EBTCM No Comm.
Old Nov 5, 2012 | 08:03 PM
  #61
m88vet's Avatar
m88vet
From: LA from the 6th sept till the 10th sept california ( then New Zealand)
hey bill , you say to try this....
"3. Disconnect STAR 1 and STAR 2 connectors and read each module serial data terminal to chassis ground. If one of the readings is out to lunch, that module is likely the issue."
can you tell me what readings i should expect to get to chassis ground?
should they all be the same?
am i testing resistance? or continuity? my OHM readings dont seem to register on my meter. help...
Old Nov 5, 2012 | 08:51 PM
  #62
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your voltage/s look OK but still dropped down on the ignition circuit. The module cut off voltage is close to 9 VDC but,, just because the voltage is good today, doesn't mean it will not be bad on the next ignition cycle.
When you get the module back, install it and do the measurements again.
BC
Old Nov 5, 2012 | 10:45 PM
  #63
m88vet's Avatar
m88vet
thanks , yes got module back today. plugged it in and No joy.
bill can you clarify my last post re star 1 and 2 ?
also what do you think of my PCM and BCM codes that i posted earlier on in this thread? could this be the problem?
i will test voltage again with the module installed.
Old Nov 5, 2012 | 11:01 PM
  #64
m88vet's Avatar
m88vet
ok tested with module on and plugged in. battery voltage on terminals 12.2v
Pin B ignition on plugged into module 11.92 volts.
Old Nov 6, 2012 | 03:01 PM
  #65
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,, 11.92 VDC isnt the end of the world. Should be enough to make the module happy. If you want it closer to true battery voltage,,, you will have to repair or replace your ignition switch. I really dont think that will resolve the issue but, you could run a wire directly from the battery POS terminal to the ignition supplied contact and see..
Bill
Old Nov 6, 2012 | 04:31 PM
  #66
m88vet's Avatar
m88vet
OK bill tried that and still no luck..... i hope the speedoguy was 100% honest with me and it did not have a fault....
Does the EBTCM rely on the PCM to come to life or??? or can it have basic function without communication with it? i do have those pcm codes .....
any other ideas??
Old Nov 6, 2012 | 05:31 PM
  #67
lionelhutz's Avatar
lionelhutz
What did you use as the ground when doing those measurements?
Old Nov 6, 2012 | 06:29 PM
  #68
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Unless those guys have rigged up some sort of fancy test gear,,, I DO NOT see any way for them to test anything.
IMHO, all that they do is inspect the boards solder joints, resolder any that look bad, repair any circuit board traces that look bad and replace the power relay.
The ABS guy says that he adds a special power surge suppressor but, I have never seen it in person.
NONE of them (NONE) can repair any thing but a power related DTC issue. If they have spare modules, they can replace broken hard parts that are soldered to the board.
If the microprocessor has an issue,,,,, Stick a fork in it,, ITS DONE!!
I'm not sure of your meter reading skills and the ability to properly probe for the correct info. If it were me,,,,,,,,,,,,,,,,,,,,, I would disassemble the main EBTCM connector, look for damaged wires, examine EACH pin and insert a male pin in each female pin and insure that each female pin wasn't spread and make positive that all my basic module power and grounds were 100%.
Once you do that,, it has to be the module. You can get a O scope and read the output of the module and see if theres a digital signal there but thats reaching deeeeep.
BC
Old Nov 6, 2012 | 06:37 PM
  #69
m88vet's Avatar
m88vet
i used pin G on the connector and also used a chassis ground..
Old Nov 6, 2012 | 06:39 PM
  #70
m88vet's Avatar
m88vet
BC
yeah i do have my doubts....... not a good service if that is the case.... i will try find another corvette owner and plug my module into his or visa versa........
Old Nov 10, 2012 | 10:38 PM
  #71
m88vet's Avatar
m88vet
ok, what does ebtcm need to come to life? in other words what wires ( input and output ) does it need to no show a NO COMM ?
does it need just pin A B + and F and G- on the connector? which wires does it need for basic function on the serial side of things?
thanks again.......
Old Nov 10, 2012 | 11:09 PM
  #72
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
thanks again.......
The EBTCM doesn't tell you that it has NO COMM... Other modules do. The modules look for something called State Of Health messages If a module doesn't send one out. The BCM will report it NO COMM.
You can actually read the Serial Data line for that module with an O Scope and see if there is any output.
If your EBTCM actually has all the power inputs and the proper Grounds,,, it should work.
Your are going to need to be HANDY with the electronic surgical tools (meters and schematics) to make a proper diagnosis.
Bill
Old Nov 11, 2012 | 03:41 AM
  #73
m88vet's Avatar
m88vet
thanks bill. hoping later this week to try a 2001 vettes module on mine or visa versa... i will report back with my findings .... if i need a new or replacement module can you recommend a source? thanks ...
Old Nov 11, 2012 | 10:20 AM
  #74
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I normally get all my GM ONLY parts from Gene or Patrick at Gm Parts House. www.gmpartshouse.com
Give them a call and see what kind of deal you can get.
Bill
Old Nov 11, 2012 | 06:11 PM
  #75
m88vet's Avatar
m88vet
Bill
thanks bill , can you tell me which wire sends the signal from the EBTCM to the BCM? color? thanks in advance ....
Old Nov 11, 2012 | 07:18 PM
  #76
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You already have that info... Go back and look at post 16..
Star connector 1 pin E
Old Nov 15, 2012 | 02:03 AM
  #77
m88vet's Avatar
m88vet
OK ...are we out of ideas here? Is the culprit still the EBCM module? I have asked David Ruberg ( speedoguy ) how he tested the module to confirm it works 100% !! i hope to hear from him soon.....
i will copy and paste his reply here ...
My money is still on the EBCM. What else could it be?
still getting codes as follows:
40 BCM B0502 HC
40 BCM B0507 HC
10 PCM PO650 C
10 PCM P1571 HC
58 SDM U1040 HC
To EBTCM No Comm.
Old Nov 15, 2012 | 03:46 PM
  #78
m88vet's Avatar
m88vet
ttt .....
Old Nov 15, 2012 | 03:52 PM
  #79
m88vet's Avatar
m88vet
OK here is David ruberg's reply when asked how does he test the ebcm modules
" hi we test all the stuff on tester that preform all test and fuctions of unit dr "
Old Nov 15, 2012 | 04:12 PM
  #80
3boystoys's Avatar
3boystoys
Bull
