EBTCM No Comm.
Old Aug 10, 2012 | 12:41 PM
The Highlander's Avatar
The Highlander
Default EBTCM No Comm.
So... I had the car sit for a month... Battery dies, and when I recharged... You guessed it... ABS and TCS lights come on.
2002 Z06.
Checked the codes, no communication from TCS module..
Checked wiring... it has 3 pos (all ok) and 2 grounds (all ok)...
Fuses are ok...
Any thoughts or is the ABS module fried?
Thanks a bunch
Old Aug 11, 2012 | 10:48 AM
Dave68's Avatar
Dave68
I really doubt that it would "fry" when just sitting there. Try unplugging and plugging relevant connectors a few times and reset the error code(s).
Old Oct 3, 2012 | 04:10 PM
m88vet's Avatar
m88vet
From: LA from the 6th sept till the 10th sept california ( then New Zealand)
hi, was your problem resolved?? i have the same problem. TCS no comms
checked fuses all ok with correct battery voltage. checked ebtcm voltage and ground at the plug and seem to be ok . took the ebtcm off and soldered where it looked bad...
any other ideas??
car is a 2002 ZO6
where does the data line from the ebtcm run too? i would like to check the star connectors on the next module , can someone tell me???
thanks guys
Old Oct 3, 2012 | 04:52 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Any other weird DTCs at all???????????? Do your door functions work for BOTH doors???
Old Oct 3, 2012 | 10:19 PM
m88vet's Avatar
m88vet
bill , not sure if your reply to me or the post before. well here's hoping its me!! i am getting TCS NO COMMS.
58 sdm u1040 hc
bcm B0502 + B0507 hc
i will report back later with the PCM code i had , reset it now but will show once i go for a drive. Although i have now taken off the EBTCM ready to send away to ABSFIXER ( it the module is the problem ?? )
getting 12 v at A and B on the ebtcm plug. ground or G looks ok on the meter.
any other ideas?? thanks for your help
Old Oct 3, 2012 | 10:51 PM
m88vet's Avatar
m88vet
hi bill is it true i should have battery voltage on pin D as well as A +B??
i do not have voltage on pin D of the connector on the EBTCM module..
help.. going ...
Old Oct 3, 2012 | 10:59 PM
lucky131969's Avatar
lucky131969
You should have the following:
1) Pin A - 12 volts at all times
2) Pin B - 12 volts key on
Old Oct 3, 2012 | 11:03 PM
m88vet's Avatar
m88vet
oh ok thats what i thought.. read PIN D in another thread!! OK I have power at A + B . does that mean the EBtcm module is dead? still TCS NO COMM ..!!!
Old Oct 3, 2012 | 11:11 PM
lucky131969
Possibly, but I think you should verify the serial data wire first. What is the resistance to ground on pins F & G ?
Old Oct 3, 2012 | 11:16 PM
m88vet's Avatar
m88vet
thanks for your help here... G IS 0.00 OHM
will check F now ..
Old Oct 3, 2012 | 11:18 PM
m88vet's Avatar
m88vet
F is 0.00 OHM....
Old Oct 3, 2012 | 11:30 PM
lucky131969
F is 0.00 OHM....
Doesn't get any better than that.
Old Oct 3, 2012 | 11:31 PM
m88vet's Avatar
m88vet
how do i check the data wires?? where do they run to ??
Old Oct 3, 2012 | 11:50 PM
m88vet's Avatar
m88vet
posted dtc's below.. bill
both doors operate /lock open windows up down with no issues at all ...
very frustrating that all the systems are bundled into one ...
Old Oct 4, 2012 | 12:22 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old Oct 4, 2012 | 12:26 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is the serial data buss. ALL the modules are SERIAL or connected together and if there is an issue somewhere on the data wire, it can effect other modules.
Old Oct 4, 2012 | 03:49 AM
m88vet's Avatar
m88vet
what is the best way to check them bill?? from the ebtcm module where do they go next? have you heard of or had experience of the data wires failing?? does this mean it may not be the ebtcm ?? could it be the pcm? or ? that's presuming the wires are all OK. or will it be the TCS EBTCM module? sorry to sound vague , just no sure what to do next...... i have the module off the car right now...
To EBTCM No Comm.
Old Oct 4, 2012 | 04:15 AM
The Highlander
Honestly.......
your abs is toast
contact
digitalguy_1@charter.net
he fixed it for me for $50!!!!!!!!!! Extremely quick turnaround.
Old Oct 4, 2012 | 01:06 PM
AngryTurtle's Avatar
AngryTurtle
if you search google for speedometerrepairguy. You will find his website.
This just happened to me on a 03 z06. I havent tested grounds and such yet. But im not hopeful.
Old Oct 4, 2012 | 02:37 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
TRUST ME!! The ABS FIXER people can NOT fix an internal module logic issue. If you are POSITIVE that you have power to the module and the module is correctly grounded, a NO COMMS issues is caused by one of theses issues:
1. The serial data buss has an issue that is being caused the EBTCM or another module. The modules with the most issues are the LDCM, RDCM and the Seat Control Module SCM. Simply disconnect the STAR 2 Connector shorting buss (on top of the connector) and that will ISOLATE those three modules from the rest of the modules.
2. Plain and simple,,, The module has power and ground but, ITS TOAST!
3. Disconnect STAR 1 and STAR 2 connectors and read each module serial data terminal to chassis ground. If one of the readings is out to lunch, that module is likely the issue.
For the C5 to operate, you really only need the BCM and the PCM.
If you disconnect star 1 & 2 connector shorting busses AND JUMPER WIRE PINS "B" & "M" together the engine will start and run just fine.
If you jumper B, M & "E",,,,,,,,,,,, all the other modules will be out of the circuit and if the EBTCM is working, the NO COMMS issue should NOT be an issue any longer.
If its still an issue, you have an issue internal to the module or with the wire to the STAR CONNECTOR! Do a continuity check from the EBTCM connector " PIN #10 " to star connector #1 Pin "E"
BC
