Clutch swap
Old Jun 21, 2012 | 02:38 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Default Clutch swap
I am changing my clutch this weekend with a Textralia with a Z06 flywheel and wanted some input on a few things. I have bolts for the clutch to flywheel but did not get new bolts to attach the flywheel, can I use the old bolts? If not what is a reputable brand to get? Also I changed my slave cyl about 6 months ago with a new OEM from the dealer, should I swap for a aftermarket or will the one I have be ok? I have read about slave cyl being replaced and then a few months later failing, so what are some things I can look at when I have it off to indicate time for a new one.
Old Jun 21, 2012 | 02:53 PM
bumble-z's Avatar
bumble-z
Even though your slave is only six or so months old, I'd put a spanking brand new one in, along with a new pilot.
I'd get a hold of the manufacturer of your clutch/pressure plate & flywheel to get the correct answer on the proper bolts to use.
Hopefully you have a steel splined adjustment tool for the clutch disc.
Old Jun 21, 2012 | 03:06 PM
BigGun's Avatar
BigGun
FWIW....
http://forums.corvetteforum.com/c5-t...h-install.html
Old Jun 21, 2012 | 06:13 PM
cdkcorvette7's Avatar
cdkcorvette7
I like ARP bolts personally. I would not use the old ones.
May as well do the new slave and pilot bearing given the amount of work involved. OEM slave should be fine. It's the OEM master that is lacking for some applications.
Check your torque tube couplers for wear while you have everything apart and replace them if worn.
You might consider putting a remote bleeder line on your slave so you can bleed the clutch properly from time to time. I used the tick remote bleeder on mine and had no issues.
Did you buy the clutch and flywheel as a kit from a vendor? If so ask them if they were balanced. If not you should have them balanced to avoid issues. See the link in the above post.
Since you're going with an aftermarket unit you should check to make sure the clutch is fully disengaging once you've got everything installed. The stock master cylinder does not displace a sufficient amount of fluid for some (not all) aftermarket clutches to fully disengage so it's worth checking. Park your car on a flat surface and hold the clutch and the brake pedal down. Bring your engine up to 2500 rpms and release the brake pedal but leave the clutch pedal all the way in. If the car moves forward at all your clutch is not fully disengaging.
Old Jun 22, 2012 | 06:16 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Thanks for the info, I have a tick installed already and I changed the TT couplers when I was changing the slave out before. I did not buy the clutch from a vendor I bought it off a forum member. He put 1000 or so miles on it and then scrapped the car. the flywheel was off his Z06 he had them balanced so should I still get it balanced?
Old Jun 22, 2012 | 07:52 AM
lucky131969's Avatar
lucky131969
Why? The service manual does not call for replacement. ARP bolts can interfere with some pressure plates, so they are not a good suggestion for all. There is nothing wrong with reusing the factory flywheel bolts, provided you use loctite.
Old Jun 22, 2012 | 11:55 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I reused mine without any issues.
Here are some LESSONS LEARNED that I hope you heed. I just did all this successfully. I spent too many hours reading post after post after post trying to sort the truth from the wives tails.
Some facts:
IF,,,,,,,,,,,,,,, you do NOT have drive train vibrations NOW with your current set up,,,,, have your new fly wheel MATCHED BALANCED to the old one!!!
REPLACE THE PILOT BRG!!!!
Highly recommend installing a remote bleeder!!!
IMPORTANT!!!!
Spend extra the couple hours that it takes and take the critical SLAVE CYLINDER/THROWOUT BEARING to PRESSURE PLATE clearance measurements to determine if you need a shim or not to acheive the correct clutch release clearances!!!!!!!!!!!!!
Read and implement the extra cooling mods that this post discusses:
http://forums.corvetteforum.com/c6-t...post1581134673
Hope this helps!
BC
Old Jun 22, 2012 | 12:19 PM
cdkcorvette7
Honestly it's because I've always had good experience with ARP fasteners. Don't have a mechanical engineering degree to back it up though
As to not reusing the factory ones; I've always looked at new bolts as CHEAP insurance. I'd rather spend a few $ on new bolts for a job this involved than take even a .00001% chance that the flywheel could turn itself into a rudimentary circular saw at 6K RPMs. I also thought I read in the service manual during my last clutch job that new flywheel bolts were called for but evidently I am mistaken.
Old Jun 22, 2012 | 12:32 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Some facts:
IMPORTANT!!!!
Hope this helps!
BC
Thanks Bill I am convinced I have vibrations currently from my stock clutch or TTbushing or could be a wheel, but not sure which one. I have been in the same boat spending hours looking at different threads to see which is more credible. But if i have vibration now from the stock one what should I balance the new one to? I just picked up a bearing from dealer, and plan on putting remote bleeder back on. Are the measurments for the slave to pressure plate measurments in the service manual?
Old Jun 22, 2012 | 12:44 PM
bumble-z's Avatar
bumble-z
c5vette211, You mentioned you have a Tick M/C installed.
If you go to their site, you will see where they sell a shim package.
They have a diagram of proper spacing of the slave to p/plate measurements.
It shows the distances to determain which size shim you may need (if any).
Hope this may help.
It wouldn't hurt to have them already ordered & in your possession prior to the install.
Old Jun 22, 2012 | 02:09 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Hope this may help.
Nice THANKS!!! I will not be doing the install this weekend after my balancing road block I have hit. I am trying to figure out now how to deal with my situation. I have found a shop that will balance my new flywheel with the new clutch, but I read if my current flywheel is weighted then I need the new flywheel matched to the old but the shop I found will not match the old to the new just the new flywheel to the clutch. How can I determine if my old clutch is weighted without tearing too far into the car?
Old Jun 22, 2012 | 02:27 PM
cdkcorvette7
Gotta take a look; there's no other way to know.
I didn't have any weights on my flywheel (and chances are you don't either) so I don't know from experience but I think you could just have the new clutch and flywheel balanced together then just transfer the weights from the old flywheel to the new.
Old Jun 22, 2012 | 02:38 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
This is what conclution I came to. This way i can avoid taking apart multiple times.
Old Jun 22, 2012 | 02:41 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
The APR are $10 less with TICK than the ones from the dealer
Old Jun 22, 2012 | 03:40 PM
cdkcorvette7
Make sure you get the weights (if you have any) in the same position(s) on the new flywheel.
Old Jun 22, 2012 | 03:59 PM
lucky131969
Nothing wrong with ARP bolts, except that the heads do interfere with some pressure plates.
Old Jun 22, 2012 | 04:07 PM
cdkcorvette7
I actually hadn't heard that so thanks for the info. I'll be sure to check before my next swap... If I hadn't known this I probably would have just done it without checking.
To Clutch swap
Old Jun 23, 2012 | 12:03 AM
Arnie Chamberlain's Avatar
Arnie Chamberlain
ARP bolts are $29 from Amazon. I can spend that in an hour in a tavern. Go with the ARPs and sleep well.
Old Jun 23, 2012 | 01:02 AM
BOUT X's Avatar
BOUT X
Corvette Cowboy
Hello OP everything Bill said I would do, I just did mine and I had issues with my pilot shaft make sure it is in good shape and not worn out. The dim. for the end of the shaft is .591 +.000 - .01 if it is smaller or worn I would get it fixed I can do it for you for a cost here is a link to my thread of how I fixed it.
http://forums.corvetteforum.com/nort...be-help-2.html
if have any questions feel free to contact me also is your shaft in the T.T. Bent have it check also
Dale
Old Jun 23, 2012 | 10:26 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Dale
Thanks for the dims on that and I will be in touch if I need help with the shaft.
