Check eng light
Old Mar 9, 2015 | 03:49 PM
Hogloving's Avatar
Hogloving
8th Gear
Default Check eng light
I get a check engine light that goes out after about 200 miles. The dealer checked and found code P104 and 107 I believe. Lt and RT bank lean. They could find nothing wrong except the dip stick was pulled out a little. This has happened before so I told them to install a now "O" ring and see if it happened again. How does the check engine light know the dip stick is not seated all the way in. Is it engine case pressure low. Why does the dip stick work its way out. I have 124K miles on the car but it does not use any oil nor does it smoke so I do not think the case pressure is high. Any ideas.
John
Old Mar 9, 2015 | 04:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
John
The engine crankcase is sealed and ventilated by the Positive Crank Case Vent valve (PCV ) The PCV allows a very slight vacuum to be drawn on the crankcase during part throttle operation.
If the dip stick is being blown out of the tube, you either have a bad defective PCV valve ( CLOGGED ) OR the rubber fitting that connects the PCV to the intake manifold is cracked/deteriorated and leaking manifold vacuum.
The vacuum leak can cause a bank lean condition.
OR
You have excessive piston ring blow by caused by worn or carbon clogged up compression rings.
Recommend that you carefully examine all the tubing and rubber fittings on the entire PCV pluming!
Bill
Old Mar 10, 2015 | 11:49 AM
Hogloving's Avatar
Hogloving
8th Gear
Originally Posted by Bill Curlee
John
OR
Bill
Thanks for the info. If I get the light again I will check the PCV valve.
I just left Hendricks Chev who should be very good on Corvettes, they sell about 30 a year and they could find nothing wrong except the dip stick pulled out. I thought they would have checked the PCV valve and maybe they did. I will continue to monitor. Thanks again
John
Old Mar 10, 2015 | 11:53 AM
73Corvette's Avatar
73Corvette
If I was betting... I would bet on Mr Curlee not any dealership! One of a few guys here that know more about the C5 than most GM certified techs
Old Mar 10, 2015 | 03:10 PM
sting15ray's Avatar
sting15ray
Regarding potential leaks in the PCV line, see my post on what I found when I removed my PCV line this week - see the condition of the rubber at the y-joint that was out of view behind the intake ... 140,000 miles so I guess I can't complain too much
https://www.corvetteforum.com/forums...errerid=341022
To Check eng light
