Winter project has begun!
Old Dec 8, 2013 | 12:21 AM
rpmrollbar's Avatar
rpmrollbar
So got whole assembly cleaned up today. Degreaser and power washer. 2 hr job and its 24 degrees out today. Came really clean, no longer looking like a logging truck rearend .
Old Dec 8, 2013 | 12:28 AM
rpmrollbar's Avatar
rpmrollbar
Pilot bearing removal literally was 30 seconds. Went down to auto zone and rented bearing puller. Piece of cake. Hammered new one in and done. Installed new flywheel and clutch assembly. The Monster stuff fit like a glove and was very complete with all the hardware.
Old Dec 8, 2013 | 01:01 AM
rpmrollbar's Avatar
rpmrollbar
Everything installed and put rear assembly back in. Just takes time to make sure it lines up and brake lines stay out of the way. Next project is bushings, new ball joints.
Old Dec 8, 2013 | 01:02 AM
rpmrollbar's Avatar
rpmrollbar
Sorry for some sideways pics guys , iPhone keeps doing that format.
Old Dec 8, 2013 | 01:16 AM
TastyBacon's Avatar
TastyBacon
Thanks for taking all these great pictures. I'm planning on doing the same job myself this winter. How high did you lift the car to drop the drivetrain?
Old Dec 8, 2013 | 01:25 AM
rpmrollbar's Avatar
rpmrollbar
It's about 2 ft off ground. Plenty to crawl around room.
Old Dec 8, 2013 | 04:19 AM
Mustang_Guy's Avatar
Mustang_Guy
Wow!!!!!
I wasn't aware it was this much work for a clutch job on these!!!
I'm used to about 45 mins on my 5.0's lol.
Definitely intimidating to say the least but your pics make it look easy.although I'm doubting it is or was.how much of a PITA was this to do?
Old Dec 8, 2013 | 08:40 AM
7LitreC5's Avatar
7LitreC5
Good job. I can relate to the cold. I was out pulling the intake manifold on mine yesterday and it was a whopping 27 degrees in the garage.
Old Dec 8, 2013 | 01:23 PM
rpmrollbar's Avatar
rpmrollbar
Ya clutch job actually took all week. Lol, I started last Sunday . 5 hrs on that day, and worked on it 2 hrs each day all week. So overall took 15-18 hrs. But I was cleaning also as I put back together.
Old Dec 10, 2013 | 02:48 AM
rpmrollbar's Avatar
rpmrollbar
Waiting on parts so started cleaning up parts I took off. The borla system was rubbing on the axle. Almost a hole thru it. Fabbed up piece of stainless and welded that in tonight. Found out previous owner actually put some healthy swaybars in. Ya that was rubbing too. So made a bracket to move ABS up out of way of swaybar. So new swaybar was ordered. Already had 35mm in front so ordered 24 mm rear.
Old Dec 10, 2013 | 02:51 AM
rpmrollbar's Avatar
rpmrollbar
Pic of ABS bracket . Was 97 only year this was in rear of car??
Old Dec 10, 2013 | 01:28 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
I've never even seen the abs module in the rear like that.
Old Dec 10, 2013 | 03:09 PM
  #33
rpmrollbar's Avatar
rpmrollbar
Ya me neither, wonder if it was 97 year only? Looks factory tho. Although looks like a dumb location, there was a lot of brake lines running thru tunnel. Made the torque tube removal and install very tedious.
Old Dec 11, 2013 | 01:07 AM
  #34
rpmrollbar's Avatar
rpmrollbar
Still waiting for more parts do started the tunnel plate project. Got some 6061 alum 1/4" thick and started making a better piece. Should help handling and make chassis stiffer. Whole project was only 43 bucks and fun to just make it myself. Turned out nice, dropping off to powder tomorow.
Old Dec 11, 2013 | 01:10 AM
  #35
rpmrollbar's Avatar
rpmrollbar
Finished and ready for coating.
Old Dec 11, 2013 | 09:03 AM
  #36
Paul Schmidt's Avatar
Paul Schmidt
You really should have opened up the torque tube and rebuilt the guibos. With that mileage and a life of drag racing. You will dropping the drive train again.... Soon. I think in 98 the ABS was in the rear too.
Old Dec 12, 2013 | 11:44 PM
  #37
rpmrollbar's Avatar
rpmrollbar
Took swaybars and tunnel plate to powder today. Bushing project starts next week, this weekend tackling the LG headers and full exhaust install.
To Winter project has begun!
Old Dec 13, 2013 | 10:50 AM
  #38
xzo124's Avatar
xzo124
Didn't try the open end wrench trick, that magic wrench arrives today so lets hope it works after waiting 2 days for it , and next day shipping. LOL. The motorcycle jack works great, it spreads the load so easir for assembly to balance on. Now that the exhaust manifolds are off, looking for some heads. Anyone know of some 243's for sale please let me know. I would like to try a pair of those with some porting, Only looking for around 430 rwhp. Should be manageable for my first year of roadracing.
Advance Induction CHD can fix you up easily ...xzo
Old Dec 13, 2013 | 04:41 PM
  #39
rpmrollbar's Avatar
rpmrollbar
So wanted to add some clutch fluid to new system. Any reccomendations??
Old Dec 13, 2013 | 04:52 PM
  #40
bracketshark's Avatar
bracketshark
you'll be sorry if you don't do this while your in there..
