Fuel filter
Old Sep 15, 2012 | 04:42 PM
Mastertvtech's Avatar
Mastertvtech
Late 03's and 04's are in the tank....So that won't be happening to mine anytime soon...I spent 20 minutes looking for it until I found a thread here about it.
Old Sep 15, 2012 | 09:24 PM
Coach62's Avatar
Coach62
St. Jude Donor '12
Damn, that sucks. I have an 04, and I noticed that when I get down around 1/4 tank my car acts like it's losing fuel pressure under hard left turns.
Old Sep 16, 2012 | 04:43 AM
soggysailor's Avatar
soggysailor
I wonder if most C5 owners realize how buried the fuel filter is. I just installed an X pipe and at that time took the opportunity to change mine.
I don't believe there is a quick EZ way to change it. If you have a lift....great. Then all you need to do is remove your exhaust system from manifold to cat back.
Old Sep 16, 2012 | 05:02 AM
bumble-z's Avatar
bumble-z
97 to early build 03's have an in line filter, towards the rear drivers side rail.
Late build 03's, started with the filter in the tank w/pump.
In line picture 0f 97-03
http://forums.corvetteforum.com/1547377681-post4.html
Post in regards to change out of filter on 97-03
http://forums.corvetteforum.com/1547377667-post3.html
Old Sep 16, 2012 | 03:33 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I know what you mean, as I just changed the one on my '01 yesterday. The filter didn't have that many miles on it, as I had changed it in '04, but the seal at the output side of the filter must have deteriorated, and it started to drip fuel...
Yes, having the car on a lift would make the job MUCH easier...too bad I don't have one!!
Old Oct 20, 2012 | 07:12 PM
beninchesapeake's Avatar
beninchesapeake
Okay friends, I'm gonna be stupid tonight and ask anyway. 2003 coupe, unbolted the cat back pipe to gain better access to my fuel filter. The two lines with the blue and green tabs came off easily, almost by accident. Problem is when I put the disconnect tool thing in the other end and tried to release that line it wouldn't come out. The old filter will spin on the line so I know it's not frozen up, it just wouldn't release. Any thoughts, helpful hints would be greatly appreciated. ]
Old Oct 20, 2012 | 07:20 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Release fuel pressure on the schrader valve on the fuel rail. PUSH IN on the filter and then insert the tool. Release the filter and it should pull off.
BC
Old Oct 20, 2012 | 07:31 PM
beninchesapeake
Thanks Bill, I did release the pressure just like you said in another post. LOL,,I printed your instructions before beginning. I see what you are saying and I will give it a go tomorrow. Gonna be hard to get both hands up there at once but I will need to find a way. Thanks again.
Ben
Old Oct 20, 2012 | 08:12 PM
81c3's Avatar
81c3
Its absolutely unnecsessary to rmove or unbolt any of the exhaust system to access the fuel filter.
Old Oct 21, 2012 | 02:58 AM
Tron Z's Avatar
Tron Z
Originally Posted by B747VET
It is interesting that in much of the automotive world there is a mentality of "If it ain't broke, don't fix it!"
Certainly in the racing world that doesn't really apply. Similarly, in the aviation world, it only applies to non-safety related items. Radios? Let them go till they fail.
Oil filters? Fuel filters? In aviation, these items get replaced on a preventative maintenance basis/philosophy. They are replaced long before there is any chance of such items negatively impacting the health of an engine.
I would propose that everyone consider approaching such replacements on the basis of "better safe than sorry." We have no idea of the quality of that component at the time of manufacture. Likewise, it only takes one gas station owner trying to cut corners to save his business for sediment issues to result in a major repair bill.
Along that line, how many of us have magnetic plugs in the engine, tranny, and differential? How about these new oil filter magnets? Cheapest engine insurance there is.
Part of the problem is that cars of recent manufacture are so damn reliable. Lots of people on the highways today do not remember changing ignition points, plugs, condenser, rotor and cap every 5k miles. Many techs have no idea what a dwell meter is, nor what it is used for. People routinely lease cars these days for 24 and 36 months and do absolutely nothing but put gas in them. Many of these "owners" know better, of course, but they are not about to spend money on a car that belongs to the bank. Besides, if something breaks, they aren't going to fall out of the sky. There will only be a slight inconvenience, while the dealer sends a rollback out to the scene of the crime. Surprisingly many cars tolerate this abuse pretty well, although I would not want to buy one second hand!
Most people that have competition, or collector cars know perfectly well what the real maintenance requirements are, regardless of what the manufacturers recommendations may state, because those recommendations are based on ideal operating conditions (which do not actually exist).
Old Oct 21, 2012 | 01:59 PM
bighank's Avatar
bighank
Default If you have LARGE HANDS it is NECESSARY to unbolt the left muffler
I played with my leaking mess for over an hour and couldn't get my large hands up to remove the nut holding the filter to the frame. Took out the 2 bolts holding the left muffler to the Y pipe, slid muffler to the right but didn't remove it and wished I had done that an hour ago.
If you are one of the 15 dwarfs that come out of a Volkswagon beetle at the circus you don't have to waste 5 minutes unbolting the muffler.
If not go for it.
Old Oct 21, 2012 | 03:44 PM
81c3's Avatar
81c3
If not go for it.
Perhaps it boils down to your tools and maybe your skill level. Im not a dwarf, nor am I Andre the Giant as you might be. Im a normal sized man with normal sized hands,so yea, it took me 20 minutes and I also cleaned behind the fuel filter with simple green all without removing any exhaust.More power to ya though...remove the body from the car if it helps you.
