Random stalling issue
Old Aug 8, 2012 | 09:36 PM
Qwik01's Avatar
Qwik01
Default Random stalling issue
For a few months now every so often when I first crank up my car after I have drove it about an hour prior the engine cuts off once I give it gas and begin to ease off the clutch. It usually happens when I am on a slight incline. It's not a stall becuase am in not bogging the motor down. The engine simply is cutting off. I have to restart and try again about 10 times or so to finally get going down the road. Other than this only happening when the motor is heated up and on a slight incline is it never happens any other time. Once it gets moving the car is back to normal and will not do it again from any stop lights.
What would cause this odd behavior?
Old Aug 8, 2012 | 09:54 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
First,, read and post the DTCs that you have.
Next,,,,,,,, what MODS have you done and has the PCM been tuned?
Have you ever cleaned the TB or MAF??
Bill
Old Aug 8, 2012 | 10:45 PM
Qwik01's Avatar
Qwik01
Bill
I clean the MAF and TB every other oil change. The car has a brand new LS6 with roughly 15k miles on it now. TPIS headers, high flow cats, ported TB, x-pipe, borla stingers, Taylor plug wires. The car has been tuned as well before it was ever turned over. But the car does idle and drive perfect. Just this wierd random issue happens every once in a while. I will check for codes tomorrow but it isn;t throwing a CEL.
Old Aug 8, 2012 | 11:08 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hmmmmmmmmmmmmmmmmmmmm,,,, IF, you dont see any DTCs,,,,,, the PCM is happy. It may very well be just shutting OFF. That leads me to the IGNITION SWITCH.
How many TOTAL miles are on the chassis??
BC
Old Aug 9, 2012 | 12:35 AM
Qwik01's Avatar
Qwik01
BC
108,000 miles. I do notice time to time as well that there is a hesitation in the car starting.
Old Aug 17, 2012 | 11:25 PM
Qwik01's Avatar
Qwik01
I took a video of it this morning while leaving. Im not sure why the security light was staying on but it shut off every time until I locked and unlocked the car.
http://www.youtube.com/watch?v=xLic9y8pA1c&feature=plcp
Old Aug 18, 2012 | 12:18 AM
tom01ss's Avatar
0tom01ss
Former Vendor
bcm issue
Old Aug 18, 2012 | 12:47 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Try cleaning you key or try the spare key---The anti theft system may be licking in--These keys have an OHM reisitor built into the key-- Also--when it dies--does it stumble /idle hunt breifly then die ? OR does it shut off quickly ??
Old Aug 18, 2012 | 07:49 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You have a theft deterrent issue. Its doing the 2MPH fuel cut off. The security light should NOT be on and when it was on in the Vid, the car stalled when you tried to roll forward.
When the light was OFF,, the stall issue no longer was an issue.
Sounded like you locked and unlocked the car with the FOB. When you did that,, the security light went out and was NOT on as you drove away.
You have a problem with something causing the theft deterrent system to remain ON when it should be OFF.
Bill
Old Aug 19, 2012 | 12:35 AM
Qwik01's Avatar
Qwik01
Bill
Yes, I did use the fob becuase I noticed at the time that the light was lit and thought maybe arming and disarming the car would make it go out. What could be causing this? I am now looking for this light all the time when I drive..... But I do remember driving a few times in the past with this light lit on the dash and was lit with me driving down the road. I hope this issue doesn't happen to pop up when I am crossing and intersection...
Old Aug 19, 2012 | 09:24 AM
Dream C5's Avatar
Dream C5
Have Frost increase the 2mph fuel cutoff to a higher number like 200mph if he didnt do so when u got a tune. Wont solve the security light but will stop the stumbling.
Old Aug 19, 2012 | 09:49 AM
CactusCat's Avatar
CactusCat
You know, it just pisses me off when I get to 200mph and my car shuts off ! Dang it !!
Let's go ahead and make it 250mph, I hardly ever get that fast.....
Last edited by CactusCat; Aug 19, 2012 at 02:14 PM. Reason: I put more thought into it.
Old Aug 19, 2012 | 11:15 AM
Qwik01's Avatar
Qwik01
Good thought, I may have to do that.
To Random stalling issue
