anti theift security
Old Nov 20, 2014 | 12:48 PM
Corvette_Ed's Avatar
Corvette_Ed
Originally Posted by 65GGvert
My point is that the "alarm" isn't the problem. Neither is the security. The neighbor's remote would have to be triggering the "panic" function. Otherwise, just turning on the alarm (security) would not make the alarm sound unless the door were opened. Therefore, his question about bypassing the theft security would not be answered by bypassing it. He would have to disable the receiver, and therefore his remote function and tpms mode. In other words, apparently his neighbor has the frequency of the "panic" function of the fob and is using it, maybe even just to annoy him.
Ah, ok. I do agree with that. When I said "alarm" I was speaking of the system as a whole, which would include the panic function, and not just the alarm functionality.
Old Nov 21, 2014 | 08:19 AM
dadaroo's Avatar
dadaroo
It also may be that the BCM may be acting on it's own. I have deal with several BCMs on C5s and C6s that "wake up" and start doing weird stuff. If it were me I would just remove the serial bus pin at the BCM and see if that stops it or not since it is easy to access. Could also just unplug the RFA to test.
Old Nov 21, 2014 | 09:55 AM
65GGvert's Avatar
65GGvert
I thought it was established that the neighbor's truck remote was setting of off the horn (panic function) on the Corvette. Unless he unplugs it every night, it won't help with his problem.
Old Nov 21, 2014 | 10:57 AM
dadaroo's Avatar
dadaroo
He has not provided me enough evidence that the truck is the root cause yet. He should have worked with the neighbor to test the theory of whether the truck was the cause. I think at this point he may have severed the neighbors support.
If he removes the RFA from the equation and it does not happen again then it would seem that the truck (or something else) is the cause. BCMs can have a life of their own and I would like to prove what is the root cause.
Old Nov 21, 2014 | 10:59 AM
rodsvet's Avatar
rodsvet
It hasn't happened in a few weeks now. My remote needs to be reprogramed almost every 2-3 days. I pulled the connectors in both accordians in the doors and the pins look perfect with no signs of shorts or bare wires. So it must be an electrical gremlin as others have spoken to in other threads. Thanks for your inputs. Rod
Old Nov 22, 2014 | 07:11 AM
dadaroo's Avatar
dadaroo
If you want to deactivate the RFA by just disconnecting the serial bus wire at the BCM let me know. Easier to do than getting to the RFA and it can be reconnected in a few minutes.
Old Nov 22, 2014 | 11:17 AM
rodsvet's Avatar
rodsvet
Dadaroo, thank you for the offer. I'm no electrical guy. I will save your post if you don't mind, and if the alarm thing gets too bad I will PM you! Rod
Old Nov 22, 2014 | 12:10 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Why not just pull the RFA fuse. With that fuse removed, the car will NOT respont to ANY frequency generated commands.
You will not have any Tire Pressure Sensor readings or FOB functions but,, you will be able to tell if the car is being told to blow the horn by internal OR external reasons.
Bill
Old Nov 23, 2014 | 07:42 AM
dadaroo's Avatar
dadaroo
I agree pulling fuse 27 will do it but I did not recommend to pull it since it will also disable HVAC controls.
Old Nov 24, 2014 | 01:23 PM
Fast one's Avatar
Fast one
If you want to kill the horn part of the alarm then install a relay that connects the horn power when the ignition is on and breaks it when the ignition is off.
Old Nov 24, 2014 | 06:20 PM
bob guzzy's Avatar
bob guzzy
Why not shut the power off, there are disconnects on the market meant to kill power to the whole car for storage.
Someone had on on the z06 I bought I just took it off, it's brass and well made.
I found this one on line it has a different style shut off but they all do the same thing.
http://galleryplus.ebayimg.com/ws/we.../1000x1000.jpg
Using a 9V battery plugged into the cig lighter keeps the radio codes on a c4 alive it should work on a c5.
Old Nov 24, 2014 | 06:55 PM
Ghunt's Avatar
Ghunt
You may just have a bad alarm module if you have to reprogram the key fob often
Old Nov 24, 2014 | 07:49 PM
  #33
65GGvert's Avatar
65GGvert
That's a bad fob. Well documented and sometimes repairable. Google "C5 legendary problem solved" and the fix will come up.
