS),, You will see that message.
If it comes on and stays on, or if you get a DTC and messages, then that would be an issue.
BC
Old Jul 28, 2013 | 06:16 PM
mobius's Avatar
mobius
mine just started taking a long time to turn off like 15 min... my steering wheel is off a little hope that is it... no codes
Old Jul 28, 2013 | 07:20 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Get a four wheel alignment and MAKE SURE that they recenter the steering wheel and it centered when you drive straight down the road. If they don't recenter the steering wheel, you will nit resolve the issue.
BC
Old Jul 29, 2013 | 05:30 AM
Atok's Avatar
Atok
Mine does too. I drive no faster than 15km/h for about 1/2 mile when I leave home. Long dirt driveway. I get that message almost every time. It seems to be speed related as well. If I drive a little faster it sometimes does not pop up and if it does it goes away much quicker.
Old Jul 29, 2013 | 07:36 AM
AU N EGL's Avatar
AU N EGL
Start your car, let it warm up 30-60 sec, drive straight if possible for 25-50 feet.
If you cant drive straight, once you get your car straighten out, stop for 30 sec, then drive straight for 25-50 feet.
Letting it warm up for 30-60 secs before driving is a good idea.
Old Jul 29, 2013 | 07:45 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
From the Service Manual
Traction Control and Active Handling System Indicator(s)
ACT HNDLG-WARMING UP
The IPC illuminates the ACT HNDLG-WARMING UP indicator in the message center when the following occurs:
The active handling option needs to be present in order for this indicator to appear. The EBCM detects that the engine is on and the vehicle speed is at 6 mph (10 km/h) or below. The IPC receives a class 2 message from the EBCM. The DIC will display this message for 3.5 seconds and then turn off. A chime will sound will this message is displayed.
When this message is displayed the traction control and active handling system indicator turns on.
WARM UP COMPLETE
The active handling option needs to be present in order for this indicator to appear. The IPC illuminates the WARM UP COMPLETE indicator in the message center when the EBCM has completed the functional check of the active handling system. The IPC receives a class 2 message from the EBCM. The DIC will display this message for 3.5 seconds and then turn off. A chime will sound will this message is displayed.
To Active Handling Warming Up?
Old Jul 29, 2013 | 05:34 PM
mobius's Avatar
mobius
OK well the alignment did not fix it and the steering wheel is straight. any ideas what is next?
Old Jul 29, 2013 | 07:18 PM
chaase's Avatar
chaase
St. Jude Donor '12
Pull the codes and post.
Old Jul 29, 2013 | 07:52 PM
mobius's Avatar
mobius
No codes man. just takes forever for the active handling warming up to go away
