Roller rockers
Old Aug 16, 2014 | 09:41 PM
RonSSNova's Avatar
RonSSNova
I was, correct.
I've had the stands and rockers off my turbo motor several times of late. I had to replace the head gaskets then do a retorque.
The stands are nice, but at the same time don't grab the trunion until you nearly have the bolt tight. You have to make sure the rocker is aligned before the final torque.
Thought I read once that Lingenfelter made precision steel stands.
Anyway, that Jessel rocker is to nice to put in an engine. :-) looks like artwork to me.
Old Aug 17, 2014 | 07:50 AM
vettenuts's Avatar
vettenuts
Sorry about the rocker ****. LPE does make machined steel stands. And they can be milled to adjust rocker geometry if necessary. I looked into them when I was trying to get a good wipe out of my stock rockers, but I just couldn't come up with anything I was happy with so I went to the YT's. The wipe I achieved with them is 0.045" wide.
Old Aug 17, 2014 | 12:57 PM
bracketshark's Avatar
bracketshark
Originally Posted by vettenuts
Not needed. The roller tips slide, they don't roll. The stock heads also have powder metal guides which won't wear like a bronze guide so the wipe pattern is less critical. The stock rockers are also very light requiring less valve spring to maintain valve control. Only time I would switch to a roller tip rocker is high valve lift from an aftermarket cam or aftermarket heads with bronze guides.
Really? Where did you get this information? I've seen thousands of roller rockers (off of drag cars and round track), I've never seen one that showed signs of the roller tip sliding. Not being critical here just looking for some conclusive evidence. Please show some documentation.
Well hundreds anyway...
Old Aug 17, 2014 | 01:48 PM
ssrallyred's Avatar
ssrallyred
Originally Posted by strand rider
In a recent issue of Hot rod magazine , they help out a C5 owner with long term problems on his boosted engine .
One of his problems was the added mass of roller rockers was limiting rev's high in his power band. They go through the guys valve train , you might find the article entertaining, I did. It restates what has been posted here, but with pictures and more story.
I had the same issue on an 02 SS with Harland Sharp roller rockers. Alan Futral was tuning it back in the day and actually asked me did I have roller rockers on it because of the way it fell off over 6K. Because it was a group dyno tune day I had time to replace with stock rockers and it picked up hp at a higher peak rpm.
Old Aug 17, 2014 | 07:58 PM
vettenuts's Avatar
vettenuts
David Vizard discusses this in some of his writings and I have read similar findings in other places as well, but John Lingenfelter states in one of his books: "Roller rockers have become more affordable and popular but there are few misconceptions about roller rockers that should be addressed. Perhaps the most misunderstood point is that the roller tip actually rolls across the valve stem tip. This is not true. Even though the roller will spin easily between your fingers, once loaded against the valve spring pressure the roller merely slide across the valve stem."
Roller tips become a necessity when you have an aluminum rocker to provide a hardened contact point to transfer the rocker motion to the valve stem motion. Not truly required with a steel rocker, although it can aid in obtaining a more optimized wipe pattern.
Old Aug 17, 2014 | 09:54 PM
bracketshark
OK, Well Jim Miller explains it this way:
Believe it or not, even to this day, people think that the roller tip is for rolling on the valve. It is NOT. The roller tip is for one reason only, and that is to convert the shifting length of the rocker’s arc (that moves across the valve on a shoe design), to a fixed length that moves far less in its effect, because it is always point down in line with the valve’s motion, just as a roller tappet of a cam is always aiming its contact tangent line with the axis of the camshaft.
That doesn't mean the roller slides across the valve stem, it articulates, at least the way I read it. I'm not smart enough to debate any of these rocker arm issues, I just read and wish I could be involved in the testing these smart guys have done. John Lingenfelter is a smart guy also I expect he got some education from Jim Miller somewhere along the line.
Read some of this when you have time and keep a open mind.
http://www.aera.org/engine-professio...cker-geometry/
Rocker arms always open a can of worms with me, I used one of those little Moroso plastic jobs to set pushrod length on my 408 bracket motor years ago. I feel so stupid after reading Jim's articals. I've read his stuff so many times its starting to make since.
