Winter project has begun!
Old Dec 22, 2013 | 04:41 AM
  #61
rpmrollbar's Avatar
rpmrollbar
More pics of rear
Old Dec 24, 2013 | 07:16 PM
  #62
SLOWBRAH's Avatar
SLOWBRAH
Looks Killer!!! I'm subscribed!!!
Old Dec 28, 2013 | 02:17 AM
  #63
rpmrollbar's Avatar
rpmrollbar
Well got everything back together after guibos replacement. Sometimes things go smooth and somedays not so much. I had 3 friends over to help reinstall and one must have been ford lover or something. Lol. Starting to bleed clutch and fluid was running out of bell hosing. Argh!. Yep " someone " forgot to tighten the lines going in slave. Nice. So yep everything came out again, or is it again x 3? . So now pretty savvy in vette undercarriage. Lol. All fixed and bled now . On to finish brakes tomorow.
Old Dec 29, 2013 | 02:05 AM
  #64
rpmrollbar's Avatar
rpmrollbar
Got front control arm bushings done today. Bottom front arms have to be torched out , once out the steel sleeve gets cut in half and pressed in both sides. Not a difficult procedure just time consuming. Rubber everywhere! Top arms were easier, heat the sleeve and it slides right out. Clean them up and press in with new bushings already in. Whole front bushings project took about 5 hrs. Reinstalled the swaybar and end links. Next up project is brakes.
Old Dec 29, 2013 | 02:09 AM
  #65
rpmrollbar's Avatar
rpmrollbar
Pic of front assembly finished. Bushings were definitely alot of labor but should provide better handling for not alot of cash.
Old Dec 29, 2013 | 08:00 AM
  #66
Sids04's Avatar
Sids04
Nice work !
Old Dec 29, 2013 | 09:59 PM
  #67
1998BlackPlasticToy's Avatar
1998BlackPlasticToy
Originally Posted by rpmrollbar
Got exhaust manifolds off today, wasnt too bad. Welds on previous system someone installed were "special". Tool for the slave arrives tomorow so ill finally get to see clutch damage.
Nice!! Looks like the work of some of the "Certified" welders we had to train to build the freight cars where I worked... We had to start a school just to teach all the Cert'd guys to REALLY weld, LOL
Old Dec 30, 2013 | 11:19 PM
  #68
rpmrollbar's Avatar
rpmrollbar
Got calibers back from powder , I did victory red with hi temp powder. Will withstand up to 900 degrees. All 4 calibers came to 75 bucks to powder. Reassembled with new seals, put some hawk ceramic pads on for street. Saving the race pads for the track days. Same time installed some new braided brake lines as well. Got rear on today, front scheduled for tomorow .
Old Dec 30, 2013 | 11:21 PM
  #69
rpmrollbar's Avatar
rpmrollbar
Installed pic
Old Dec 30, 2013 | 11:33 PM
  #70
blown81bu's Avatar
blown81bu
Very nice work u may want to cut down those arp studs 1/2 "so u can use the lugnuts unless your going open end
Old Dec 30, 2013 | 11:41 PM
  #71
rpmrollbar's Avatar
rpmrollbar
Yes they are open end. Trying some of those anodized alum ones. Yes alum lugnuts still make me nervous but they worked great on my drag car. So trying them here on street/road course scene.
Old Dec 30, 2013 | 11:45 PM
  #72
TastyBacon's Avatar
TastyBacon
Nice. Are those the ARP 2.5" long studs? 100-7708? I didn't know they were threaded all the way to the end.
Old Dec 31, 2013 | 12:05 AM
  #73
rpmrollbar's Avatar
rpmrollbar
Yes those are the 2.5". I also have a 1/2" spacer that goes on cause of the ZR1 c6 rims
Old Dec 31, 2013 | 12:06 AM
  #74
TastyBacon's Avatar
TastyBacon
Cool, I'm planning on doing the same thing with my C6 wheels
Old Dec 31, 2013 | 12:10 AM
  #75
rpmrollbar's Avatar
rpmrollbar
Yes that offset looks really factory even with the 305/30 on the rear. ��
Old Dec 31, 2013 | 04:45 PM
  #76
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
Did you put some Loctite on the slave cylinder side of the speed bleeder? Twisting on the other end can loosen it up at the slave causing the leak you were describing.
I had to take my driveline out 3 times too when I replaced my clutch the first time.
Old Dec 31, 2013 | 04:59 PM
  #77
rpmrollbar's Avatar
rpmrollbar
Funny you mention that cause this time that's exactly what we did, we used some blue Loctite on the lines where in went into the slave. lol. I think it got loose when we were trying to position up inside the tunnel. So many brake lines and fuel lines up there it probably hit something and got loose.
To Winter project has begun!
Old Jan 2, 2014 | 01:03 AM
  #78
rpmrollbar's Avatar
rpmrollbar
Got front brakes installed. The corvette letters of course came powdered over, had to sand off. Came out pretty nice. All the calibers now have new O rings and dust boots, braided lines, street pads are on. Bled the system, put Motul fluid in. This weekend tackling the LG header and exhaust install.
Old Jan 3, 2014 | 03:41 AM
  #79
rpmrollbar's Avatar
rpmrollbar
Today was header and exhaust install. Driver side actually was easy, goes in from bottom. Couple wires in the way near back of motor but it slides by. Passenger side was the patient side. Valve cover comes off, and the starter got unbolted and just moved out of the way. It goes in from the top. Once both sides are in I put new GM gaskets in with ARP 12 points bolts. The exhaust was time consuming lining up everything but not hard. Overall took around 10 hrs to install the LG headers and full exhaust. Mine has the cat delete, we don't have DEQ out here. My Borla stingers bolted right up, perfect fit. Question I have tho is I used the adapter to plug my rear O2 sensors in the front location. So now I have the rear empty plug socket, do I leave like that or plug another sensor in there and just zip tie it?? Will it still work if nothing plugged in that socket?
Old Jan 3, 2014 | 03:45 AM
  #80
rpmrollbar's Avatar
rpmrollbar
Installed fun.
