High Voltage error need to use car
Old Jul 12, 2013 | 11:02 AM
leet13's Avatar
leet13
Default High Voltage error need to use car
Hi all. Once in a while I get a high voltage warning and my gauges go out... I can see my speed and rpm with my HUD. I read it could be the regulator in my alternator (saw in another post). For the first time the other day I saw a low voltage warning and I saw the needle dropping down. I was idle in my garage... I only have one car right now and that is mine (hubby's car is in the shop)... what harm will I do driving my car if the gauges go out and it says high voltage?
My car does sit and I get it out once a week or so... no problems starting up... battery is less thsn 1 yr old (optima yellow top).
Old Jul 12, 2013 | 11:41 AM
dadaroo's Avatar
dadaroo
Most likely the alternator regulator is bad. Be careful it does not boil/overcharge the battery and put acid on the PCM computer module below the battery. Please check around the battery for any signs of leakage you may need to clean up.
Could be a bad battery also. I would get them both tested.
Old Jul 24, 2013 | 08:45 AM
leet13's Avatar
leet13
Going to go check things out again today again to see if I can figure it out... what is happening now is i get a low voltage error and watch the gauge needle drop all the way down and then up again. Weird I am getting both high and low voltage errors during a single start up now. No noticable dimming of lights. Guess I have to get it to a shop because this wont fix itself (originally thought it was acting crazy because my car doesnt get driven much... 1x every 2 weeks or 3 weeks).
Old Jul 24, 2013 | 04:42 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You MOST LIKELY either have corroded, dirty or a poor connection on the starter solenoid OR loose/dirty or damaged BATT connection on the back of the alternator under the rubber boot.
The charging and alternator feed back voltage wires orginate thru the starter solenoid. The batteyr also connects there and receives its charging voltage and supplies field voltage to the alternator thru those connections
Jack up the car and make sure that the solenoid connections are not damaged/ burnt/ loose/ corroded.
Make sure that the BATT connection on the back of the alternator is tight and not burnt.
Make sure that the plug on the top of the alternator is not damaged. One of the red wires should have battery voltage on it at all times! That wire is the output reference feed back wire and controls the alternator output voltage. If it is compromised, it can and will cause the output voltage to read very high!
I also recommend removing, cleaning and properly tighting the battery terminal connections. 97-2003 C5 = 11 foot pounds of torque for correct trouble free connections.
Old Nov 3, 2021 | 01:55 PM
lotzacarz's Avatar
lotzacarz
2nd Gear
lotzacarz here 01 Z06 17,000 always garaged never in rain getting high voltage warning, low voltage warning gauges all go dead. Absolutely NO corrosion anywhere Alternator perfect (changed anyway) brand new battery (exactly the one the car calls for-always has been). Wires are all tight. Sent instrument cluster out to be diagnosed. Checked perfect. Put cluster back in>> 3 seconds later> high voltage warning! Volt gauge went up. Gauges all died. At wits end!!!!! NO ONE HAS "THE" ANSWER!
Old Nov 3, 2021 | 04:55 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Could possibly be a bad PCM…if you want to wait 2 weeks (just had minor back surgery today) and drive the car across the state I’d be happy to look at it…I’d throw the lab scope on the L and F terminals at the alternator connector and see what’s it’s showing !!..and WELCOME to the Forum. !!..BTW I can recommend an excellent diagnostic shop in Melbourne if you want to go that route.
Old Nov 4, 2021 | 01:00 PM
sirdano's Avatar
sirdano
Has the alternator been changed?
Old Oct 8, 2023 | 02:35 PM
Carlos_426's Avatar
Carlos_426
4th Gear
Did you ever find what the problem was? I am having the same problems
Old Oct 8, 2023 | 03:09 PM
mmartinez's Avatar
mmartinez
You will get more responses if you start a new thread.
Old Oct 9, 2023 | 11:29 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you have a HIGH VOLTAGE message, Put a volt meter on the battery terminals (engine running ) and see what voltage the system is seeing. Is the alternator actually outputting a high voltage??? Should be 13.5 to 14.5 VDC.
The alternator gets a feed back reading from the red sense wire that attaches to the starter main terminal and it goes back to the alternator on the small plastic plug that connects to the side of the alternator. See if that wire has continuity to and from the alternator to the starter.
I agree,, Start a new post for more direct assistance.
Bill
Old Oct 10, 2023 | 09:53 PM
Carlos_426's Avatar
Carlos_426
4th Gear
Bill
I checked the output voltage from the alternator and it reads 14.2v. i checked the battery ( i actually purchased a new one). I changed the starter thinking that was the problem because of a bad solenoid.. i checked all the grounds and all the fuses and i still get the.. CHARGE SYSTEM FAULT.. HIGH VOLTAGE.. As soon as i start the engine the volts get high and when it reaches over 16v all the gauges go dead
Old Oct 10, 2023 | 10:08 PM
mmartinez's Avatar
mmartinez
This tread was started in 2013, and then replies were made in 2021, doubtful that the person who had this same problem will reply. You might think of pulling the alternator and having it tested at your nearest auto parts store.
Old Oct 10, 2023 | 10:54 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You either have a bad regulator, connector to the regulator or that small red wire that connects to the solenoid main terminal is compromised/broken!!! Get an ohm meter and check that wire for proper continuity. Check that White/clear plastic connector on the side of the alternator for damage / melted /corroded pins.
Bill
Old Oct 10, 2023 | 11:43 PM
Carlos_426's Avatar
Carlos_426
4th Gear
Bill
regulator is brand new.. the cable to the starter solenoid should be good i just checked it and clean the metal connector..how do you check the cable with the multimeter? How would i know if the connector to the regulator is bad?
Old Oct 11, 2023 | 01:37 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Please call me. PM sent. Have your multimeter ready and access to the vehicle.
BC
Old Oct 11, 2023 | 09:35 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bill
If you measure that wire with a DC Volt meter to ground, It must/should read full battery voltage at all times. Look at the pins inside the end of the connector. Are they clean and tight? Do they make solid connections inside the alternator?
Old Oct 11, 2023 | 09:36 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you measure that wire with a DC Volt meter to ground, It must/should read full battery voltage at al times. Look at the pins inside the end of the connector. Are they clean and tight? Do they make solid connections inside the alternator?
To High Voltage error need to use car
