EBTCM No Comm.
Old Nov 15, 2012 | 05:34 PM
  #81
m88vet's Avatar
m88vet
From: LA from the 6th sept till the 10th sept california ( then New Zealand)
Originally Posted by 3boystoys
Bull
further quote from speedorepairguy
" by the way we have tested al over unit yes it is good "
Old Nov 15, 2012 | 05:39 PM
  #82
m88vet's Avatar
m88vet
Ok found some inconsistency with the light blue wire running from pin 10 on ecbm to pin E on the star connector 1 whilst doing a continuity check again.. does this wire run straight to the ecbm or does it have any junctions etc etc . Help!!
Old Nov 15, 2012 | 05:46 PM
  #83
m88vet's Avatar
m88vet
oh and if i replace the wire does it have to be the same thickness?
Old Nov 15, 2012 | 07:07 PM
  #84
m88vet's Avatar
m88vet
OK after studying the wiring schematics it seems there is a connection and possibly a solder joint . does anyone know where the connection is?
I Am now getting a reading on the pin 10 to pin E star bus of OL or open circuit. !!
bridged the connection with a temp solderderd wire which closed the poen circuit , turned on the ignition and still TCS NO COMM . what the hell is going on? apart from this issue every thing on the Vette is fine!!
would like to find the connection still !!
Old Nov 15, 2012 | 09:19 PM
  #85
m88vet's Avatar
m88vet
Am I OK to run a new wire from pin 10 ebtcm module to pin E on star connector 1? wasnt sure ......
Old Nov 15, 2012 | 09:48 PM
  #86
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The DIGITAL information for the EBTCM is not getting to the BCM or the data from the BCM is not getting to the EBTCM.
You either have an OPEN in the Serial Data wire between the EBTCM and the BCM or SHORT or both//
Disconnect the the BCM and the EBTCM.. Check the BCM and the EBTCM end for continuity. Should be zero ohms... Check both ends to GROUND Should be INFINITY
Post results
Old Nov 15, 2012 | 11:25 PM
  #87
m88vet's Avatar
m88vet
thanks bill , let me get this right. apart from the wire running from pin 10 ebtcm to pin E star connector( which is now new after a continuity check ) . what wire do i need to look at BCM to EBTCM ? or are there several? please tell me colour and location pin number etc.
Old Nov 15, 2012 | 11:32 PM
  #88
m88vet's Avatar
m88vet
bill, do you have the relevant schematics for your recommended procedure?
please post if you do!? thanks again ..........
Old Nov 16, 2012 | 12:36 PM
  #89
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
This will be the THIRD time Ive either posted or referenced this schematic.
THIS IS THE ONE..
HERE IT IS!!!
ITS ALL YOU NEED!
SUPER FRIDAY SALE!!!!!!!
FREE FREE FREE!!
THREE FOR ONE SALE!!!!!
Old Nov 16, 2012 | 01:58 PM
  #90
m88vet's Avatar
m88vet
sorry bill I did not know you was going to post the same diagram! !
this in not my field of expertise as you can tell.....!
OK do i need to check the STAR to bcm PIN M#???? only this one??
am i looking for continuity ? any other wires i need to check??
sorry to sound so dumb......
Old Nov 16, 2012 | 06:34 PM
  #91
lionelhutz's Avatar
lionelhutz
It's a dark green wire that goes from the star connector 1 to the EBTCM. Disconnect the plugs on both ends then check it. Make sure the connectors on the ends are good and not damaged. Check the continuity and make sure it's connected end to end. Check the wire to ground and make sure it's not grounded.
Old Nov 19, 2012 | 06:36 PM
  #92
m88vet's Avatar
m88vet
Ok thanks , will check and report back!
Old Nov 20, 2012 | 06:23 PM
  #93
m88vet's Avatar
m88vet
hi please confirm dark green and not light green from bcm to ebtcm?
Old Nov 20, 2012 | 07:49 PM
  #94
lionelhutz's Avatar
lionelhutz
I looked at the wrong line. Appears to be light blue.
Old Nov 20, 2012 | 08:01 PM
  #95
m88vet's Avatar
m88vet
OK thanks , the light blue wire you mention i have renewed from pin 10 ebtcm to pin E star connector 1.
i did ask bill for a BCM wiring diagram . but i am sure his patience is wearing thin!!
Old Nov 20, 2012 | 08:03 PM
  #96
m88vet's Avatar
m88vet
he mentions Check BCM to EBTCM but is have 3 plugs and lots of wires.... i guess it must be 1 wire from bcm ( not star 1 ) to ebcm .. help!!
Old Nov 20, 2012 | 08:07 PM
  #97
lionelhutz's Avatar
lionelhutz
Look at post 16. Lt blue wire from star connector 1 to EBTCM....
To EBTCM No Comm.
Old Nov 20, 2012 | 08:11 PM
  #98
m88vet's Avatar
m88vet
Post results
bill which wire do i need to check specifically? (BCM TO EBTCM) star 1 pin E to pin 10 ebcm is new. thanks for your patience
Old Nov 20, 2012 | 08:14 PM
  #99
m88vet's Avatar
m88vet
thanks for reply... i renewed that wire( light blue ) EBCM to Star 1 ....
Old Nov 23, 2012 | 05:23 PM
  #100
m88vet's Avatar
m88vet
TRUST ME!! The ABS FIXER people can NOT fix an internal module logic issue. If you are POSITIVE that you have power to the module and the module is correctly grounded, a NO COMMS issues is caused by one of theses issues:
1. The serial data buss has an issue that is being caused the EBTCM or another module. The modules with the most issues are the LDCM, RDCM and the Seat Control Module SCM. Simply disconnect the STAR 2 Connector shorting buss (on top of the connector) and that will ISOLATE those three modules from the rest of the modules.
2. Plain and simple,,, The module has power and ground but, ITS TOAST!
3. Disconnect STAR 1 and STAR 2 connectors and read each module serial data terminal to chassis ground. If one of the readings is out to lunch, that module is likely the issue.
For the C5 to operate, you really only need the BCM and the PCM.
If you disconnect star 1 & 2 connector shorting busses AND JUMPER WIRE PINS "B" & "M" together the engine will start and run just fine.
If you jumper B, M & "E",,,,,,,,,,,, all the other modules will be out of the circuit and if the EBTCM is working, the NO COMMS issue should NOT be an issue any longer.
If its still an issue, you have an issue internal to the module or with the wire to the STAR CONNECTOR! Do a continuity check from the EBTCM connector " PIN #10 " to star connector #1 Pin "E"
BC
I looked at the schematics on the GM spo dvd ( installed at last ) and it seems its not pin 10 on the ecbm its pin 21 !!
i was looking at the wrong wire !!
