Coil upgrade?
Old Jul 18, 2013 | 12:46 PM
StatmanRN's Avatar
StatmanRN
Default Coil upgrade?
With 107K on them and increasing the boost level, are there any upgrades for coils? Are there any benifits to truck coils? The MSD coils seem to get a bad rap, but have always had good results with their products. Anyone done a comparison?
Old Jul 18, 2013 | 05:22 PM
NukeC5's Avatar
NukeC5
From what I hear, it really doesn't get much better than the OEM setup. The coils are powerful and each cylinder has one directly to it. They fire so fast and accurate, you can get any tuning you need done with them. I dont think its worth messing with. Besides, the spark plug gap is still going to be jumped with the same amount of current (which the factory coils are beyond capable of providing). So going to a higher output coil really wont do anything.
Old Jul 18, 2013 | 07:35 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
ABSOLUTELY CORRECT. Nothing in the primary or secondary coil/plug or plug wire area will add power.
OEM is all you need!
However,,,,, you should make sure that you have proper battery voltage supplying the coils and injectors as the ignition switch supply can provide less than necessary voltage if the switch starts to fail.
Bill
Old Jul 18, 2013 | 08:44 PM
LoneStarFRC's Avatar
LoneStarFRC
Bill
Do NOT buy into MSD's hype about their LS coils! Do NOT buy them!
The OEM coils provide plenty of juice.
Old Jul 20, 2013 | 01:14 PM
youngrigo's Avatar
youngrigo
Like everyone else said... Stick with the OEM and run from the MSD if you don't want to have problems
Old Jul 20, 2013 | 08:23 PM
red1vette's Avatar
red1vette
Stick with OEM for sure!
Old Jul 20, 2013 | 08:44 PM
StatmanRN's Avatar
StatmanRN
OEM Seems to be the consensus.
Next question: Given the age/mileage, shold they be replaced or wait until a problem arises?
Old Jul 20, 2013 | 08:45 PM
Ohyoufan's Avatar
Ohyoufan
The only coils I'd swap for is the truck coils only if I was getting rid of my fuel rail covers just for aesthetic reasons, but since I'm not the stockers work just fine like everyone else stated.
Old Jul 20, 2013 | 08:57 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Unless you are getting a coil related cylinder misfire, there is NO reason to worry about them. If you have a forced induction engine, up grading to late model LS3 or truck coils will give you some more dwell time and secondary current. Its not a plug and play swap. You have to splice on different connectors.
People (Me included) running 450 -500 RWHP do so on stock coils without issue. I'm at 60,000 miles.
BC
Old Jul 20, 2013 | 09:26 PM
LoneStarFRC
Paraphrasing: ITABDFT.
If it makes you feel any better, buy a spare to keep on hand.
Old Jul 20, 2013 | 09:39 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I just realized... Your stock nasty OEM coils are BAD!!!!
Get eight new ones and send me the old ones. I like old parts. I will pay the shipping.
LOL
Old Jul 20, 2013 | 09:47 PM
LoneStarFRC
LOL
If he sends you his old nasty coils, can I have your olds ones? Surely they are getting on in age by now.
I'll even post a step-by-step installation complete with pictures.
Old Jul 21, 2013 | 06:55 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
So just curious.... whats wrong with the MSD coils ?
Bad product, or just a waste of money since the stock ones are very good quality.
Toque
Old Jul 21, 2013 | 08:53 PM
crainholio's Avatar
crainholio
Toque
There's a big difference between GM & Delphi testing components to 100K miles in all weather conditions, versus aftermarket companies knocking off their design and "improving" it.
I've helped two guys diagnose engine misfires involving MSD ignition coils, plus my own experience on my old TPI car where the MSD coil was arcing through its failed insulation after less than 10K miles service.
I'm not saying all aftermarket parts are bad, just that MSD coils have a well-earned bad rap.
Old Jul 21, 2013 | 11:50 PM
Toque's Avatar
Toque
Thanks for the explanation. That is what I was wondering.
Good to know if I ever have to replace a coil...
Toque
Old Jul 22, 2013 | 12:20 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I'm sure that the MSD coils do work. BUT,, for our secondary spark needs, OEM works excellent.
I also know that, MSD draws more primary current at full load and our puny 12 VDC supply and ground wires do not adequately support those needs.
If you rewired the power and ground circuits, they may work better but,, thats just an assumption..
Why spend the extra cash on something that really doesn't need any up grading??? Spend it on something that really needs better parts.
Bill
To Coil upgrade?
