Ported throttle body, is it worth it?
Old Jan 3, 2013 | 12:47 AM
yaknow's Avatar
yaknow
Default Ported throttle body, is it worth it?
From everything I've read, the stock throttle body is good to about 500 hp. According to my tunner I'm at around 485 to 500 hp at the crank. I have yet to have the car dyno test to be sure. In your opinion what benefit would I see from buying or having my throttle body ported?
Current mods to my 2000 FRC w/ 3.42 gears from front to back are
Cam and springs spec'ed by Patrick G at 500hp goal
vararam intake
160 degree thermostat
226/230 Comp Cam .598/.609 113LSA +3 advance
LS2 243 stock heads
TEA .660 dual springs
7.35 chrome spring rockers
LS2 Timing Chain
LS6 Oil Pump
LS7 Lifters
LS2 Lifter buckets
LS6 Intake Manifold
30#Ford Racing Injectors - 36# GM Equivalant
1 3/4 LT Headers w/ flow through cats and x pipe
SLP power flo exhaust
Old Jan 3, 2013 | 01:42 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When your at that HP/Tq level,,,, anything that you do will help. So,, YES.
In my honest opinion, you would SIGNIFICANTLY benifit from a ported FAST 90 and Ported LS2 TB. Then get a retune and see what you gain. I bet it will be 12-15 HP gain.
Old Jan 4, 2013 | 05:48 PM
Supercharged111's Avatar
Supercharged111
According to this, the ported TB is worth I don't know because my POS computer won't show the page. I think it was around 10hp though, all up top only. According to this, the FAST 92 is good for 13whp on a stock LS6 but again, all up top. Neither seem to cost any power down low, but I think you're past the point of bang for the buck mods. That and the gains seen above should be more significant on your engine.
Old Jan 4, 2013 | 06:36 PM
NukeC5's Avatar
NukeC5
Hell I gained 15whp on a stock internals LS1 with a FAST92 and ported LS2 TB. Thats going from an LS6 intake that was tuned for too. OP should see way better gains than me!
Old Jan 4, 2013 | 10:00 PM
yaknow's Avatar
yaknow
thanks for the additional reads.
Old Jan 5, 2013 | 01:13 PM
lionelhutz's Avatar
lionelhutz
FYI, there really is no such thing as X part being good for Y hp. It's possible the part can be successfully used to produce Y hp but that's not the same thing. Just because the part can be used in an engine producing Y hp doesn't mean that a better part couldn't be used to produce the same Y hp "easier".
In this case, the stock TB becomes more a restriction the more air you try to flow. The LS6 intake becomes more of a restriction the more air you try and flow too. I'd believe going bigger on both would show decent gains, especially at the top end. I'd think more like around 25-40hp could be possible with a FAST intake and bigger TB.
Old Jan 5, 2013 | 09:42 PM
yaknow's Avatar
yaknow
the more I read the more I'm convinced, If I want to gain any real horsepower, I need to go with a fast 90 w/ LS2 TB with my current mods.
Old Jan 7, 2013 | 01:22 AM
liquidforce917's Avatar
liquidforce917
regardless of what you decide as your choice of TB, I would have the porting done. In my experience with ported LS TB's, you only gain throttle response. No noticeable increase in HP due to the fact that ported or not the diameter of the TB will be the same.
Old Jan 7, 2013 | 09:16 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
}I want to gain any real horsepower, I need to go with a fast 90 w/ LS2 TB with my current mods.
You would spend over $1000 for 20-30hp?
Stop any mods and start saving for FI! You can find a used system for $3000-4000 and you can make 200hp more!
Old Jan 7, 2013 | 11:29 AM
AU N EGL's Avatar
AU N EGL
hmm may want to rethink the LS2 TB. there are far better ones out on the market.
Old Jan 8, 2013 | 10:47 PM
yaknow's Avatar
yaknow
part of the continuing search process
Old Jan 9, 2013 | 12:23 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
I was at your point and switched to a LS2 TB and FAST 102
I would also get rid of the 160 degree thermostat and put in a 180. It will make better power
Old Jan 9, 2013 | 12:15 PM
robert miller's Avatar
robert miller
But if you go the other way a few more hp here and a few there will someday add up to a bigger number.Robert
Old Jan 11, 2013 | 11:01 PM
yaknow's Avatar
yaknow
what were your before and after numbers?
To Ported throttle body, is it worth it?
