Differential swap question
Old Jan 31, 2014 | 10:03 AM
FASTFORM's Avatar
FASTFORM
Default Differential swap question
I have a 2003 A4 with 2:73 rear diff. What is involved in swapping to a 3:42 Z06 diff? I tried a search and couldn't find any similar question.
Thanks, Bill
Old Jan 31, 2014 | 10:54 AM
GoBallsDeep!'s Avatar
GoBallsDeep!
Thanks, Bill
http://www.tim-yvonne.com/mikemercury/342.htm
Although I have never done this before, I would be willing to lend a hand. I live in Clearwater.
Old Jan 31, 2014 | 10:56 AM
NukeC5's Avatar
NukeC5
A 3.42 diff is a direct swap. As long as its in working order, you wont need anything special. But everyone will tell you, now is the time to do a higher stall converter while your at it. You will pay for the labor twice if you decide to later. And if you have big power plans in the future, build the diff with stronger parts. IE: C6 output shafts because the C5's are weak, etc. I'd grab a solid transmission mount too. Will stop wheel hop and lessen the likelihood of breakage.
Old Jan 31, 2014 | 11:07 AM
Cutlassmaster's Avatar
Cutlassmaster
Also you will need to adjust the trans shift points for the new gear ratio.
Chris
Old Jan 31, 2014 | 11:20 AM
NukeC5's Avatar
NukeC5
Chris
Shift points and shift pressure
Old Jan 31, 2014 | 11:25 AM
FASTFORM's Avatar
FASTFORM
Thanks to all who have replied. This is why I love this forum!
Old Jan 31, 2014 | 11:31 AM
1999corvettels1's Avatar
1999corvettels1
Does it have to be a Z06 unit, or any unit as long as it came from a 6 speed manual car?
Old Jan 31, 2014 | 03:01 PM
PRE-Z06's Avatar
PRE-Z06
Any will work, 2001+ are all 3-rib cases which are stronger
Old Feb 7, 2014 | 12:44 AM
seansz28's Avatar
seansz28
a problem I ran into going from a normal 6spd diff. to an auto diff. case with 4.10 gears. my speedometer no longer works and i cannot figure out why because both diffs looked complety identical
Old Feb 7, 2014 | 09:20 AM
Patches's Avatar
Patches
Speedometer runs off the sensor on the top, passenger side of the diff. If it's not hooked up or if the sensor or wiring are malfunctioning, no speedo.
You can see the sensor connector on the diff in this pic.
Old Feb 7, 2014 | 09:26 AM
Patches's Avatar
Patches
OP, replace all the seals/O-rings while you're at it.
Also, if you source a diff from a manual car, realize that you need to transfer the A4 adapter plate from your diff to your new one. The adapter plate fits into the recess on the front of the diff pictured here.
Here's a thread I posted on several mods I did, including swapping in a 3.42 for the 2.73 diff. I also installed a high stall converter. I adjusted the shift points and pressures using EFILive.
http://forums.corvetteforum.com/c5-g...mega-pics.html
Old Feb 7, 2014 | 06:00 PM
PRE-Z06's Avatar
PRE-Z06
I agree with Patches, maybe the wiring got pulled loose from plug I'd check the electrical connection and report back.
Good point about the adapter plate
Old Feb 7, 2014 | 09:28 PM
seansz28's Avatar
seansz28
the sensor wiring all looks good. it does read something but its way way off. for example at 20mph it reads 0 but at 65 its within reads around 30mph. i also swapped out sensors and still the exact same issue. during instalation the wire did break but i soldered a new connector back on. could it be i accidentally got the wires backwards?
Old Feb 8, 2014 | 02:52 PM
stein3282's Avatar
stein3282
Is it better to just swap out the gears instead of the whole rear end?
Old Feb 10, 2014 | 03:43 PM
PRE-Z06's Avatar
PRE-Z06
You can't put 3-series gears in a 2-series case and less labor as long as diff is in good shape, hope that helps.
Old Feb 11, 2014 | 04:15 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOTS of good info above!!
Any used C5/c6 differential, needs to be disassembled and examined. At a MINIMUM,,,,,,,, New seals need to be installed.
Most C5 differentials have worn antislip clutches. Most have BROKEN Clutch Springs They are large bent washers(Belleville Washers ) that apply the correct preload on the Limited Slip Clutch Packs. When they break, the clutches slip excessively and wear out prematurely.
Here are some Post that detail how to install C6 Differential part into your C5 Differential. This a a DO IT YOUR SELF project and is a great bang for the buck!!
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
Old Feb 16, 2014 | 02:42 PM
kh400's Avatar
kh400
Just finished swapping out the 2:73 diff. For thr 3:42. Bill is right, you should disassemble and inspect and replace. All seals anf o rings. Mine had one cracked bellville washer. Also installed a 3000 stall convertor from phoenix trasmissions along with a huge trans. Cooler.difference in performance is remarkable.makes an overly civilized car a little rawer.now for the new LS-6 installation and i should be happy!!!!!
To Differential swap question
Old Feb 16, 2014 | 04:30 PM
stein3282's Avatar
stein3282
Is it worth it to just buy a new differential, or just swap the gears with same differential?
Old Feb 17, 2014 | 01:40 AM
NukeC5's Avatar
NukeC5
If you send your diff in as a core, the RPM stage two diff isnt too expensive.
Old Feb 17, 2014 | 07:28 PM
stein3282's Avatar
stein3282
I can buy gears for 3-400. Thats why I'm asking about just swapping gears or the whole differential.
