DSS Torque Tube Coupling Help
Old Mar 26, 2013 | 08:40 PM
rmata's Avatar
rmata
Default DSS Torque Tube Coupling Help
I was wondering if anybody else has ran into this problem. I have a 1999 torque tube and decided to replace the old couplings with the DSS ones. The quality looks a lot better, but once I replaced them and tried to assemble everything back together I can't get the torque tube to go on. It's as if the DSS couplers are larger than the stock ones and won't slide in. I ordered the 10mm ones so not sure if this is common or not. I would call but it's after hours so I'm just trying to get some ideas.
Old Mar 27, 2013 | 12:16 AM
Supercharged111's Avatar
Supercharged111
The older C5 TTs are smaller than the newer ones, right? Or was it Z06 vs non, I forget, but I do know there are 2 different TTs in the C5s. Was that taken into consideration with the purchase of the coupler?
Old Mar 27, 2013 | 12:32 AM
rustyguns's Avatar
rustyguns
you might need to give a bit more info. when you took it apart did you have to pound or push very hard on the input shaft to remove the drive shaft from inside the torque tube? the input shaft bearing fits really tight in the front of the torque tube and is a little tough to put back in. I usually have to pound it in with a 2x4
the 2001-2004 bushings are thicker. DSS may have screwed up and drilled 10 mm holes in a 2001-2004 coupler
Old Mar 27, 2013 | 01:03 AM
lionelhutz's Avatar
lionelhutz
Did you compare them to see if they were the same thickness and diameter?
The bolts should have been fairly snug in the holes if they were the 10mm couplers.
Let us know what you find. Both the 10mm and 12mm couplers are the same diameter (12mm is thicker) so it appears their couplers are too large to fit the early torque tube.
Old Mar 27, 2013 | 07:32 AM
rmata's Avatar
rmata
I had to tap it with a rubber mallet to get the props haft out of the torque tube, but I don't see it going back in even if I used a 2x4 but I didn't actually try that yet. So is the 12mm torque tube housings bigger than the 10mm ones? The part number matches up with the 10mm ones I ordered. The DSS couplers are bigger, but I initially thought it was just because my GM ones were so worn out. I'll give them a call today and see what they say.
Old Mar 27, 2013 | 10:53 AM
NukeC5's Avatar
NukeC5
Yes! I ran into the same thing exactly! Its actually a quality issue on DSS's part. I have a 99 A4 that I upgraded to DDS poly couplers when doing a high stall converter.
Long story short. Its not the wrong size, the damn thing is out of round. We put the couplers on a lathe and sanded them down in the oblong areas. Then it fit alright.
NukeC5's Avatar
NukeC5
And nice comparison of the couplers. Mine looked similar
Old Mar 27, 2013 | 11:12 AM
rmata's Avatar
rmata
Yeah, it looks like they are aware of this. I actually just got off the phone with them and they said to send them back in to be modified. Looks like it'll take a little longer to get my car back on the road, but at least I'll get to use them. Thanks for your help
Old Mar 27, 2013 | 11:20 AM
NukeC5's Avatar
NukeC5
They are going to do the same thing... Just do it yourself to save time!
Old Mar 27, 2013 | 11:23 AM
NukeC5's Avatar
NukeC5
If you dont have a lathe available use a dial caliper and a sanding tool till you get even all around. Its time consuming. But we bypassed this hickup in a matter of an hour and got back to work. Its not rocket science, just get it round!
Old Mar 27, 2013 | 11:25 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
On one end of your prop shaft, theres a large nut that secures the coupler flange to the torque tube. Make sure that nut is tight!!
They have been found to have backed off and allow the flange to make noise.
We took ours apart and put high strength locktight on the threads and hammered it down good and tight!
Bill
Old Mar 27, 2013 | 11:47 AM
rmata's Avatar
rmata
I don't have access to a lathe so I'd rather just send it in and let them be responsible for it. i guess I can think of a couple other little projects I can do in the meantime while I wait for them anyway. I have the Hinson motor mounts and a fast 102 to replace, and I'd like to clean the diff real good and replace the axle seals.
Thanks for the tip Bill, I'll be sure to check that now that I'll have the opportunity again.
Old Mar 27, 2013 | 12:36 PM
RonSSNova's Avatar
RonSSNova
$400 for the pair and they don't fit? What?
Why in the heck would they let them out the door like that if it's a "known" problem? Gads.
Thanks for posting. I'll be replacing couplers in the next month or so.
Ron
Old Mar 27, 2013 | 01:33 PM
NukeC5's Avatar
NukeC5
Ron
Thats what I said. I was pretty P.O.ed. Probably the most expensive couplers on the market from the leading authority in drive train components. We should not be going through this to get them to work.
Old Mar 27, 2013 | 01:42 PM
RonSSNova's Avatar
RonSSNova
I have the late A4 TT in my car now, the one with the issue. The orig A4TT is in the garage. I thought the later had the 12mm couplers.....I was wrong. So I need to source 10mm parts. I guess I better figure out what I need to buy. Stock is fine, if they are available.
Too bad the later shafts aren't 12mm, I have a nice pair of replacements that were given to me.......
Old Mar 28, 2013 | 04:29 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default If you've got driveline noise....Give us a call.
We've got the parts in stock and we've got PLENTY of experience with
C5 and C6 torque Tube problems and failures.
Been thru too many of them in the past few years and I've just about seen it all....
Call any time. 914-332-0049
Chuck CoW
Old Apr 6, 2013 | 08:41 PM
Formulized94's Avatar
Formulized94
So I am in the business for new couplers... these were the ones I was looking to purchase, might be rethinking that.
To DSS Torque Tube Coupling Help
Old Apr 6, 2013 | 08:51 PM
NukeC5's Avatar
NukeC5
Just talk to them over the phone and tell them you are familiar with the bad luck others have had. Im betting they will make sure to send a good set to avoid yet another return. They really are a top of the line brand. But these damn couplers... not their best work, thats for sure.
Old Apr 6, 2013 | 10:18 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Yup had the same problem,But instead of making the couplers smaller and maybe weaker,I took a die grinder and made the hole bigger on the torque tube,Went right in after that
Old Apr 11, 2013 | 10:24 AM
rmata's Avatar
rmata
Yeah, just make sure they modify them for you before they send them out if you are getting the 10mm ones because I'm still waiting on mine to come back. They are taking a lot longer than I expected and makes me regret not taking care of the problem myself, but luckily I have had other work going on in the shop to keep me busy while I wait.
