Change Oil Soon Message
Old Mar 9, 2013 | 09:08 AM
K9Leader's Avatar
K9Leader
Default Change Oil Soon Message
My '99 with 48K total miles is giving me the oil change warning. Oil was done 8 months/5K miles ago. This seems a little early - in the past it has generally gone more like 7K miles/10-12 months.
Is this in the normal range?
Should I be concerned?
Will I ever find love? Oh, wait, different forum.
Old Mar 9, 2013 | 09:24 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
did you reset the OLM?
and I have never seen that kind of mileage between oil changes EVER on my 99 from day 1....
normal to me...
no...change the oil
yes, and her name will be Shaniqua
Old Mar 9, 2013 | 10:17 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Originally Posted by K9Leader
My '99 with 48K total miles is giving me the oil change warning. Oil was done 8 months/5K miles ago. .
You forgot to reset the oil monitor
Old Mar 9, 2013 | 11:23 AM
K9Leader's Avatar
K9Leader
I did reset it when I changed it last time. Oil level is good. I'll just plan on changing it in the next couple of weeks.
Old Mar 9, 2013 | 11:24 AM
jrose7004's Avatar
jrose7004
Yep
Old Mar 9, 2013 | 01:15 PM
pewter99's Avatar
pewter99
Originally Posted by 8VETTE7
My car commonly goes 10 to 12K miles before I get any oil related message. It's an 04, so perhaps they changed the way they calculate oil change time on newer C5's.
if my car did that I would have changed the oil only 12 times in 14 years.....
Old Mar 10, 2013 | 10:50 AM
jacobsjp's Avatar
jacobsjp
I've heard the computer adjusts the oil change warning based on how you drive. Were you driving more agressively?
Old Mar 10, 2013 | 10:56 AM
Poppa G's Avatar
Poppa G
normal to me...
no...change the oil
i just broke up with aquanetta... I'll send her your way
Old Mar 10, 2013 | 05:00 PM
3sACROWD's Avatar
3sACROWD
The oil life monitor works off an algorithm. I drive mostly on the highway and oil life is 10k - 12k miles. Getting 5k - 7k miles between changes would be considered normal for a car driven with more stops / idling. I don't think your experience is anything to be concerned about.
Old Mar 10, 2013 | 07:36 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Oil and a filer isn't that much money... For peace of mind just change the oil and filter.. Make sure that your 100% on the OLM and see how it pans out. I have driven my 02 z aggressively and had to change it a LOT earlier than I would normally.
Old Mar 11, 2013 | 12:22 AM
_r2h's Avatar
_r2h
I daily drive my 03 very aggressively. OCI for me is approx 7.5k-8.5k. Which is about as long as I care to leave the oil in the car.
Old Mar 11, 2013 | 04:22 AM
baxsom's Avatar
baxsom
Id be curious as to what a used oil analysis says about mobil 1 after 8K miles of driving. my guess would be that you should have left it in another couple thousand miles. I wish I would have kept the analysis I did on my wifes civic. The standard oil change interval per the manual for it was 10K miles. We used amsoil the first time I changed it, when I got the analysis back it recommended going another 5K on the next one.
Old Mar 11, 2013 | 07:48 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
All I can say is no matter how many times I've explained the OLM, in the last 12 years and how it works, even seasoned members don't have a clue. Im disappointed, and wonder why I waste my time here. Mileage has very little to do with oil life integrity. It plays a part but a small part. RPM, temp, shear, open loop vs. closed loop are much more of a concern to the OLM.
Old Mar 11, 2013 | 07:53 AM
Hameister's Avatar
Hameister
2015 C6 of the Year Finalist
Originally Posted by Evil-Twin
... Im disappointed, and wonder why I waste my time here.
Maybe you have no where else to go?
Old Mar 11, 2013 | 09:58 AM
_r2h's Avatar
_r2h
Guess I should add that I go by the OLM, not actual mileage.
Old Apr 23, 2013 | 01:51 PM
ssuesz's Avatar
ssuesz
4th Gear
Help, I have tried to reset the oil change now message on my '98 but it will not reset, any ideas??????
Old Apr 23, 2013 | 01:58 PM
ZeeOSix's Avatar
ZeeOSix
Been driving it pretty hard? That will decrease the mileage the oil will go vs. the Oil Life Monitor. If I drive my Z06 hard, oil life it near 0% at 5~6K miles.
To Change Oil Soon Message
Old Apr 23, 2013 | 02:00 PM
ZeeOSix's Avatar
ZeeOSix
Check your owner's manual to make sure the procedure is being followed correctly.
http://www.c6registry.com/Technical/...98corvette.pdf
Page 2-93:
To reset the OIL LEE reminder after an oil change:
1. With the ignition on, press the TRIP button so the
OIL LIFE percentage is displayed.
2. Press RESET and hold for two seconds. The word
RESET will appear, then OIL LIFE 99%.
Old Apr 23, 2013 | 02:27 PM
chaase's Avatar
chaase
St. Jude Donor '12
If you are sure you reset it, then listen to the OLM and change the oil.
Old Apr 23, 2013 | 05:36 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Turn on the ignition (engine OFF)
Bring up the oil life monitor percent display
Press the accelerator fully to the floor and release it four times.
Your OLM display should read 100%
