Took out MAF screen!
Old Jun 27, 2002 | 12:22 PM
  #61
primetime's Avatar
primetime
Default Re: Took out MAF screen! (Fast one)
Excuse my stupidity please..But what is meant by ..."surging"....sound? feel?? :crazy:
Old Jun 27, 2002 | 12:26 PM
  #62
primetime's Avatar
primetime
Default Re: Took out MAF screen! (primetime)
Also....Is Breathless Perf. MAF with the air foil in it a good way to go instead of just cutting out the screen??? :cheers:
Old Jun 27, 2002 | 12:40 PM
  #63
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
It gives you a larger diameter, and no need to cut screen.
Old Jun 27, 2002 | 12:43 PM
  #64
C54CSTER's Avatar
C54CSTER
What do you guys think about doing this mod on my '01 Z-06 with a Halltech T1? The T1, or Sidewinder, has that curved elbow that leads right up to the MAF. Do you think that if I go ahead and remove the screen I might have some issues with the airflow being too turbulent for the MAF to read? Thanks. :cheers:
Old Jun 27, 2002 | 12:48 PM
  #65
HP-GURU's Avatar
HP-GURU
Default Re: Took out MAF screen! (C54CSTER)
If you remove the screen and gain 5HP, you have changed your MAF readings. Who is to say that if you artificially change your MAF reading some other way ( Maf Translator, perhaps ), to read the same as a descreened MAF that you won't have similar gains.
What I'm trying to get around to, is the largest bottlenecks in the induction system are the:
Heads and the Air box. The rest of the stuff mostly provides you a warm fuzzy to know you aren't stock.
Old Jun 27, 2002 | 12:55 PM
  #66
kewlbrz's Avatar
kewlbrz
Given the T1 and the curves, you may get some unwanted turbulance.
Old Jun 27, 2002 | 12:58 PM
  #67
C54CSTER's Avatar
C54CSTER
Default Re: Took out MAF screen! (kewlbrz)
Thanks Kewlbrz. :cool:
Old Jun 27, 2002 | 01:02 PM
  #68
kewlbrz's Avatar
kewlbrz
Default Re: Took out MAF screen! (HP-GURU)
Dennis, I know where your trying to come from in that if you are getting more flow through the maf than its calibrated for, then you in essense create a lean condition. ( I dont think turbulance is an issue unless you have a unique air system, say like the halltech). The O2 sensors pick this up, and add positive increases to the fuel trims to compensate. In essense the engine perceives a lesser load, yet it is getting the air it needs, and timing will increase somewhat. Thus giving some power, (up to possible KR). However, at high RPM, I think there is some peak power to be gained without the screen. Its both the increase in timing, and the increase in flow that is benneficial. I've seen the bone stock LS1 heads good to ~400rwhp.
[Modified by kewlbrz, 11:05 AM 6/27/2002]
Old Jun 27, 2002 | 01:06 PM
  #69
Hokie's Avatar
Hokie
I took mine out in my 02 and my neighbor took his out at the same time in his 98. No problems and very easy to do. Just be careful not to mess up the small wires. I'm glad I took out mine.
Old Jun 27, 2002 | 01:58 PM
  #70
RyanC7's Avatar
RyanC7
Default Re: Took out MAF screen! (Hokie)
..........But do you have any mods like Headers and exhaust filter etc.. on your 02?
Old Jun 27, 2002 | 06:34 PM
  #71
BobbyD's Avatar
BobbyD
Default Re: Took out MAF screen! (Ryan2002C5)
Any warranty issues if there are problems down the line and you have cut out your MAF in your 2002?
Old Jun 27, 2002 | 07:03 PM
  #72
kewlbrz's Avatar
kewlbrz
Default Re: Took out MAF screen! (BobbyD)
Anything is possible with the ding-dongs at a dealership. But I cannot fathom a circumstance where they would lay blame to the screen being removed.
