2002 corvette rear main seal leaking
6th Gear
I have a 2002 Corvette with 141,000 miles on it and the rear main seal is leaking is it worth it to fix it with that many miles on the engine?
St. Jude Donor '13
Lets see......the LS engines go 300-400k miles plus as long as good full syn oil has been used, even beating the heck out of them (our C5 bracket racer we ran 200k miles 1/4 mile at a time and was still going strong when sold) so YES!!! These are not the engines our grandfathers drove that only went 70-100k miles before needing a rebuild. I tear some down with 150-200k miles and the original cross hatch hone marks are still visable with NO detectable wear ridge in the cylinders, crank and rod bearing look like new yet.
That or sell it to us for cheap....we will make good use of it!
The rear main and the rear cover seals are the ones prone to leak over time. Replace it and enjoy for another 100-200k miles.
while rebuilding my transmission i noticed the tale tale signs of rear main seal leaking so of course since everything was out i replaced it.
Had a corvette shop quote me $1000 to replace it so it is pricey if you dont do it yourself but well worth it!
Id pay 500$ all day long for a rear main. I have built my car myself, from the motor, suspension, aero, all of it, but all that work for a 10$ gasket pisses me off
from Rev Extreme's profile page:
www.revxtreme.com - (941) 721-1826
1614 20th St E.
Palmetto, FL 34221
Home of the RX Catch Can - Single, Dual & Monster Cans, RX Superchiller
LSx Performance Specialists, Full Fabrication Shop, EFI Tuning All Platforms
Diablosport CMR Custom Tuning for GM, Ford, & Dodge
Authorized Vendor: RX, VMax, ARH, ECS, Pfadt, Vortech/Paxton, Procharger, Diablosport - PM for Best Pricing!
1614 20th St E.
Palmetto, FL 34221
St. Jude Donor '13
Thanks 406!
It is not a super hard job....drop the torque tube and bellhousing is right there. A bit longer if the rear cover seal needs replaced.
We hire the good techs from Chevy that do this day in and day out and have it down pat.
i would pull the cam sensor and put a new o ring on it first before i do all that.oil puddles up obove the rear cover and leaks down the back.unless you can see oil dripping from seal through the inspection cover ijs
You guys will laugh at me and scoff at me, I don't care..LOL! My 2001 Blazer had a rear main seal leak, it was very minor,, I cleaned it up real good and I used JB Weld to seal it.. 3 years later, and no more oil leak. $6.99 total cost... Was it the right thing to do? Maybe not.. Did it work? Yes..
St. Jude Donor '13
In the 60's and 70's, we used what ever we could to keep our hotrods on the road as the budget was beyond tight back then.
It's alot of work for an oil leak, in the belly of the beast for sure. Low mile cars need it too, I changed mine about 20K miles. At least plan to do something else that's cool, while you're in there.
Received 2,061 Likes
If it's a manual car, I'd consider replacing the clutch since there's no extra labor
