Voltage regulator stuck open?
Old Dec 10, 2013 | 10:11 PM
Dcollins3208's Avatar
Dcollins3208
Started the car today for the first time in 4-5 days (we've had terrible freezing weather/ice here in Texas), and the voltage jumped and set the voltage high DTC, then once it warmed up all was well. I can shut the car off and immediately restart and voltage stays constant, no spike at all. If I let it sit a while and start it the voltage will jump again. Not sure if the voltage regulator is "frozen open" because of the temps/ humidity in the air here then it thaws out, or if there may be another problem. Your help is much appreciated.
Old Dec 11, 2013 | 10:17 AM
3boystoys's Avatar
3boystoys
Battery is probably way down on charge, try keeping it on a trickle charger and see if it happens again.
Old Dec 11, 2013 | 10:46 AM
Dcollins3208
That's actually what I was beginning to think because the car wouldn't start this morning but could be jumped. Battery is on trickle charge as we speak, will update this evening.
Old Dec 11, 2013 | 11:02 AM
mrlmd's Avatar
mrlmd
You need to get the battery on a regular charger to get it fully charged first. A "trickle" charger is usually meant as something which will maintain a battery' s charge when left standing for prolonged periods, but will not recharge a dead battery as the output is too low.
Old Dec 11, 2013 | 11:04 AM
dadaroo's Avatar
dadaroo
If the battery is good, you may have a parasitic drain you need to resolve.
Old Dec 11, 2013 | 12:29 PM
lionelhutz's Avatar
lionelhutz
The voltage regulator is electronic so it's doubtful it can "freeze open".
The voltage should not charge way high even with a low battery. The regulator should still hold the voltage in the 14V-15V range.
Maybe you could be a little more clear about what you mean by "the voltage jumped". What voltage level? How long?
Old Dec 11, 2013 | 12:57 PM
Dcollins3208
Only upon start up, shot up above 17 I believe then back to normal (very quick spikes, maybe 1 second) Then it drops to where it should be and remains constant
Old Dec 11, 2013 | 07:25 PM
Dcollins3208
UPDATE: all it ended up being was a loose nut on the starter. Go figure
Old Dec 11, 2013 | 08:17 PM
joes2001's Avatar
joes2001
Basically, when an alternator does not see a "load", the voltage will go high. Sometimes really high. You were lucky that it was a loose connection and making intermittent connection else you would have fried the alternator and maybe other electronics. Makes me want to go and check my connections.
Good Luck, Joe
Old Dec 11, 2013 | 08:35 PM
Dcollins3208
I agree, very glad it didn't fry anything. Headers will be coming off very soon so I can apply locktite to hopefully prevent this from happening again. I had initially written this off thinking it couldn't be the cause because I replaced the starter around 1-2 months ago and had tightened the nuts pretty tight.
Old Dec 12, 2013 | 03:09 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Actually there is a voltage sense line that goes from the starter solenoid back to the alternator. That wire is how the regulator reads the B+ voltage on the BATT Output terminal on the back of the alternator. If that SENSE wire is open or has a poor connection, the alternator goes to full output.
Bill
Old Dec 13, 2013 | 07:06 AM
dadaroo's Avatar
dadaroo
Here is the complete design including the PCM interface. There is a way to check everything so if you need help to do that let us know.
Old Dec 13, 2013 | 09:14 AM
Dcollins3208
Thanks dadaroo. Although I've fixed my "voltage regulator" problem, it appears I now have another problem I need to track down. I will occasionally get a "charging system fault" as well as a p1637 code. I took a quick look and the gray fusible link wire on the stater solenoid appears to be exposed and frayed; hoping this is what's causing the issue. Pulling the headers off this weekend so i can repair it and will also be applying lock-tite to the nuts, threads, etc so they hopefully will not back off anymore.
To Voltage regulator stuck open?
