cam bearing help please
Old Aug 29, 2013 | 12:57 PM
mathia's Avatar
mathia
I'm in the middle of a cam install and my front cam bearing looks very similar.
01 stock motor w/ 60k miles. I'm the original owner and never saw any oil pressure issues. I've done about 25 HPDE days with the car.
Old Aug 29, 2013 | 05:07 PM
didntdoit11's Avatar
didntdoit11
St. Jude Donor '12
well i took bills advice and bought a bore scope (harbor freight $89) worked for what i needed it for, lol and found all cam bearings are like the firsrt one maybe worse so i will be replacing them. thank you all for your help and advice
Old Aug 29, 2013 | 06:00 PM
RonSSNova's Avatar
RonSSNova
Nice clear photo.
The front bearing has to deal with chain tension....I'd wager it works harder than the rest.
At any rate, you had no oil pressure issues so I would install the new cam and run it. mine looked about the same at 80K miles when I did my cam.
I probably would if I were the OP as well. But if the engine is out, might as well replace. But find a competent shop to do it.
Ron
Old Aug 29, 2013 | 09:29 PM
OneCylinder's Avatar
OneCylinder
St. Jude Donor '13
Originally Posted by didntdoit11
should i replace or is this normal
I learned about engines old school, hands on and I was taught ALWAYS replace bearings when replacing rotating stock. For example if you pulled the cam to inspect it and re-install it, then fine, if the bearings and journals mich within tolerance no need to replace the bearings, unless you just want to (I would). You should not however install new rotating stock on old bearings. New bearings and journals mate during break-in. Break-in allows different tolerances to minimize. A new cam on old bearings may be a sloppy fit and you might not realize it.
Old Aug 29, 2013 | 10:33 PM
mathia's Avatar
mathia
Here's some more opinions on the matter:
http://ls1tech.com/forums/generation...ng-wear.html#9
http://ls1tech.com/forums/generation...ring-wear.html
I'm just going to leave them as is and continue on with my install.
Old Aug 29, 2013 | 11:15 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,,,,,,,,,,,,,,,,,,,,,,,,,, If you go by that INFO, ,,, If it were me,, I would at a M I N I N U M measure the cam and cam bearings and figure out what the MAX OEM bearing clearance is and go from there!
Old Aug 30, 2013 | 12:07 AM
RonSSNova's Avatar
RonSSNova
Besides, it's a better problem to have than a balancer that fell off eh?
Ron
