powerbond HB?
Old Feb 27, 2013 | 09:02 PM
upser23's Avatar
upser23
Default powerbond HB?
It has a key way slot but since the stock one doesnt have one that means i can just put the powerbond on however i want right..It doesnt need to line up with anything?
Old Feb 27, 2013 | 09:49 PM
lionelhutz's Avatar
lionelhutz
correct
Old Feb 27, 2013 | 11:00 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
I would do some research on that balancer if I were you. I believe they cause timimg chains to break
Old Feb 27, 2013 | 11:15 PM
upser23's Avatar
upser23
Ive read powerbond was one of the good ones
Old Feb 27, 2013 | 11:20 PM
lionelhutz's Avatar
lionelhutz
There is another one that was in common with many timing chain breaks. I can't remember which one right now and really can't be bothered searching for it.
Old Feb 28, 2013 | 02:40 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Powerbond is NOT associated with chain damage... I have one and it works very well. YES,, you can install it in any position that you desire.
It does have the key way and I added a pin to the crank snout to be able to utilize the key way:
Old Feb 28, 2013 | 05:15 AM
vettenuts's Avatar
vettenuts
The one you are thinking of is ASP.
I have installed a couple of Powerbonds. They seem to be well made units and the keyway can be used with the ATI pin kit, which is a nice feature. I have never seen data the damping performance of the Powerbond however.
To powerbond HB?
