Best cam for torque
What cam is great for torque and low speed drivability? I assume something with a sub 22* duration and will work with the trusty...or not so trusty 4l60e and 3.15 gears.
I hope someone chimes in...I've spent the last two weeks reading, researching, and debating the same issue. I ~do not~ want 3:42's or 3:73's, because I don't want to lose the top end (I have a 3:15 rear on the way to replace my 2:73) and plan to replace the TQ converter as soon as I get the cam selection narrowed down.
My planned mods are, in this order:
1. Replace the 2:73 with a 3:15
2. Install LT headers
3. Install an LS6 intake
4. Replace cam and TQ converter
The headers and intake brands are easy to figure out....LG for headers, and GM for the intake. I'll probly go with a Precision TQ converter. The cam selection has me....going in circles.
I do not intend to ever put the car on a track...1/4 mile or otherwise.
I DO intend to fully enjoy the (frequent) acceleration to...shall we say...high speeds. Where I live there are roads that are just begging to be driven hard, where a long TQ curve will really make you smile.
I read a post a while back where the OP listed his mods, and the SOTP as well as the dyno results...his result was EXACTLY what I want in my car, but wouldn't you know it, I didn't bookmark it, now I can't find it! I've used the "search" feature on the forum, but "best cam" nets about 4 billion hits, mostly for other than a C5.
Sooo.... any thoughts? Which cam for my car? anyone?
Go over to LS1 Tech....cam guys are there.
I have a Pat G custom, it's 226/230, right at .600" lift and 114 lobe sep. It's quite good. Mellow, yet the car is knocking on the 10's.
Ron
mine is 224/224 116lsa no problems with idle, strong power 1800-6000rpm range
I have the 3:15 gears and im happy with it
A 224/224 or 224/228 would be good. I went 222 to insure cali emissions compliance. Would rather have gone 224.int and 112lsa
Ron
By the way, I am running a 3200 stall and 3.42s. I will have a great low end set up. Im worried about my high end now! haha. But I hope to have good all around power.
auto conversion done I had a 228/232 on a 110 and could never get
it tuned where it didn't stall at stoplights or rpm's jump up and down.
It was tuned at a very popular shop down in Georgia, twice.
Got to where I didn't even like driving it. With this cam and the auto
now anything below 35 or 40 the tires will lose traction when I stomp
it with the 3:42's I had put in it. Haven't had it on a dyno since but it's
got all the power I want.
Spartan did my build and HIGHLY recommended 342 as a minimum with my setup. I have not dyno'd it, but it has a lot of torque low to mid..
that confirms for me that I need to change my cam to something with less duration then. If it can't work with the 3.15's, I just don't want it. I feel confident If I installed 3.73's I would probably fall in love with my cam...until I got on the highway for 20 minutes each way and opt to blow my brains out...lol
I am seriously searching now for a cam like yours. What is the lift? If I have enough torque then the 3.15's will be just fine. I need the steeper gears to get into the power band faster. If the band is lower or torquier then my gears should be fine. She is a cruiser/bruiser...lol
Josh does great work. I wish I had known about him when I had my first cam. He installed my current cam and did a great job tuning it. Drives like stock but will blister the hell out of those tires.
Really knows his stuff!
After mods 81 mph at 2500 rpm and getting ~28 mpg.
I love my 342"s!!!
