Spark Plugs
Old Feb 26, 2014 | 08:32 AM
hgoodwiniii's Avatar
hgoodwiniii
Default Spark Plugs
Hi all, what's the correct spark plug gap for AC Platinium plugs for a 2001? I know the owner's manual says 0.06 inches for the original Denso (#PTJ16R15) plugs. The auto parts store says the AC Delco plugs should be on 0.04. Which is correct? Thanks.
Old Feb 26, 2014 | 09:05 AM
Corvette_Ed's Avatar
Corvette_Ed
The iridium plugs I installed last year are .040.
Old Feb 26, 2014 | 09:14 AM
Dave02C5's Avatar
Dave02C5
I run copper TR55's @ .060
Old Feb 26, 2014 | 11:14 AM
MAC5's Avatar
MAC5
The current OEM replacement plug is ACDelco 41-110, and they are pregapped to .040
I double check them anyway before installing.
Old Feb 26, 2014 | 11:38 AM
Dave02C5's Avatar
Dave02C5
I tried the new spec .040 with the Iridium TR5 and it seemed a little low on power.. went back to .060 gap with a TR55 copper core and the power is back. FWIW
Old Feb 26, 2014 | 01:37 PM
Old Horsepower's Avatar
Old Horsepower
My results were the other way. I couldn't tell any difference in power but the idle was smoother with the Iridium's.
Old Feb 26, 2014 | 03:29 PM
hgoodwiniii
Ok, looks like the between the AC delco 41-110 and the AC delco 41-962 is Iridium vs. Platinium. I have the 41-962 which I'm ok with. I'm thinking I will just go with 0.06 on them and see how it runs?
Old Feb 26, 2014 | 03:53 PM
NukeC5's Avatar
NukeC5
New factory spec is .040" , original was .060". I gap to .050"-.055" and it helps smooth the idle as well as keeping close to the original planned spec for the engine. Generally you want the wider gap, but not at the sacrifice of idle and allowing misfires.
Old Feb 26, 2014 | 03:59 PM
LoneStarFRC's Avatar
LoneStarFRC
I would stay with .040.
Old Mar 6, 2014 | 01:23 PM
hgoodwiniii
Car is running very well with AC Delco Professional Plats gapped at 0.040. It has not run this well for a long time. Thanks all.
Old Mar 6, 2014 | 01:42 PM
racebum's Avatar
racebum
i wonder how much of this is in your head
that gap difference might be worth 5-7hp tops
for those of you wondering what i mean, smaller gaps are more detonation resistant and safer, but, they make less power than larger gaps....which are more prone to detonation
Old Mar 6, 2014 | 02:35 PM
3boystoys's Avatar
3boystoys
Gapped mine by the manual (.060) and it ran horrible. Regapped to .040 and all is well.
Old Mar 7, 2014 | 05:53 PM
baxsom's Avatar
baxsom
Spark plug gap has been talked about here many many many times. Original gap was 60 then a TSB came out saying to reduce the gap to 40 instead.
Old Mar 7, 2014 | 08:20 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
Ditch the AC delcos, they are prone to have the pucks bust off. NGK TR55s are what you need.
To Spark Plugs
