Under engine hood lamp timer
Old Mar 25, 2014 | 02:06 PM
Clancy209's Avatar
Clancy209
Default Under engine hood lamp timer
Does anyone know if the 2001 C5 has a timer for this lamp. I have to keep disconnecting the negative battery cable at every show.
Old Mar 25, 2014 | 02:10 PM
jim993's Avatar
jim993
It should go off at about 15 minutes.
Old Mar 25, 2014 | 02:21 PM
3boystoys's Avatar
3boystoys
I have my hood up in the garage most of the time for the battery tender. Light goes off in 10-15 minutes.
Old Mar 25, 2014 | 04:25 PM
Clancy209's Avatar
Clancy209
My light never goes out. That's why I am trying to find out about a timer. None of the books talk about it.
Old Mar 25, 2014 | 04:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its called the RAP circuit and it times out usually around 12 minutes. Shut the car down with the redio ON and see if it turns off on its own after the RAP circuit times out.
Old Mar 25, 2014 | 05:45 PM
Clancy209's Avatar
Clancy209
Hey Bill,
Tried your advice everything turned off except the under hood lamp
Old Mar 25, 2014 | 07:01 PM
SG Lou's Avatar
SG Lou
get yourself one of these
Corvette Underhood Light Turn-Off Switch, 1997-2004
•Turns Off Courtesy Light At Your Discretion
•Ideal For Prolonged Work/Shows
Turn off the underhood courtesy light with a simple flip of the switch and prevent a dead battery. Simply plug in the supplied harness, no cutting or splicing is required, mount the switch and you're done in less than 15 minutes. All mounting hardware, including the "Flex Guard" conduit is supplied for a "factory installed" look.
http://www.ecklerscorvette.com/corve...1997-2004.html
Old Mar 25, 2014 | 07:22 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Look in the instrument panel fuse box. Relay 37 is the MONITORED LD relay. That relay controls that light as well as the IP Compartment lamps, the Vanity mirror lights and mirror lights. Check and see if that relay is switching.
Ide say change that relay if it doesnt switch..
If you cant find it locally, contact Gene Culley www.gmpartshouse.com
If that relay is working correctly, the BCM is the root cause and not switching the lamp off
Old Mar 25, 2014 | 07:26 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If the relay is bad, Repairing that relay could save you a dead battery. We frequently leave one of those lamps on accidently.
See if you can turn the DIMMER all the way up and turn the lamps listed ON
Please tell us how you make out.
Bill
Old Mar 25, 2014 | 07:30 PM
Clancy209's Avatar
Clancy209
Bill
I will check rely tomorrow, but to be on the safe side I also ordered the switch SG LOU suggested.
Old Mar 25, 2014 | 07:31 PM
65GGvert's Avatar
65GGvert
Look in the instrument panel fuse box. Relay 37 is the MONITORED LD relay. That relay and controls that light as well as the IP Compartment lamps, the Vanity mirrorlights and mirror lights. Chack and see if that relay is switching.
Ide say change that relay..
If his other lamps are going out, can it still be the relay?
Old Mar 25, 2014 | 09:50 PM
jrose7004's Avatar
jrose7004
Mine goes out after 10 or 15 minutes.
Old Mar 25, 2014 | 10:10 PM
dimler's Avatar
dimler
Default Under hood Lamp
OR follow the wire down approx. 18 to 24 inches and disconnect at the wire junction. It's a simple pull apart plug. Unplug for the show and connect before you drop your hood and go home.
Old Mar 26, 2014 | 12:07 PM
DougBoost's Avatar
DougBoost
Was about to say the same thing as above, it's pretty easy to reach and disconnect that plug. In fact, it's rare I actually want the light on when the hood is up. But if working correctly it will shut off after 10-15 minutes as others noted.
Old Mar 26, 2014 | 12:43 PM
s'noJob's Avatar
s'noJob
If the OP did not buy his car new, I wonder if a previous owner hardwired the hood light for whatever reason.
Old Mar 26, 2014 | 03:04 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Good point. Look down by the radiator shroud (passengers side where the harness is and see if its correctly connected to the OEM harness connector.
Old Mar 26, 2014 | 04:11 PM
JoeDAnnunzio's Avatar
JoeDAnnunzio
Be careful disconnecting the cannon plug. It doesn't seat as well as some of others on the car, and the pins are fragile.
I just spent the last hour splicing in blade connectors.
To Under engine hood lamp timer
Old Mar 27, 2014 | 02:59 PM
Clancy209's Avatar
Clancy209
Funny thing happened yesterday. I opened the hood turned on the sun visor vanity lights, came back 20 minutes later everything was off
I said to myself :stopbeatingadeadhorse: maybe it's working OK. I put the sun visors up and the under-hood light came on again. Must be something loose some where. Easier to install new switch then to ring out wires.
Thanks for everyone's input and help.
Old Mar 27, 2014 | 05:04 PM
MAC5's Avatar
MAC5
Is there a regular bulb or a LED installed in that underhood lamp fixture?
Old Mar 27, 2014 | 08:10 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I was thinking the same thing.
The BCM looks for current draw to turn the lights back on. When you cycled the mirror light switch, the BCM turned the lights back on. Any electrical disturbance will start the timer over again.
Give it another try and see if the under hood light does go out after 10-15 minutes. Mine turns off after 12 minutes but some C5s do it sooner, some take longer.
Another thought. If something in the car is turning on and off (like your seat motors or lumbar pump motor), the timer will never turn the lights off.
Bill
Bill
