Pull Key, Wait 10 seconds.
Old May 26, 2002 | 11:43 PM
quenchmasterc5's Avatar
quenchmasterc5
Default Pull Key, Wait 10 seconds.
I just completed the Column Lock bypass from C5Solutions. Worked perfect. Instructions were to the T. Took me 35 minutes including coffee break and vacuum out when finished. My problem now is the Pull Key, wait 10 seconds code. Happens almost every time. Anybody have any suggestions.
AL
Old May 27, 2002 | 02:18 AM
CORVETTE FOREVER's Avatar
CORVETTE FOREVER
Default Re: Pull Key, Wait 10 seconds. (quenchmasterc5)
I have the CLB too,and I occasionaly still get the Pull Key,Wait 10 Seconds message
Old May 27, 2002 | 07:33 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Pull Key, Wait 10 seconds. (CORVETTE FOREVER)
Never had an error message since I installed CLB over a year and a half ago... :)
Old May 27, 2002 | 02:57 PM
mozin's Avatar
mozin
I still sometimes get the warning message and my car has the CLB. Contact C5 Solutions and they will steer you straight.
Old May 27, 2002 | 08:16 PM
Kent1999's Avatar
Kent1999
Welcome to my world. :(
I was given a new CLB unit in exchange, but it still had the same problem.
I was told that the only other solution is to get a refund, or to replace the BCM ($1200+).
The bad thing about it is that it seems to be getting worse! I used to get the "pull key..." message just after I turned the key to "on", but now sometimes I don't get the message until the car starts to move (which is REALLY aggravating!)
So my choices are to put up with it, or risk getting a locked column at the worst possible moment. (No, my car is not covered by the recall)
Old May 28, 2002 | 12:19 PM
blackjack's Avatar
blackjack
Default Re: Pull Key, Wait 10 seconds. (Kent1999)
You will sometimes get that error because the key sensor gets stuck. Inside the ignition switch there is a sliding nylon key sensor that gets stuck and fools your car. It thinks that there is a key in the ignition with a non-compatible resistor pellet so it throws that message. The best way to tell if this is your problem is if the bell rings with the door open without a key in the ignition. If this happens, insert the small end of a plastic wire tie into the ignition switch and "fiddle around" until the sensor releases. There is a TSB out to update your ignition switch.
-Blackjack :flag
Old May 28, 2002 | 12:35 PM
JS2 FST's Avatar
JS2 FST
Default Re: Pull Key, Wait 10 seconds. (blackjack)
We have not done the upgrade yet and my car did this last week. Does this mean I need to do the upgrade before I have problems?
Old May 28, 2002 | 05:15 PM
mozin's Avatar
mozin
-Blackjack :flag
I looked but could not find a TSB for the ignition switch replacement on a 2001 C5. Perhaps my car already has the updated ingition switch?:confused:
Old May 28, 2002 | 06:45 PM
quenchmasterc5
Default Re: Pull Key, Wait 10 seconds. (JS2 FST)
What year C5 do you have. 97-00 I am pretty sure will experience this failure. I would go ahead and have the C5Solutions CLB installed. You can do it yourself in about 30-45 minutes with a T-15 screwdriver. C5solutions will provide detailed instructions with your purchase. Cost $72.00 including shipping and handling. Better safe than sorry. Good luck.
Old May 28, 2002 | 06:47 PM
quenchmasterc5
Default Re: Pull Key, Wait 10 seconds. (mozin)
Hey Mozin, I think your right. 01C5 has been fixed I think. If I see something to the contrary, I will let you know..
Old May 28, 2002 | 11:20 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I have the exact same problem as Kent1999 on my 98. C5 Solutions sent me another CLB and had the same problem. I disconnected the CLB but left it installed. Had the car for one year today.
Old May 28, 2002 | 11:47 PM
mozin's Avatar
mozin
quenchmasterc5,
Good news. :seeya
Old May 30, 2002 | 07:22 PM
quenchmasterc5
I reset the code athis morning ands it hasn't done since. Hopefully it will stay that way.
Thanks for all the inputs..
Old May 31, 2002 | 12:46 PM
lostsoulny's Avatar
lostsoulny
pull fuse 25 under passenger side footwall this will clear the code. also make sur ethe chip on your key is clean, and insert key and wait till the gages cycle before starting this seems to have done the trick for me. :seeya
Old May 31, 2002 | 01:10 PM
Tennis Bum's Avatar
Tennis Bum
Hey Al - I think you're pulling your key too much! :smash: Try what lostsoulny said. Good to hear from ya.
Bum
Old May 31, 2002 | 01:48 PM
NYtoCA's Avatar
NYtoCA
Default Re: Pull Key, Wait 10 seconds. (Tennis Bum)
I must say i have no idea what you guys are talking about because i've never experienced this....BUT if i do is there an instructional link somewhere that i can save juuuust in case?
Thanks,
Frank
Old Jun 11, 2002 | 07:30 PM
quenchmasterc5
Thanks Kent, it just started doing that now too.
AL
To Pull Key, Wait 10 seconds.
Old Jun 11, 2002 | 07:31 PM
quenchmasterc5
Thanks. I haven't heard the chime yet. So I think that is not it.
Old Jun 12, 2002 | 08:32 AM
Razrbak97's Avatar
Razrbak97
Hi neighbor! :seeya
I had the same problem with my CLB, got so frustrating that I just had the TSB fix done. Problem is, that on '97's, the "fix" only involves replacing the same defective parts (circuitry was different in '97, which also seems to be why that year is more prone to confusion with a CLB installed). If you have an early '98, that may be part of the problem (same parts). I still have my bypass, just in case, but I'm keeping my fingers crossed.
I'll keep my eyes peeled for ya' 'round Oviedo-ville. :D
Old Nov 12, 2012 | 11:49 AM
BOB95lt1's Avatar
BOB95lt1
5th Gear
Default C5CorvetteTSBpullkeywait10seconds
Has anybody heard that the column lock motor after a while over draws amperage and burns up the harness of the CLB? Sounds crazy to me but the Tec at the Chevy dealership told me that about my 2003 Corvette.
BBsVette