Old Aug 17, 2014 | 10:24 PM
RonSSNova's Avatar
RonSSNova
If the roller tip doesn't roll, why make it so it can?
And if it doesn't roll, how could the roller tip axles have failed in my 3rd gen YT rockers?
Ron
Old Aug 18, 2014 | 01:58 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ron
The roller tip contains a roller, needle bearings and a shaft. All I can think of is,, If the roller doesnt roll, the shaft inside the roller has to rotate in the bearing.
Old Aug 18, 2014 | 06:52 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Ron
I'll take a SWAG (scientific, wild-azzed guess) and say that the point load of the roller against the valve tip fatigued the axle, and it snapped.
Old Aug 18, 2014 | 08:34 AM
vettenuts's Avatar
vettenuts
Thanks for the link. I have read many of his writings although not he one you provided the link for. One thing I have found with all the LS1 rockers is that they move from the inside to outside with the further outside point being max lift and the furthest inside point being the closed valve position. Many articles indicate the rocker will sweep out than in during the lift, but I have never seen that on the LS1 although I have admittedly not set up all manufacturers rockers. One of the worst was the Crane Quick Lift rockers, the rocker pattern covered a majority of the valve stem contact area providing a wide sweep.
Old Aug 18, 2014 | 11:46 AM
RonSSNova's Avatar
RonSSNova
Actually Bill, there are no needle bearings in the tip. Just a wheel and shaft.
Old Aug 18, 2014 | 06:00 PM
NemesisC5's Avatar
NemesisC5
Doesn't someone make nice machined steel ones?
Comp makes a steel rocker that has been "lightened" up a bit with roller tip. With that said, I removed my YT-6645's in favor of new factory rockers with trunion upgrade installed from Texas Speed...$145.00/set of 16 I believe.
Below are the Comp "Ultra Pro Magnum" in 8650 chromemoly steel, very nice looking pieces. The roller tips do not have bearings of any kind.
http://www.compcams.com/Products/CC-...rs'-0.aspx
Old Aug 18, 2014 | 06:42 PM
  #33
RonSSNova's Avatar
RonSSNova
Nice, but they are only 1.8 ratio.......
Old Aug 18, 2014 | 07:08 PM
  #34
vettenuts's Avatar
vettenuts
They are also stud mounted and I would prefer the shaft mounted arrangement of stock or YT rockers.
Old Aug 19, 2014 | 07:17 AM
  #35
NemesisC5's Avatar
NemesisC5
Merely pointing out a lightweight chromemoly steel unit with good "arm design" as compared to the aluminum offerings. Surprised that Comp does not make these in 1.7's......yet
Old Aug 19, 2014 | 08:12 AM
  #36
vettenuts's Avatar
vettenuts
I think if they made a similar design that mounts like stock in the 1.7 stock ratio that they would be a big seller. Not sure why they went 1.8 since most LSx owners shy away from the higher ratio rocker arms. Just doesn't seem like a brilliant business move.
Old Aug 19, 2014 | 08:44 AM
  #37
mrr23's Avatar
mrr23
St. Jude Donor '15
love the 1.8 ratio. Still have to use stock stands.
Maybe they are following gm with their move to 1.8 in the ls7 motors.
Old Aug 19, 2014 | 11:52 AM
  #38
RonSSNova's Avatar
RonSSNova
It would be a good question to ask Comp.
Cams are pretty much designed around the rocker ratio. So if you knew you were using 1.8 rockers up front, you would pick the cam accordingly.
For most of us who already have a cam installed, the extra lift just might run the valves into the peestons.
Old Aug 19, 2014 | 03:28 PM
  #39
mrr23's Avatar
mrr23
St. Jude Donor '15
When going to a higher ratio rocker, it also slightly changes the duration as well. This is because it opens the valve sooner and closes later. How much it changes depends on rocker design.
It is best to check your piston to valve clearance when going to a higher ratio rocker if you have an aftermarket cam. Talk with your cam manufacturer and/or engine builder.
