C5 won't start
Old Mar 30, 2013 | 11:29 PM
helios_1215's Avatar
helios_1215
Default C5 won't start
k, i posted another thread, seems the title was a little misleading, so i just post it again. My C5 wouldn't start this morning. I plugged in the key, and turned it to start. The lights went off for split second, and i could hear a very faint sound from the engine, that's it. no spark, no start. It shows on DIC "break before shift." only check engine light and gauge light were on. I pull the code. There were U1160 and C0584. C0584 i have seen for awhile now, it's the first time i see the U1160. I clear the history, only C0584 came back on again when i try to start the car again. I tried a couple dozen times, no luck, still the same thing. I checked the key cylinder pellet and my key. they are clean. I drove my car for about 70 miles with about 85 mile/hr. I drove recently in snow once, but everything was fine after.
I did some research, seems it can be BCM failure, fuel injection problem. I dunno what else it can be, and how much it's gonna coast me to fix it. I don't want the dealer kidnap my car and, i don't have enough ransom to get her back. especially she is not running.
thank you guys.
Old Mar 30, 2013 | 11:44 PM
baxsom's Avatar
baxsom
Battery voltage?
Old Mar 31, 2013 | 12:19 AM
helios_1215
battery voltage appeared on the DIC was 13 when i first time fail to start it in the morning. I checked before dinner again, after couple dozen times it's 11.9 right now.
helios_1215
Originally Posted by baxsom
Battery voltage?
Old Mar 31, 2013 | 01:21 PM
BigGun's Avatar
BigGun
Charge the battery and check the connections at the starter.
Old Mar 31, 2013 | 01:41 PM
sircampsalot2's Avatar
sircampsalot2
Also might wanna check to see if the Anti-theft system is working properly...sounds like it might not be recognizing your key in the ignition or something
Old Mar 31, 2013 | 01:54 PM
helios_1215
hopefully it's just the battery problem. thanks.
helios_1215
how can i check the anti-theft system?
Old Apr 1, 2013 | 08:25 AM
helios_1215
you are right, it's the anti-theft system. my ignition is disabled. i am not sure if i can do anything or i should just send it to dealer.
Old Apr 1, 2013 | 10:47 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Charge the battery.. Clear the DTCs ... Reinsert the ignition key and see if you hear the column lock motor unlock the column.
What is your security light on the IPC doing when the key is in the ignition??
BC
Old Apr 1, 2013 | 11:04 AM
helios_1215
BC
Thank god, bill you are here. I recharged the battery. the security light is off when i turn the key. i clear all the code, the only reoccuring code is the c0584. i am going to take a video right now. there is my door lock sound. and the all the electronic device shut down.
Old Apr 1, 2013 | 11:23 AM
helios_1215
this is the video of what happen when i try to start my car. i hope this help. there are all the sound, even the sound of my breath...
Old Apr 1, 2013 | 10:28 PM
helios_1215
BC
So as the video show, the security light is off when the key is in the ignition. And there is no lock column sound. So what do you think the problem is? I have sent you private msg this morning. Thank you for replying.
Old Apr 10, 2013 | 06:51 PM
helios_1215
Just an update, I brought it to a small shop, they disconnected the battery and tightened everything, car runs fine for a week, today can't get it start again. Then I tried couple more time. It started. I pull the code.
B0361
U1000
B0441
I really think it might be the bcm/PCM problem. I think I need to bring it to the dealer.
Old Apr 10, 2013 | 08:31 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Pull the neg battery cable one more time and wait a minute. Then reconnect and see if it starts/
BC
Old Apr 12, 2013 | 11:19 PM
helios_1215
BC
It won't start again today. And I realized the TPMS sensors are not displaying numbers. Not X just blank...
Old Apr 13, 2013 | 09:15 AM
helios_1215
I pulled the neg cable put for two min. But it still won't start.
To C5 won't start
Old Apr 13, 2013 | 09:22 AM
3boystoys's Avatar
3boystoys
ANybody do a load test on the battery?
Old Apr 13, 2013 | 09:31 AM
helios_1215
Just putting a crazy idea out there, is it possible it's because of low oxygen in my garage? Coz it's underground, and very bad air flow. Both time it won't start happened iny garage. And it's fine outside.
Old Apr 13, 2013 | 09:39 AM
helios_1215
I don't think so, but it won't start when I try to jump start it.
