Help finding a Comp 224 cam
Old May 27, 2013 | 12:45 AM
hexagram13's Avatar
hexagram13
Default Help finding a Comp 224 cam
Hi, I haven't posted much because my car has been in storage for 4 years. I had a lifter blow up and parked the car. I'm now getting it repaired, but the cam is trash.
I'm looking for a new Comp cam 224/224 .581/.581 114. I can't find it in their catalog now. I need a new cam and lifter set and wanted to go back with the same thing so hopefully the tune will still be right.
Also, what lifters do y'all recommend?
My other mods are below.
99 Coupe
RPM 2800 Torque Converter
RPM Stage 4 Automatic Transmission
SLP underdrive pulley with gatorback belts
SVO 30# injectors
Hypertech 160 thermostat
Comp cams 7.4 chromoly pushrods
Patriot Stage 2 LS6 heads with 64cc
SLP double timing chain
NGK TR6IX plugs
SLP LS6 ported oil pump
Magnecor Wires
Abs of Steel (coated) from Elite Engineering
LG Street Series headers and x-pipe (locally coated)
Borla Stinger Exhaust
SLP LS6 Intake
Donaldson Blackwing with Icebox
Old May 27, 2013 | 01:06 AM
StingrayRebel's Avatar
StingrayRebel
if you have the specs you can just order it directly from comp and it might even be a bit cheaper... I see a lot of people using factory ls7 lifters
Old May 27, 2013 | 07:59 AM
AU N EGL's Avatar
AU N EGL
I have that cam for the past 10 years now. Good cam.
texas speed has them
http://www.texas-speed.com/p-1146-te...-camshaft.aspx
Lg has the G2
http://www.lgmotorsports.com/product...oducts_id=1509
However, I would do one of two options:
1. 224/228 581/588 112 or 114
http://www.texas-speed.com/p-1147-te...-camshaft.aspx
LGs G5X1
2. 228/232 588/574 112
this would be my choice
Old May 27, 2013 | 08:25 AM
vettenuts's Avatar
vettenuts
AFR also sells the 224/228 on 114 as part 6016. It is ground by Comp.
Old May 27, 2013 | 09:18 AM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
As posted above, Texas Speed has them, I am having one installed in my 2000 M6 with a number of other components.
To Help finding a Comp 224 cam
