winter storage
Old Sep 1, 2012 | 08:29 AM
pprice666's Avatar
pprice666
2nd Gear
Default winter storage
Need to store 97 corvette this winter in storage unit with no electricity. I live in northern Michigan where temp's can get down to minus 20!What all do I do to assure there is no damage.
Old Sep 1, 2012 | 09:03 AM
j84buick's Avatar
j84buick
Lot's of threads on this subject but for me I do an oil change, fresh gas and a full detail. Then I put on a battery tender and cover her up. For you since you don't have electricity you'll want to pull the battery and put some rodent precautions in place.
Old Sep 1, 2012 | 10:03 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Add some Sta-Bil to a full tank of fresh gas before driving to your storage unit.
Remove your battery, since there's no 120 volt power available, and top off the charge about once a month.
If your radio security is activated, either disable the code or make sure you have it written down somewhere!
Old Sep 1, 2012 | 11:03 AM
andrec10's Avatar
andrec10
Lots of dryer sheets in the car and in the engine bay! Rodents hate them!
Old Sep 2, 2012 | 08:24 PM
nyelectrify's Avatar
nyelectrify
I live in upstate ny also and will be storing it inside but with outdoor temps prevailing. I'm also concerned about the rodent problem. How many dryer sheets and anything else also that can be used???
Old Sep 2, 2012 | 09:01 PM
vettenuts's Avatar
vettenuts
Had a friend who used drier sheets, the mice used them for a nest under the fuel rail covers.
I put the car in a "Carbag" and set some traps inside the bag and around the outside as well. Car stays dry and no mice in many years thus far.
Link to: Carbag
Old Sep 3, 2012 | 12:30 AM
All good advice. Here are some files on winter storage that might give you some additional ideas.
File Type: doc
File Type: doc
File Type: doc
Old Sep 3, 2012 | 02:08 AM
FRITZM's Avatar
FRITZM
Default Winter Storage
You might try this.
http://www.amazon.com/Fresh-Cab-Rode...bxgy_lg_text_z
Old Sep 3, 2012 | 10:06 AM
98DC231's Avatar
98DC231
fill it with gas, park it and pull the battery.
its not complicated.
To winter storage
