Bobbyt1
Old Aug 27, 2012 | 09:59 PM
BOBBYT1's Avatar
BOBBYT1
Default Bobbyt1
My ABS and ACTIVE HANDLING lights came on my 1999 coupe and the DIC said to service these items. I used the Forum before when I had a problem with my windshield wipers and the information and pictures were right on target to fix this problem.
Does anyone have someplace I should start? I'm not sure how concerned I should be or where I should go to have this problem checked. Any help would be appreciated very much.
Old Aug 27, 2012 | 10:37 PM
cdnguyred88's Avatar
cdnguyred88
Go here and post your codes:
http://www.stengel.net/diccodes.htm
Then we can help you, once we know what is wrong.
Old Aug 29, 2012 | 04:11 PM
BOBBYT1's Avatar
BOBBYT1
Default "service abs/traction control" message on dic
I checked the codes last night and got the following:
C1243,B2253,B2284 AND B0521.
I took it to work this morning and there were no warnings; everything seemed to be O.K.
After the codes were scrolled through automatically, the display showed a manual mode which did not show the code number, but just showed each category like "TCS---1 code" each time I pressed the option button. Is there a way to open up the code when it is on manual display?
I appreciate your taking the time to help me out with this problem.
Old Aug 29, 2012 | 05:30 PM
PUMP03's Avatar
PUMP03
Oldtimer
Go here and there is a pdf with everything you need to know about DTC codes
http://forums.corvetteforum.com/c5-t...odes-dtcs.html
Old Aug 30, 2012 | 10:22 AM
BOBBYT1's Avatar
BOBBYT1
Default Pulling codes
I will pull the codes again(this time, I'll have someone with me so I don't miss any!)
BTW, that video you sent is extremely helpful.
Old Aug 30, 2012 | 03:43 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You can also read about it.
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
You can read the DTCs while the engine is running. If you turn the engine OFF and then back ON, that can clear some DTCs that may be important with identifying a problem. One example is a Misfire DTC (p-0300) If the engine is shut down, the DTC will clear.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Aug 30, 2012 | 05:16 PM
BOBBYT1's Avatar
BOBBYT1
Bill,
this is very helpful.
I'm going to check the codes again and get better information to attach to this thread.
I really appreciate the number of users who have taken the time to walk me through this.
B.T.
Old Sep 10, 2012 | 12:43 PM
BOBBYT1's Avatar
BOBBYT1
Default Abs/active handling warning
Sorry for the delay in responding.
I rechecked the DTC codes and came up with the following:
T28TCS
C1243H
60IPC
B0521H
AOLDCM
B2284H
A1RDCM
B2253H
The warning has not come back on the DIC for about two weeks.....???
I'm wondering if it could be a bad ground?
Thanks for all the help.
Bob
To Bobbyt1
