Emergency help please -- column life
Old May 25, 2012 | 06:25 PM
Mudd92's Avatar
Mudd92
Default Emergency help please -- column life
Well FML lol. Went to leave work for my 3 day weekend, fire the car up and my steering wheel is locked. I have not done the bypass, I dont know if the recall was done. And service column lock is activated.
Is there anything I can do to bypass it here? Can I ordered the harness they sell and fix it or does it HAVE to go to the dealer to be unlocked?
Thank you for any help.
Old May 25, 2012 | 06:30 PM
65GGvert's Avatar
65GGvert
From the top of the page where you posted, under "please read before you post"
http://forums.corvetteforum.com/c5-t...ky-please.html
Old May 25, 2012 | 06:33 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
To address your dire situation first, you can turn the ignition to the "on" position,and shake the wheel left and right, firmly, and the lock pin may disengage. IIRC, there's also a fuse that you can pull, and it will unpower the lock motor, but I don't remember which one it is. maybe someone will help out with that.
You can install a column lock bypass harness, but the bad news for you, is the column has to be in the unlocked position in order to do the install.
Good luck!!
Old May 25, 2012 | 08:24 PM
Purple92's Avatar
Purple92
Read through the sticky at the top of the page, and go to the Compliance Parts website. Supposedly agressive turning of the wheel and/or "tapping" the column lock motor will free it up more times than not, but get one flavor or another of the Column Lock Bypass and install it.
Old May 25, 2012 | 09:55 PM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Agree try to turn the wheel back and forth. Yours sounds like it had DID NOT HAVE the recal. If you get it free replace it as the factory did or it will do it again and not be so lucky.
Old May 26, 2012 | 01:58 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
CALL ME PM Sent
Old May 26, 2012 | 08:26 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Forum member 8VETTE7 is the resident expert on that system but Bill C knows a lot about it as well. Either can help you
Old May 26, 2012 | 09:36 AM
gotz06?'s Avatar
gotz06?
Old May 27, 2012 | 01:44 PM
Mudd92's Avatar
Mudd92
Bill has been amazing help. in the process of trying more things. Thanks everyone.
Old May 27, 2012 | 08:50 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
How did powering up the column lock motor do??
Bill
Old May 27, 2012 | 09:28 PM
Mudd92's Avatar
Mudd92
Didnt work out. Guess im going to try and replace it myself. Know of any write ups and is the lock a dealer only part?
Old May 29, 2012 | 01:37 PM
Mudd92's Avatar
Mudd92
I just wanted to say I got the stupid thing unlocked. I want to thank Bill here from the forums and richard at compliance parts.com Both of you guys were awesome help thank you so much. Bill, you had me doing the right thing on jumping the wires, but I ended up not having a solid connection so I grabbed a 12v batt from the shelf and went directly into the connector off the lock itself (unplugged from dash) and it worked perfect. Im ordering the LMC5 module now to keep the problem resolved.
Thanks again everyone.
Old May 29, 2012 | 03:49 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Glad that I was able to help! Anytime my friend!
Bill
To Emergency help please -- column life
