What is the going rate...
Old Oct 11, 2013 | 03:24 AM
john8642's Avatar
john8642
Originally Posted by strand rider
I was finding labor quotes from 8 to ten hours , but never saw a rate book number for the job. How much the hours cost varies.
I paid around 800 bucks labor for the job from a dedicated Corvette garage. Be sure and address the torque tube wear .
Just to be interesting, the car had only a vacant space where the pilot bearing belonged. Nothing but dust, but I put a lot of miles on a hurt clutch, looking for a garage that knew the car.
In my local area, you can find german specialty garages all day long, good ones. High end chevy repair, forget it. Don't ask me how I know these cars need a better than average shop.
Can you tell me which shop you used, if they did a good job? I've been pricing shops from south bay to orange county, and the prices range from $ 900-1200. Just had to do the ranger flush, so the slave cyl probably doesn't have much time left.
Old Oct 13, 2013 | 02:49 AM
Supercharged111's Avatar
Supercharged111
Originally Posted by bcperry
I plan on grabbing an LS7 if/when I get the clutch worked on, I figure 500 crank horsepower is about as much power as I'll ever need. If I want more, I'll upgrade to a C6Z and build on it.
With the power it robs, screw that.
The job isn't that bad. Dropping the cradle reminds me of a FWD car, and once you free the harness the TT it a cakewalk to free up off of the bellhousing. Only takes a couple hours to get that far. At that point, the clutch is staring through the bellhousing right at you, it's not that much worse than doing it on a normal car. More time consuming? Yeah, but it's not that big of a pain. Nowhere near what I experienced yanking the 4.7L V8 from a Grand Cherokee. NEVER AGAIN.
Old Oct 13, 2013 | 10:12 PM
mightymike140's Avatar
mightymike140
Just had my Mcleod rxt + flywheel Installed , $600 labor
Old Oct 14, 2013 | 09:01 PM
71corv's Avatar
71corv
St. Jude Donor '08
$1500. Break down was 10 hrs. labor @ $75/hr. C5 Z06 clutch kit (flywheel,etc.) $750.
Gene