Old Jun 27, 2002 | 07:27 PM
  #73
Mike Mercury's Avatar
Mike Mercury
Agreed. Plus, how many dealer mechanics have full knowledge of the difference between the two... to where they would even realize that one model Corvette should have the screen, and another model should not.
Unless you tell them :nono:
Old Jun 27, 2002 | 09:33 PM
  #74
fxrhm's Avatar
fxrhm
Default Re: Took out MAF screen! (Mike Mercury)
Anyone do this on an '00 or older with the LS1 intake manifold changed to the LS6? I imagine it would be good. My only problem is I also have the Powerloader II and am wondering if I should follow Steve's advice?
Old Jun 27, 2002 | 11:39 PM
  #75
StormCrow's Avatar
StormCrow
Default Re: Took out MAF screen! (fxrhm)
I removed my MAF screen and I've had two instances light surging (once while pulling out of the parking lot here at work and once pulling in). Both times, it happened when I was going light throttle at something below 30mph. I've only been running without the screen since Saturday, so I'm hoping my car is still under the process of relearning. :/
I'll keep you guys informed.
Old Jun 27, 2002 | 11:53 PM
  #76
Truck Guy's Avatar
Truck Guy
Lord of the Tree
CI 3-4-5-6-7-8-9-10-11 Vet
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10, '16
I'm still on the fence wtih this mod, although I do need some leaning out after the TPIS install.........
:seeya
:yesnod: Me too....I have a Yank3000 TC, Free flow air bridge w/smooth coupler and LS1 Edit custom tune going in soon. I think I'll have the screen pulled at the same time so the tune reads the mod. :chevy
Old Jun 28, 2002 | 04:26 AM
  #77
StormCrow's Avatar
StormCrow
Default Re: Took out MAF screen! (Truck Guy)
On the way home tonight, I decided to take a small detour and test out the car.
**Disclaimer: I've put about 50 miles on the car since I removed the MAF screen **
While doing WOT from standstill to 55mph, response felt a little wonky. Shifted to second, but didn't get any surging. It sure did get up there fast, though. :)
WOT to about 40mph, shifted to second at around 4000 rpms and got engine braking or surging. I can't be certain, since I've only been driving stick since Oct.
WOT to about 70mph, shifted to third. It got up there real quick but I thought I felt surging. Who knows, I might be imagining things.
At this point, I'm thinking my computer needs time to relearn so I did an idle relearn to speed it along. Anyone else have any ideas on what I should try?
To Took out MAF screen!
Old Jun 28, 2002 | 09:34 AM
  #78
BatVette's Avatar
BatVette
Default Re: Took out MAF screen! (StormCrow)
I am definately interested in doing this mod. Of course I am concerned about the consequences from surging. Does it matter specifically that I see more problems in the 2001's? I would be interested to hear from anyone who has had problems once they removed the screen and what they did to remedy the situation.
Old Jun 28, 2002 | 10:11 AM
  #79
jschindler's Avatar
jschindler
Default Re: Took out MAF screen! (BatVette)
Let me play the devils advocate on this post. First of all, when it was eliminated on the Z06, the car only picked up 20 CRANK horsepower. At the same time, they eliminated the pre-cats and put a different cam and different air intake in the car. So how much rwhp do you think the maf removal actually added? I'd be totally amazed if it is even 5 rwhp. And there is not a one of you who can feel 5 rwhp SOTP's. You do know that 10 degrees of ambient temperature change makes 5 horsepower difference, don't you? I think a lot of people don't realize this. It is one reason alone that if you take your car out on a 60 degree day it feels stronger than on a 90 degree day.
Please feel free to disput my theory here, as I have no facts. But I just don't think it is worth it unless you are racing for money and a 5/100's of a second in the quarter is really important to you.
Old Jun 28, 2002 | 11:09 AM
  #80
SKINVILLE's Avatar
SKINVILLE
Default Re: Took out MAF screen! (jschindler)
