No pulling Power
Old Jul 20, 2013 | 08:09 AM
Strawberry4669's Avatar
Strawberry4669
3rd Gear
Default No pulling Power
Got to a red light took off in 1st really hard shift 2nd and then nothing car has no gears that will make it move i was thinking input shaft but any ideas greatly appreciated! Thanks
Old Jul 20, 2013 | 09:55 AM
lionelhutz's Avatar
lionelhutz
Could be a number of things. Manual car? Clutch, trans input shaft, trans output shaft or diff output shaft are all possibly breakage points. I'd look at the diff output shaft if it's not dumping oil from a broken rear end and not making funny noises when you press the clutch pedal.
Old Jul 20, 2013 | 10:54 AM
Strawberry4669
3rd Gear
Lionel thanks for the info yes it is a manual tranny its not the clutch im thinking because it goes into the gear but just doesnt move u can hear something like jus spinning but i dunno. I have no oil leaks from what i can see on the floor.,
Old Jul 20, 2013 | 11:27 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its very likely a broken differential output shaft. Jack up the rear-end.
Have someone hold one rear wheel and try to turn the other wheel. If if either one of the wheel free spins, you have differential output shaft or limited slip clutch failure and a busted output shaft.
Just so you can get an idea of how the differential is constructed and some ides how to fix it and maybe beef it up, check out these post:
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
Bill
Old Jul 20, 2013 | 11:48 AM
Strawberry4669
3rd Gear
thanks for the good info Bill will do
To No pulling Power
