Zero oil pressure - Debug thread
Old Apr 27, 2015 | 12:00 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The ONLY two things that I have seen cause a ONE DAY GOOD to the next day BAD oil pressure reading is:
-The Pump "INTERNAL" Relief Valve gets stuck in the fully OPEN position.
- The O Ring between the pump and pick up tube fails (this usually happens as a result of poor reassembly)
Oil Pump vs Pick Up Tube CUT AWAY:
BC
Old Apr 27, 2015 | 12:11 PM
73Corvette's Avatar
73Corvette
[QUOTE=Bill Curlee;1589508069]The ONLY two things that I have seen cause a ONE DAY GOOD to the next day BAD oil pressure reading is:
Is there any way to tell when either of these two failures occur, besides taking the pan or pans off and inspecting them?
Old Apr 27, 2015 | 12:46 PM
StingrayRebel's Avatar
StingrayRebel
shouldn't have to pull the pan to inspect the oil pump/pickup tube o-ring... you will have to move the steering rack out of the way and remove the balancer and front cover to gain access to the oil pump... you can remove the pickup tube from the pump and inspect the o-ring without having to lower the pan just be careful not to drop the bolt... for whatever reason there are 2 bolt holes in the pickup tube where it bolts to the oil pump but only one is used, vettes use the front hole and for whatever reason the f-body uses the rear hole which makes an oil pump swap a little more difficult
Old Apr 27, 2015 | 12:59 PM
73Corvette's Avatar
73Corvette
Thanks.. just trying to learn more, so in the future if, I respond I'll be able to help with a better working knowledge of the dynamics involved with the issues the OP is having..
So, is that the ONLY way to tell if that is the problem as Bill described... or is there some other way/symptom to diagnose those two failures?
Old Apr 27, 2015 | 03:20 PM
nullpointer's Avatar
nullpointer
Let me make sure I'm getting this straight...
Your car is running fine no codes, normal operating pressures and temps... then all the sudden, BAM you have ZERO oil pressure.
First off then, I wouldn't have suspected oil pump... I would think that would have been a gradual or drop in pressure, not just BAM to Zero...
Unless there was a hole knocked in your oil pan, oil line broke, something to cause a dump of all of your oil...
My first thought would be OPS, second would have been gauges... wiring.
Of all the threads I've read so far, this one intrigues me more than any others just because it doesn't make sense to me...that the oil pump was the culprit. I'm looking forward to you getting your issue fixed and hoping you have no engine damage....
If the relief valve got stuck, then it would be bam to zero, which is what I found when I removed the ported LS6 pump.
Previous to changing the pump, I did replace the OPS and tested the wiring to the best of my abilities. Also I changed the oil and filter too.
Going to be placing a mechanical gauge on it tonight and seeing if I have pressure. I hope I do, so I don't have to tear it down again. Then its back to the sensor, wiring, etc.
Old Apr 27, 2015 | 03:22 PM
nullpointer
BC
Thanks Bill - The o-ring looked new when removed, it was the relief valve. We re installed the pump, and new o-ring that came with. It was lubed to prevent pinching. Mechanical gauge results coming tonight.
Old Apr 27, 2015 | 05:18 PM
LoneStarFRC's Avatar
LoneStarFRC
In your OP, when you said you tested the wiring, did that include a continuity check for all three wires between the EOP connector and the PCM?
The reason I'm thinking this may still be electrical as opposed to strictly mechanical, is that in your OP you said you experienced zero oil pressure indications, and then you replaced the oil pump (along with the other items mentioned) and still experienced the same thing.
Old Apr 27, 2015 | 05:45 PM
73Corvette's Avatar
73Corvette
Old Apr 27, 2015 | 09:46 PM
nullpointer
Another CF member stopped over today and helped me find the root cause. We tested the pressure using a mechanical gauge, still zero. Then we took the lower batwing pan off, and to our surprise it was clogged. It was a mixture of what looked to be a "fiberish" material and some parts orange gasket, but mainly "fiberish". No idea what is was, but once cleared the car had good oil pressure
Old Apr 27, 2015 | 10:02 PM
IH8FORD's Avatar
IH8FORD
was great meeting you man and your car is awesome glad we were able to figure it out so quickly now get that thing done and tuned lol. the material in the pick up tube was very weird almost looked like steel wool no idea where it could of come from.
Old Apr 27, 2015 | 10:15 PM
73Corvette's Avatar
73Corvette
Did your air filter or oil filter come apart? Can you have the fiber analyzed?
Well, glad you found what the issue was and got it removed...my concern would be where the hell did it come from and will it do it again...
Thank you for posting your findings!
Old Apr 27, 2015 | 10:48 PM
LoneStarFRC
Holy Mackel Andy!
From the description it sounds like an oil filter came apart or imploded.
Old Apr 27, 2015 | 11:16 PM
  #33
IH8FORD's Avatar
IH8FORD
ive seen many oil filters come apart and this did not look like it was from a filter but you never know.
Old Apr 28, 2015 | 08:35 AM
  #34
nullpointer
Great meeting you too, and thanks for the help! Can't wait to get it tuned and cruise
Air filter didn't show signs of coming apart, and yea no idea what or where the hell it came from. Not going to bother having it analyzed, the $$$ tree is getting bare
Originally Posted by LoneStarFRC
Holy Mackel Andy!
I've never seen the inside of an oil filter so I really have no idea, it did look like steel wool but I haven't used any.
Pending my oil pressure stays rock solid I'll be posting updates in my ECS Blower Build thread (Forced Induction Section).
Old Apr 28, 2015 | 08:43 AM
  #35
73Corvette's Avatar
73Corvette
Dollar tree is getting bare... and your doing a blower build... wish my dollar tree was that bare... hope you don't have any more issues!
Old Apr 28, 2015 | 08:48 AM
  #36
nullpointer
Thanks and the dollar tree is bare because of the blower build haha it really adds up fast, and then you are in too deep to stop lol
Old Apr 28, 2015 | 10:26 AM
  #37
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
might be a clogged pickup screen, you will have to pull the pan to get to it though
WINNER!!!!
I would not have suspected a clogged strainer in 100 years.. Only because normally, CRAP like that doesn't get into an engine under normal conditions or when you have the engine disassembled.
SOMEBODY,,,,,,,,,,,, ,,,,,,,,,,,, left a shop towel in the unassembled engine...
To Zero oil pressure - Debug thread
Old Apr 28, 2015 | 10:30 AM
  #38
nullpointer
WINNER!!!!
No doubt something got in there
Old Apr 28, 2015 | 11:39 AM
  #39
StingrayRebel
I agree, a clogged pickup screen would probably be the last thing to expect to go wrong unless the car was just completely neglected which the car in question does not appear to be in the slightest... people do make mistakes, besides the rag in the cylinder bore I saw a guy leave a rag in an oil pan when doing a pan gasket and that car came back in about a week with zero oil pressure due to it sucking the rag onto the pickup and eventually blocking it... obviously I didn't see these things happen right at the moment otherwise I would have told them lol, just seen the aftermath... op, do you have any pics of what was blocking your screen??
Old Apr 28, 2015 | 05:10 PM
  #40
73Corvette's Avatar
73Corvette
Need to add... some Knucklehead leaves a rag in the oil pan
