Bad first gear synchro
All other gears are fine, there is no other apparent problem. I drained the fluid and it looked very clean (I changed it about a year ago).
My question is, is there anything else that could have broken in the transmission to have caused this somewhat sudden failure? What I'm really wondering is if I should drive it like this, or is there a chance of doing further damage??
Thanks,
Dave G.
If you have the means to do so, flush your clutch fluid and put something back in of good quality. A good DOT 4 fluid. Afterwards, install 4.5 qts of GM Synchromesh and/or the Pennzoil equivalent (that's what we use) in the trans. I like to call Synchromesh "transmission guy in a bottle", stuff is amazing.
If those 2 together do not smooth out your problem, you've got a boogered up 1st gear and the trans needs to come apart. With the T56 having to be broken down from the rear forward, it would be a good time to have the entire transmission refreshed. If it comes to that I'd highly recommend doing the following: Rebuild kit with carbon fiber blocker rings, billet synchro keys for 1-2 and 3-4, bronze fork pads, Steel 3-4 shift fork, and make sure whoever builds it now's how to properly shim the entire assembly while checking it with a dial indicator to make sure it's within spec.
Good luck!
I did do a lot of searching before posting this thread and already have 4 bottles of GM Synchromesh FM on the way. As bad as it is, I doubt that will fix it, but maybe help enough to get me by for a while until I can get the issue resolved over the winter. It must still work partially as I can (carefully) slide it in to first at low speed.
Dave G.
,,,,,,, would you down shift to first gear. I can’t say that I have not done the same BUT,,,,,,,, I do not make a habit of down shifting to first. I would call it a VERY rare action.It’s a really short gear and the synchros work HARD when down shifting to that gear.
As long as you can still shift into first when very slow or stationary, I would worry too much about it.
I would change the ATF because you KNOW that there are wear/tear pieces parts of that synchros in the fluid. Switch to ANY Synthetic AFT and you will improve the shift quality of the trans in the remainder of the gears.
And if I do decide to let it go for a while, I'll likely put a synthetic back in it. I changed it last weekend to just some dyno stuff, but was going to try the synchromesh partly just out of curiosity since I read in various places that it made a decent synchro band-aide. I never intended to leave it in long term since it's not really the correct spec oil.
Dave G.
My car won't drop into 1st unless I'm at a crawl or stopped, and every manual car I've driven has been similar. I had an Acura that I swear had a interlock on 1st until you were completely stopped. Trying to go into that gear with any movement at all felt like you were hitting a wall with the shifter.
A lot of cars shift hard in to first. Mine just grinds big time if I try to downshift at any significant speed. Not the same thing (unfortunately).
Dave G.
I also want to thank the guy with the rebuild list. Good for me, my car is getting some good miles and transmissions don't grow back after you wear them down.
I once had a car with a non syncro first gear. After I blew that gear up trying to impress a girl, the trans guy showed me how lucky I was, since I drove it around for a good bit more. There was a small collection of metal bits of parts on a magnetic drain plug, but the big items were just lying in the bottom of the case, just waiting to jump up and cause mischief. Old sports car were more down to earth. THe 1962 car that had a non synco first also came with a hand crank stowed in the body work, and a starter button under the hood, because the cars needed a lot of tune up type attention back then.
Oh, and be sure to rev match your downshifts. Not only is it fun and a good challenge to do correctly but it saves your tranny!
(told you it wasn't cheap)
